◆ AxisCountSet() [1/2]
void AxisCountSet ( int32_t axisCount)
AxisCountSet will configure the number of axes processed by the controller.
axisCountA int32_t value to set AxisCount to.
Part of the Information method group.
Axis: Configuration
controller.AxisCountSet(controller.AxisCountGet() + 1); // Configure one additional axis to be used for the phantom axis
int axisNumber = controller.AxisCountGet() - 1; // Set the axis number to the last axis on the network (subtract one because the axes are zero indexed)
axis = controller.AxisGet(axisNumber); // Initialize Axis class
HelperFunctions.CheckErrors(axis); // [Helper Function] Check that the axis has been initialized correctly
axis.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
axis.HardwareNegLimitActionSet(RSIAction.RSIActionNONE); // Set Hardware Negative Limit Action.
axis.HardwarePosLimitActionSet(RSIAction.RSIActionNONE); // Set Hardware Positive Limit Action.
axis.HomeActionSet(RSIAction.RSIActionNONE); // Set Home Action.
axis.SoftwareNegLimitActionSet(RSIAction.RSIActionNONE); // Set Software Negative Limit Action.
axis.SoftwarePosLimitActionSet(RSIAction.RSIActionNONE); // Set Software Positive Limit Action.
const double positionToleranceMax = Double.MaxValue / 10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
axis.PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
axis.PositionToleranceFineSet(positionToleranceMax); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
axis.MotorTypeSet(RSIMotorType.RSIMotorTypePHANTOM); // Set the MotorType to phantom
AxisCountGet
By default, this will also set the number of allocated/enabled MotionSupervisors, Filters, and Motors
AxisConfig.cs, Compensator.cs, HelperFunctions.cs, MultiAxisMotion.cs, Recorder.cs, SampleAppsHelper.h, UserLimit.cs, UserLimitCommandPositionDirect.cs, _setup.cs, and axis-config-phantom-axis.cs.
