Drive-Based Homing (DS402)
Implement drive-based homing with DS402-compliant drives, utilizing built-in homing methods, ensuring accurate and network latency-free positioning, easily configured via our API or tools.
🔹 What is Drive-Based Homing?
Drive-based homing uses preloaded methods available on your drive. This allows for homing to be performed entirely in the drive without network latencies producing more accurate results. Drive-based homing is the recommended homing strategy.
DS402 is a set of profile specifications that standardize the functional behavior of controllers for servo drives, frequency inverters, and stepper motors.
It is important to follow your drive’s specific instructions on how to home. Most drive’s include documentation on homing procedures, limit switch configuration, etc.
🔹 How to home?
The following figure shows the relationship between the input objects and the output objects in the Homing Mode. You can specify the speeds, acceleration rate, and homing method. You can also use home offset to offset zero in the user coordinate system from the home position.
  • RapidCode API
    1. Configure
    Using the NetworkNode.ServiceChannelWrite(index, subindex, byteSize, value) method from the Axis class, you can configure the following options:
    Parameter Index Subindex byteSize Value
    Home Offset (optional, normally zero) 0x607C 0x0 4 -
    Home Method 0x6098 0x0 1 -
    Home Speed (when searching switch) 0x6099 0x1 4 -
    Home Speed (when searching zero) 0x6099 0x2 4 -
    Home Acceleration 0x609A 0x0 4 -
    Change Mode of Operation to 6 (Homing Mode) 0x6060 0x0 1 6
    2. Ready Axis
    Axis.Abort(); // Disable the Axis
    Axis.ClearFaults(); // Clear any Faults
    Axis.AmpEnableSet(true); // Enable the axis to trigger the home start
    MotionController.NetworkOutputOverrideSet(..); // Take Control of the associated Axis’s Control Word
    Ensure people and objects are clear of motion.
    3. Home
    Start Homing by setting bit 4 of the Control Word to 1
    (Control Word from 15 → 31)
    MotionController.NetworkOutputValueSet(..); // Set values to the Axis to Start Homing.
    4. Evaluate Homing Success
    You can monitor the Status Word to determine if/when homing is complete:
    • Status Word bit 10 = 1 (HIGH) Homing is Complete
    • Status Word bit 12 = 1 (HIGH) Homing Target was attained
    • Status Word bit 13 = 1 (HIGH) there was a Homing error
    5. Clean Up
    Axis.AmpEnableSet(false); // Disable the Axis
    MotionController.NetworkOutputOverrideSet(..); // Disable Output Override.
    Restore the mode of operation to the control mode you want to run in.
    modeOfOpIndex = 0x6060 // Mode of Operation (DS402 Standard)
    modeOfOpSubindex = 0x0 // Subindex
    modeOfOpByteSize = 1 // INTEGER8 (1 byte)
    modeOfOpValueToDEFAULT = 8 // Hex value to determine Mode (8 = Cyclic synchronous position mode)
    ServiceChannelWrite(modeOfOpIndex, modeOfOpSubindex, modeOfOpByteSize, modeOfOpValueToDEFAULT);
  • RapidSetup
    • Home Method: A combobox which lists the DS402 Home Methods. Not all methods may be supported by a drive.
    • Speed to Switch: The initial speed used to find the Home Switch.
    • Speed to Zero: The second speed used to find the Index or Edge.
    • Acceleration: Acceleration used during Homing.
    • Home Offset: Any post Discovery Offset which you’d like used in the process.
    units are in Drive Units rather than User Units.
  • RapidSetup (Legacy)
    *Value**: 2 (Homing with the positive limit switch and index pulse)
🔹 Homing Methods
Drive-Based Homing uses functions defined in firmware by the drive manufacturer. Below are diagrams of the DS402 standard but exact implementation by the manufacturer may differ.
(2) PositiveLimitSwitch LeftIndex
(3) PositiveHome LeftIndex (4) PositiveHome RightIndex
(5) NegativeHome RightIndex (6) NegativeHome LeftIndex
(7) RisingHome LeftIndex PositiveStart (8) RisingHome RightIndex PositiveStart
(9) FallingHome LeftIndex PositiveStart (10) FallingHome RightIndex PositiveStart
(11) FallingHome RightIndex NegativeStart (12) FallingHome LeftIndex NegativeStart
(13) RisingHome RightIndex NegativeStart (14) RisingHome LeftIndex NegativeStart
(17) NegativeLimitSwitch (18) PositiveLimitSwitch
(19) PositiveHome NegativeMomentum (20) PositiveHome PositiveMomentum
(21) NegativeHome PositiveMomentum (22) NegativeHome NegativeMomentum
(23) RisingHome NegativeMomentum PositiveStart (24) RisingHome PositiveMomentum PositiveStart
(25) FallingHome NegativeMomentum PositiveStart (26) FallingHome PositiveMomentum PositiveStart
(27) FallingHome PositiveMomentum NegativeStart (28) FallingHome NegativeMomentum NegativeStart
(29) RisingHome PositiveMomentum NegativeStart (30) RisingHome NegativeMomentum NegativeStart
(33) Negative Index (34) Positive Index
(35) Current Position
(36) Negative Hard Stop (37) Positive Hard Stop
📜 Sample Code
