MotionHoldReleasedBySoftwareAddress.cpp
21
22#include <thread>
23#include "rsi.h" // Import our RapidCode Library.
24#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
25#include "SampleApps.h"
26
27using namespace RSI::RapidCode; // Import the RapidCode namespace
28
30int MotionHoldReleasedBySoftwareAddress::Run()
31{
33 /* CONSTANTS */
34 // *NOTICE* The following constants must be configured before attempting to run with hardware.
35
36 // Axis configuration parameters
37 const int AXIS_COUNT = 1;
38 const int AXIS_NUMBER = 0;
39
40 const double USER_UNITS = 1048576;
41
42 // Index for the address in the user buffer to use for the motion hold
43 const int USER_BUFFER_INDEX = 0;
44
45 // Motion parameters
46 const double MOTION_DISTANCE = 0.25;
47
48 const std::chrono::duration HOLD_TIME = std::chrono::milliseconds(2000);
49
50 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
51 USE_HARDWARE = false;
52
53 // The rmpPath only needs to be set if the project directory is different than the rapid setup directory.
54 // *NOTICE* When setting the rmpPath, be sure to uncomment the rmpPath arguement in MotionController::CreateFromSoftware() in the Run() function.
55 const char rmpPath[] = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)"
56
57 /* SAMPLE APP BODY */
58
59 // Initialize MotionController class.
60 MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
61 SampleAppsHelper::CheckErrors(controller); // [Helper Function] Check that the axis has been initialize correctly.
62
63 // Setup the controller for the appropriate hardware configuration.
64 if (USE_HARDWARE)
65 {
67 }
68 else
69 {
70 SampleAppsHelper::SetupControllerForPhantoms(controller, AXIS_COUNT, { AXIS_NUMBER });
71 }
72
73 try
74 {
75 Axis* axis = controller->AxisGet(AXIS_NUMBER); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
76 SampleAppsHelper::CheckErrors(axis); // [Helper Function] Check that the axis has been initialize correctly.
77
78 // GET AXIS READY
79 axis->UserUnitsSet(USER_UNITS); // Specify the counts per Unit.
80 axis->PositionSet(0); // Make sure motor starts at position 0 every time.
81 axis->ErrorLimitTriggerValueSet(1); // Set the position error trigger value
82 axis->Abort(); // If there is any motion happening, abort it.
83 axis->ClearFaults(); // Clear faults.>
84 axis->AmpEnableSet(true); // Enable the motor.
85
86 // GET AN AVAILABLE MEMORY ADDRESS
87 uint64_t userBufferAddress = controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, USER_BUFFER_INDEX);
88
89 // SET MOTION HOLD ON AVAILABLE SOFTWARE ADDRESS
90 axis->MotionHoldTypeSet(RSIMotionHoldType::RSIMotionHoldTypeCUSTOM); // Use TypeCUSTOM to hold execution based on a particular bit turning ON or OFF.
91 axis->MotionHoldUserAddressSet(userBufferAddress); // Specify the available hostAddress . This address' value will be used to evaluate the motion hold condition.
92 axis->MotionHoldUserMaskSet(0x1); // Specify the bit you want to mask/watch from the MotionHoldUserAddressSet' address value (this evaluates using a logic AND)
93 axis->MotionHoldUserPatternSet(0x1); // Specify the bit value that will release the motion hold. (When this value is met, motion hold will be released)
94
95 // Check the condition to be false at first
96 if (controller->MemoryGet(userBufferAddress) != 0x0) // Check Available host address value is mask to be false (in this case 0x0)
97 {
98 controller->MemorySet(userBufferAddress, 0x0); // if not, mask it to false value/condition (in this case 0x0)
99 }
100
101 // COMMAND MOTION (NO HOLD YET)
102 printf("\nCommanding Motion...\n");
103 axis->MoveRelative(MOTION_DISTANCE); // Command simple relative motion. (This motion will have no HOLD)
104
105 // SET MOTION HOLD
106 printf("\nSetting Motion Hold...\n");
107 axis->MotionAttributeMaskOnSet(RSIMotionAttrMask::RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask ON. (This initializes the HOLD on a particular motion)
108
109 // COMMAND MOTION AGAIN (MOTION WILL BE HELD)
110 printf("Commanding Motion...\n");
111 axis->MoveRelative(MOTION_DISTANCE); // Command simple relative motion. (This motion will be HOLD by the condition above)
112 std::this_thread::sleep_for(HOLD_TIME); // Sleep for 3 second before releasing motion hold.
113
114 // RELEASE MOTION HOLD (MOTION WILL START)
115 printf("Releasing Motion Hold...\n");
116 controller->MemorySet(userBufferAddress, 0x1); // Release Motion Hold by specifying the host address value to SET Condition (in this case 0x10000)
117 axis->MotionDoneWait(); // Wait for motion to be done
118 controller->MemorySet(userBufferAddress, 0x0); // Specify host address value back to false value/condition (in this case 0x0)
119
120 // CLEAR MOTION HOLD
121 printf("\nClearing Motion Hold...\n");
122 axis->MotionAttributeMaskOffSet(RSIMotionAttrMask::RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask OFF. (This will clear any motion HOLDS that were set on this Axis)
123
124 // COMMAND MOTION AGAIN (NO HOLD)
125 printf("Commanding Motion...\n");
126 axis->MoveRelative(-2 * MOTION_DISTANCE); // This motion will have no HOLD since the previous line has set the motion attribute mask OFF.
127 axis->MotionDoneWait(); // Wait for Motion to be completed.
128
129 // Abort and Clear Faults
130 axis->Abort();
131 axis->ClearFaults();
132 }
133 catch (RsiError const& err)
134 {
135 printf("%s\n", err.text); // If there are any exceptions/issues this will be printed out.
136 return -1;
137 }
138 controller->Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
139 return 0;
141}
int32_t MemoryGet(uint64_t address)
Read controller memory.
Set the motion hold type.
@ RSIControllerAddressTypeUSER_BUFFER
First location in User Buffer.
Definition rsienums.h:408
@ RSIMotionAttrMaskHOLD
Prevents the move from executing until a specific trigger condition is met. See MotionHold methods.
Definition rsienums.h:1118
