Homing.cs
50using RSI.RapidCode.dotNET; // Import our RapidCode Library.
51using NUnit.Framework;
52using System;
53
55class Homing : SampleAppTestBase
56 {
57 public void MasterBasedHoming()
58 {
59 //@[MasterBasedHoming]
60 axis.HardwareNegLimitActionSet(RSIAction.RSIActionSTOP); // Neg Limit action set to STOP.
61 axis.HomeMethodSet(RSIHomeMethod.RSIHomeMethodImprovedFALLING_HOME_NEGATIVE_START_POSITIVE_MOMENTUM); // Set the method to be used for homing.
62 axis.HomeVelocitySet(Constants.VELOCITY); // Set the home velocity.
63 axis.HomeSlowVelocitySet(Constants.VELOCITY / 10); // Set the slow home velocity. (used for final move, if necessary)
64 axis.HomeAccelerationSet(Constants.ACCELERATION); // Set the acceleration used for homing.
65 axis.HomeDecelerationSet(Constants.DECELERATION); // Set the deceleration used for homing.
66 axis.HomeOffsetSet(0.5); // HomeOffsetSet sets the position offset from the home (zero) position.
67
68 axis.Home(); // Execute the homing routine.
69
70 if (axis.HomeStateGet() == true) // HomeStateGet returns true if the Axis is homed.
71 {
72 Console.WriteLine("Homing successful\n");
73 }
74
75 axis.ClearFaults(); // Clear faults created by homing.
76 axis.AmpEnableSet(false); // Disable the motor.
77 //@[MasterBasedHoming]
78 }
79
80 public void HomingWithAKDdrive()
81 {
82 //@[HomingWithAKDdrive]
83
84 // 1. READY DRIVE
85 axis.OperationModeSet(RSIOperationMode.RSIOperationModeHOMING_MODE); // Mode of Operation set to Homing Mode.
86 axis.NetworkNode.AKDASCIICommand("DRV.OPMODE 2"); // Sets the drive operation mode (0 - current | 1 = velocity | 2 = position).
87 axis.NetworkNode.AKDASCIICommand("HOME.AUTOMOVE 0"); // 0 = Disabled | 1 = Homing starts when drive is enabled.
88
89 // Make sure you know your motor's position, velocity, and acceleration units before you send any values.
90
91 // 2. SET YOUR LIMIT SWITCHES
92 axis.NetworkNode.AKDASCIICommand("DIN5.MODE 18"); // Sets the digital input modes. - DI5 is now our Positive Limit Switch.
93 axis.NetworkNode.AKDASCIICommand("DIN5.INV 1"); // Sets the indicated polarity of a digital input mode. - DI5 is now active when Low.
94 axis.NetworkNode.AKDASCIICommand("DIN6.MODE 19"); // Sets the digital input modes. - DI6 is now our Negative Limit Switch.
95 axis.NetworkNode.AKDASCIICommand("DIN6.INV 1"); // Sets the indicated polarity of a digital input mode. - DI6 is now active when Low.
96
97 // 3. CONFIGURE DRIVE HOMING PARAMETERS
98 axis.NetworkNode.AKDASCIICommand("HOME.MODE 1"); // Selects the homing method. MODE1 = Find limit input
99 axis.NetworkNode.AKDASCIICommand("HOME.V 20");
100 axis.NetworkNode.AKDASCIICommand("HOME.ACC 200");
101 axis.NetworkNode.AKDASCIICommand("HOME.DEC 200");
102 axis.NetworkNode.AKDASCIICommand("HOME.DIR 0"); // Sets homing direction (0 = negative | 1 = positive)
103 axis.NetworkNode.AKDASCIICommand("HOME.P 0");
104 axis.NetworkNode.AKDASCIICommand("HOME.DIST 0");
105 axis.NetworkNode.AKDASCIICommand("HOME.MAXDIST 0");
106 axis.NetworkNode.AKDASCIICommand("HOME.IPEAK");
107
108 // 4. READY AXIS
109 axis.ErrorLimitActionSet(RSIAction.RSIActionNONE); //Set the action to none so we don't get a position error while the drive is in control.
110 axis.Abort(); // Disable axis.
111 axis.ClearFaults(); // Clear any faults.
112 axis.AmpEnableSet(true); // Enable the axis.
113 System.Threading.Thread.Sleep(100); // Allow time for amp enable
114
115 // 5. START HOMING
116 axis.NetworkNode.AKDASCIICommand("HOME.MOVE"); // Starts a homing procedure; active in opmode 2 (position) only.
117 Console.WriteLine("HOME.MOVE");
118
119 // 6. CHECK IF HOMING IS DONE
120 UInt16 statusWordValue;
121 int isHomedvalue = 0;
122 int axisIndex = axis.NumberGet();
123
124 while (isHomedvalue != 1) // When isHomedValue = 1, homing has finished.
125 {
126 statusWordValue = axis.NetworkNode.StatusWordGet(axisIndex);
127 isHomedvalue = statusWordValue >> 12; // Get the 12th bit only. This bit tells us homing is done when it goes HIGH.
128 }
129
130 Console.WriteLine("Axis homed.");
131
132 // 7. CLEAN UP
133 axis.OriginPositionSet(0.0);//Set the origin to 0, otherwise repeated use will not result in Rapidcode reporting 0 at the found home position.
134 axis.Abort(); // Disable the axis.
135 axis.OperationModeSet(RSIOperationMode.RSIOperationModeINTERPOLATED_POSITION_MODE); // Mode of Operation Restore
136 axis.ErrorLimitActionSet(RSIAction.RSIActionABORT);// Restore the position error action to whatever you want it to be.
137
138 //@[HomingWithAKDdrive]
139
140 }
141
142 public void HomingWithDS402drive()
143 {
144 //@[HomingWithDS402drive]
145
146 // Constants
147 const int AXIS_NUMBER = 0; // Specify which axis/motor to control.
148
149 // Homing Offset.
150 const int offsetIndex = 0x607C;
151 const int offsetSubindex = 0x0;
152 const int offsetByteSize = 4;
153 const int offsetValue = 0;
154
155 // Home Method
156 const int methodIndex = 0x6098;
157 const int methodSubindex = 0x0;
158 const int methodByteSize = 1;
159 const int methodValue = 24;
160
161 // Speed To Switch
162 const int targetSpeedIndex = 0x6099;
163 const int targetSpeedSubindex = 0x1;
164 const int targetSpeedByteSize = 4;
165 const int targetSpeedValue = 2;
166
167 // Speed to Zero
168 const int originSpeedIndex = 0x6099;
169 const int originSpeedSubindex = 0x2;
170 const int orignSpeedByteSize = 4;
171 const int originSpeedValue = 10;
172
173 // Homing Acceleration
174 const int accelerationIndex = 0x609A;
175 const int accelerationSubindex = 0x0;
176 const int accelerationByteSize = 4;
177 const int accelerationValue = 100;
178
179 //Desired DS402 Enabled Output.
180 const int CONTROL_WORD_TO_PREP_HOMING = 15;
181 const int CONTROL_WORD_TO_START_HOMING = 31;
182 const int ACCEPTABLE_DELAY_IN_MS = 20;
183 const int STATUS_WORD_TARGET_REACHED_BIT = 0x400; // Status Bit 10 (0x400) indicates Target Reached (Homing is Complete).
184 const int STATUS_WORD_HOMING_ATTAINED_BIT = 0x1000; // Status Bit 12 (0x1000) indicates Homing Attained (Homing is Successful).
185 const int STATUS_WORD_HOMING_ERROR_BIT = 0x2000; // Status Bit 13 (0x2000) indicates Homing Error (Homing ran into a problem).
186
187 int axisControlWordIndex = (int)axis.NetworkIndexGet(RSINetworkIndexType.NetworkIndexTypeCONTROL_WORD_INDEX);
188
189 // CONFIGURE (Writing to SDOs)
190 axis.NetworkNode.ServiceChannelWrite(offsetIndex, offsetSubindex, offsetByteSize, offsetValue); // Home Offset
191 axis.NetworkNode.ServiceChannelWrite(methodIndex, methodSubindex, methodByteSize, methodValue); // Home Method (Home type)
192 axis.NetworkNode.ServiceChannelWrite(targetSpeedIndex, targetSpeedSubindex, targetSpeedByteSize, targetSpeedValue); // Home Speed during search for switch
193 axis.NetworkNode.ServiceChannelWrite(originSpeedIndex, originSpeedSubindex, orignSpeedByteSize, originSpeedValue); // Home Speed during search for zero
194 axis.NetworkNode.ServiceChannelWrite(accelerationIndex, accelerationSubindex, accelerationByteSize, accelerationValue); // Home acceleration
195
196 axis.rsiControl.NetworkOutputOverrideValueSet(axisControlWordIndex, CONTROL_WORD_TO_PREP_HOMING); // Control Word should be 15 before Switching to Homing Mode.
197 axis.rsiControl.NetworkOutputOverrideSet(axisControlWordIndex, true); // Override Control Word.
198 controller.SampleWait(ACCEPTABLE_DELAY_IN_MS);
199 // Delay to give transitions time -or- setup something more complex to ensure drive is in the appropriate state.
200
201 axis.OperationModeSet(RSIOperationMode.RSIOperationModeHOMING_MODE);
202 controller.SampleWait(ACCEPTABLE_DELAY_IN_MS);
203
204 // HOME
205 axis.rsiControl.NetworkOutputOverrideValueSet(axisControlWordIndex, CONTROL_WORD_TO_START_HOMING); // Start Homing.
206 controller.SampleWait(ACCEPTABLE_DELAY_IN_MS); // Delay to give transitions time -or- setup something more complex to ensure drive is in the appropriate state.
207
208 UInt16 statusWordValue; // Takes the axis index. This will return the status word value.
209 bool cancelHome = false;
210
211 statusWordValue = axis.NetworkNode.StatusWordGet(AXIS_NUMBER);
212 while ((!cancelHome) && ((statusWordValue & STATUS_WORD_TARGET_REACHED_BIT) == 0)) // When Status Word Indicates Target Reached (Success or Fail) or external evaluator (cancelHome)
213 {
214 //A timeout that sets cancelHome would be a good idea for this while loop.
215 statusWordValue = axis.NetworkNode.StatusWordGet(AXIS_NUMBER); //Update.
216 //A short sleep or wait is appropriate so you can't spamming this call.
217 }
218
219 // 4. EVALUATE HOMING SUCCESS
220 if ((statusWordValue & STATUS_WORD_HOMING_ATTAINED_BIT) == STATUS_WORD_HOMING_ATTAINED_BIT)
221 {
222 Console.WriteLine("Axis homed.");
223 }
224 else if ((statusWordValue & STATUS_WORD_HOMING_ERROR_BIT) == STATUS_WORD_HOMING_ATTAINED_BIT)
225 {
226 Console.WriteLine("Error Occured during homing.");
227 }
228
229 //5. CLEAN UP
230 axis.AmpEnableSet(false); // Disable the axis.
231 axis.ClearFaults();
232 axis.rsiControl.NetworkOutputOverrideSet(axisControlWordIndex, false);
233 // Restore the mode of operation to the control mode you want to run in. For most, this will be RSIOperationModeCYCLIC_SYNCHRONOUS_POSITION_MODE.
234 axis.OperationModeSet(RSIOperationMode.RSIOperationModeCYCLIC_SYNCHRONOUS_POSITION_MODE);
235
236
237 //@[HomingWithDS402drive]
238 }
239
240 public void CustomHome()
241 {
242 //@[CustomHome]
243
244 // user defined options
245 //const RSIMotorDedicatedIn CAPTURE_SOURCE = RSIMotorDedicatedIn.RSIMotorDedicatedInHOME;
246
247 const int HOME_LIMIT_NETWORK_INDEX = 99; //You may want to discover this rather than hard code it.
248 const int HOME_LIMIT_SIG_BIT = 0;
249 const int LongTime = 15000;
250
251 var homeLimitAddress = controller.NetworkInputAddressGet(HOME_LIMIT_NETWORK_INDEX);
252 axis.HomeLimitCustomConfigSet(homeLimitAddress, HOME_LIMIT_SIG_BIT);
253 axis.HomeActionSet(RSIAction.RSIActionSTOP);
254
255 // Ready Axis
256 axis.Abort();
257 axis.ClearFaults();
258 axis.AmpEnableSet(true);
259
260 // commanding a velocity move. This program assumes that the Custom Home will trigger at some point.
261 axis.MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
262
263 //wait (sleep) until motion done interrupt occurs
264 Boolean done = false;
265 while (!done)
266 {
267 RSIEventType eventType = controller.InterruptWait(LongTime);
268 switch (eventType)
269 {
270 case RSIEventType.RSIEventTypeMOTION_DONE:
271 done = true;
272 break;
273 case RSIEventType.RSIEventTypeTIMEOUT:
274 done = true;
275 break;
276 default:
277 break;
278 }
279 }
280
281 if ((controller.NetworkInputValueGet(HOME_LIMIT_NETWORK_INDEX) & HOME_LIMIT_SIG_BIT) > 0) //On Home Limit
282 {
283 axis.HomeStateSet(true);
284 }
285 else
286 {
287 //Evaluate why we aren't on custom home.
288 }
289
290 // setup Home Action (the home action will not trigger)
291 axis.HomeActionSet(RSIAction.RSIActionNONE);
292
293 axis.ClearFaults();
294 axis.AmpEnableSet(false);
295 //@[CustomHome]
296 }
297 }
Get the Network Index associated with a DS402 Axis Feature.
Set the origin position.
Set the axis operation mode.
NetworkNode * NetworkNode
Definition rsi.h:5819
void Home()
void HomeStateSet(bool homed)
Set the home state.
bool HomeStateGet()
Get the home state.
void HomeLimitCustomConfigSet(uint64_t address, int32_t bitIndex)
Sets a PDO output directly.
uint64_t NetworkInputAddressGet(int32_t index)
Send a Kollmorgen AKD ASCII command (NodeType must equal KOLLMORGEN_AKD)
void ServiceChannelWrite(int32_t index, int32_t subIndex, int32_t byteCount, int32_t sdoValue)
Write a number in the SDO.
Get the DS402 status word.
int32_t NumberGet()
Get the axis number.
MotionController * rsiControl
Definition rsi.h:4329
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:965
Definition rsienums.h:1112
RSIOperationMode
DS402 modes of operation.
Definition rsienums.h:1328
RSINetworkIndexType
Network index types for Axis.
Definition rsienums.h:1362
