◆ HomeActionSet()
void HomeActionSet ( RSIAction action)
HomeActionSet Sets the action that will occur when the Home Limit triggers.
This is NOT the action that occurs during master based Homing.
actionAction taken on Home trigger. A ::RSIAction value.
Note:
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsienums.h:621
Definition rsienums.h:1256
Go to axis screen->Limits & Actions. In image below, HomeActionSet sets the action type shown in the Home Fault box. It is currently set to STOP.
HomeActionGet HomeBehaviorSet
_helpers.cs, axis-config-phantom-axis.cs, config.h, and phantom-axis.cpp.
