Examples of various ways to home a drive.
Console.WriteLine("📜 Axis Homing: DS402 Drive");
const int offsetIdx = 0x607C;
const int offsetSub = 0x0;
const int offsetSize = 4;
const int offsetVal = 0;
const int methodIdx = 0x6098;
const int methodSub = 0x0;
const int methodSize = 1;
const int methodVal = 24;
const int targetSpeedIdx = 0x6099;
const int targetSpeedSub = 0x1;
const int targetSpeedSize = 4;
const int targetSpeedVal = 2;
const int originSpeedIdx = 0x6099;
const int originSpeedSub = 0x2;
const int originSpeedSize = 4;
const int originSpeedVal = 10;
const int accelIdx = 0x609A;
const int accelSub = 0x0;
const int accelSize = 4;
const int accelVal = 100;
const int CTRL_WORD_PREP_HOMING = 15;
const int CTRL_WORD_START_HOMING = 31;
const int DELAY_MS = 20;
const int STATUS_TARGET_REACHED = 0x400;
const int STATUS_HOMING_ATTAINED = 0x1000;
const int STATUS_HOMING_ERROR = 0x2000;
if (controller.NetworkStateGet() !=
RSINetworkState.RSINetworkStateOPERATIONAL)
controller.SampleWait(DELAY_MS);
bool cancelHome = false;
while ((!cancelHome) && ((statusWord & STATUS_TARGET_REACHED) == 0))
if ((statusWord & STATUS_HOMING_ATTAINED) == STATUS_HOMING_ATTAINED)
Console.WriteLine("Axis homed successfully");
else if ((statusWord & STATUS_HOMING_ERROR) == STATUS_HOMING_ERROR)
Console.WriteLine("Error occurred during homing");
controller.Delete();
Set the axis operation mode.
NetworkNode * NetworkNode
Sets a PDO output directly.
void ServiceChannelWrite(int32_t index, int32_t subIndex, int32_t byteCount, int32_t sdoValue, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault)
Write a number in the SDO.
Get the DS402 status word.
MotionController * rsiControl
RSIOperationMode
DS402 modes of operation.
RSINetworkIndexType
Console.WriteLine("📜 Axis Homing: AKD Drive");
Console.WriteLine("Wrong Axis type. This sample requires an AKD Axis.");
System.Threading.Thread.Sleep(100);
Console.WriteLine("HOME.MOVE command sent");
UInt16 statusWord;
int isHomed = 0;
while (isHomed != 1)
isHomed = statusWord >> 12;
Console.WriteLine("Axis homed");
Set the origin position.
Send a Kollmorgen AKD ASCII command (NodeType must equal KOLLMORGEN_AKD).
RSINodeType TypeGet()
Get the node type, as determined by the Vendor ID and Product Code.
int32_t NumberGet()
Get the axis number.
RSINodeType
Valid Node types.
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
