using RSI.RapidCode.dotNET;
using NUnit.Framework;
using System;
#if DOXYGEN
#else
#endif
[TestFixture]
[Category("Software")]
class InputOutput : SampleAppTestBase
[Ignore("Needs a network with a real node to run, but we want the snippet for docs. At least it's compiled!")]
public void GeneralPurposeIO()
Assert.DoesNotThrow(() =>
const int nodeIndex = 0;
const int digitalInIndex = 0;
const int digitalOutIndex = 0;
const int analogIndex = 0;
public void DedicatedIO()
public void NetworkInputsAndOutputs()
[Test]
public void IOPoints()
const int NODE_INDEX = 0;
const int OUTPUT_INDEX = 0;
Assert.That(output0.
Get(), Is.False,
"The getter function should return a value equal to false");
[Test]
public void IOPointUserBuffer()
const int INPUT_INDEX = 0;
const int OUTPUT_INDEX = 1;
Get(), Is.False,
Get(), Is.True,
"The getter function should return a value equal to true");
Assert.That(input0.
Get(), Is.False,
Assert.That(input0.
Get(), Is.True,
[Test]
public void SingleAxisSyncOutputs()
const int TOTAL_POINTS = 4;
const int EMPTY_CT = -1;
double[] positions = { 1.0, 2.0, 3.0, 4.0 };
double[] times = { 0.5, 0.1, 0.2, 0.4 };
int outputEnableID = 2;
int outputDisableID = 3;
axis.
MovePT(
RSIMotionType.RSIMotionTypePT, positions, times, TOTAL_POINTS, EMPTY_CT,
false,
true);
Get(), Is.EqualTo(
true),
"The output should be triggered");
Get(), Is.EqualTo(
false),
"The output should NOT be triggered");
double CommandPositionGet()
bool AmpEnableGet()
bool HomeSwitchGet()
bool PositiveLimitGet()
uint16_t MotionIdExecutingGet()
bool NegativeLimitGet()
bool AmpFaultGet()
bool DedicatedInGet(RSIMotorDedicatedIn motorDedicatedInNumber)
Read a digital input.
void Set(bool state)
bool Get()
NetworkNode * NetworkNodeGet(int32_t nodeNumber)
NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializ...
Sets a PDO output directly.
int32_t NetworkInputBitOffsetGet(int32_t index)
uint64_t NetworkOutputSentValueGet(int32_t index)
Gets the value sent out over EtherCAT.
int32_t NetworkOutputCountGet()
Get the name of a PDO output.
int32_t NetworkOutputBitOffsetGet(int32_t index)
Get the raw PDO offset for an output.
void DigitalOutSet(int32_t digitalOutNumber, bool state)
Set the state of a digital output.
bool DigitalInGet(int32_t digitalInNumber)
Get the state of a digital input.
int32_t AnalogInGet(int32_t analogChannel)
bool DigitalOutGet(int32_t digitalOutNumber)
Get the state of a digital output.
int32_t AnalogOutGet(int32_t analogChannel)
Get the value of an analog output.
void AnalogOutSet(int32_t analogChannel, int32_t analogValue)
Set the value of an analog output.
Represents an EtherCAT node / SubDevice (Drive, I/O Block, etc) on the network. This class provides a...
bool MotionDoneGet()
RSIMotionType
RSIMotorDedicatedIn
