Motion: Hold
Learn how to use motion hold in C#.
In this page:
📜 Motion Hold: via Position
Learn how to use Motion Hold 📖 based on another axis reaching a specified position. One axis controls when another axis's motion is released, useful for synchronized operations.
/* This sample demonstrates how to hold motion based on another axis reaching a specified position.
Uses one axis to control when another axis's motion is released, useful for synchronized operations.
Console.WriteLine("📜 Motion Hold: via Position");
const double TRIGGER_POSITION = 1;
const int HOLDING_AXIS_TARGET = 2;
// get axes
Axis holdingAxis = controller.AxisGet(Constants.AXIS_0_INDEX);
Helpers.CheckErrors(holdingAxis);
Axis movingAxis = controller.AxisGet(Constants.AXIS_1_INDEX);
// configure phantom axes
Helpers.PhantomAxisReset(holdingAxis);
holdingAxis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
// configure motion hold - holdingAxis will be held until movingAxis reaches trigger position
bool movingAxisIsHardware = movingAxis.MotorTypeGet() != RSIMotorType.RSIMotorTypePHANTOM;
RSIMotionHoldType motionHoldType = movingAxisIsHardware ?
RSIMotionHoldType.RSIMotionHoldTypeAXIS_ACTUAL_POSITION : // AXIS_ACTUAL_POSITION for hardware axes
RSIMotionHoldType.RSIMotionHoldTypeAXIS_COMMAND_POSITION; // AXIS_COMMAND_POSITION for phantom axes
holdingAxis.MotionHoldTypeSet(motionHoldType);
holdingAxis.MotionHoldAxisNumberSet(movingAxis.NumberGet()); // specify which axis position to monitor
holdingAxis.MotionHoldAxisPositionSet(TRIGGER_POSITION); // position that will release the hold
holdingAxis.MotionHoldAxisLogicSet(RSIUserLimitLogic.RSIUserLimitLogicGE); // release when position >= trigger position
// enable motion hold and command motion
holdingAxis.MotionAttributeMaskOnSet(RSIMotionAttrMask.RSIMotionAttrMaskHOLD);
holdingAxis.MoveRelative(HOLDING_AXIS_TARGET); // this motion will be held
Console.WriteLine($"\tHolding axis commanded to move to {HOLDING_AXIS_TARGET}, but motion is held");
// move the trigger axis to release the hold
movingAxis.MoveRelative(MOVING_AXIS_TARGET);
Console.WriteLine($"\tMoving axis to {MOVING_AXIS_TARGET} to release hold...");
movingAxis.MotionDoneWait();
holdingAxis.MotionDoneWait();
Console.WriteLine($"\tHolding axis final position: {holdingAxis.CommandPositionGet()} (expected: {HOLDING_AXIS_TARGET})");
Console.WriteLine($"\tMoving axis final position: {movingAxis.CommandPositionGet()} (expected: {MOVING_AXIS_TARGET})");
Helpers.AbortMotionObject(holdingAxis);
const int AXIS_1_INDEX
Definition _constants.cs:21
RSIMotorType MotorTypeGet()
Get the motor type.
Sets the Axis position.
Set the motion hold type.
int32_t NumberGet()
Get the axis number.
RSIUserLimitLogic
Definition rsienums.h:771
RSIMotorType
Motor Type.
Definition rsienums.h:1452
RSIMotionAttrMask
Definition rsienums.h:1201
RSIMotionHoldType
Definition rsienums.h:1236
📜 Motion Hold: via Digital Input
Learn how to use Motion Hold 📖 triggered by a digital input signal. Motion is held until the specified digital input pattern is detected.
// configure axis
axis.MoveRelative(3);
// disable motion hold
Definition rsienums.h:621
📜 Motion Hold: via Address
Learn how to use Motion Hold 📖 controlled by a software address. Motion is held until a specific bit pattern is written to a memory location.
/* This sample demonstrates how to hold motion using a software address (memory location).
Motion is held until a specific bit pattern is written to the address, useful for custom logic.
using System.Threading;
Console.WriteLine("📜 Motion Hold: via Address");
const int MOVE_DISTANCE = 2;
// configure phantom axis
axis.PositionSet(0);
// get available software address from user buffer
ulong softwareAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 1);
// configure motion hold on software address
axis.MotionHoldUserAddressSet(softwareAddress); // specify the host address
axis.MotionHoldUserMaskSet(0x1); // specify the bit to watch (logic AND)
axis.MotionHoldUserPatternSet(0x1); // bit value that will release the motion hold
// ensure condition is false initially
if (controller.MemoryGet(softwareAddress) != 0x0)
controller.MemorySet(softwareAddress, 0x0);
axis.MoveRelative(MOVE_DISTANCE);
Console.WriteLine($"\tFirst motion commanded to move {MOVE_DISTANCE} (held)");
Thread.Sleep(100);
double positionWhileHeld = axis.CommandPositionGet();
Console.WriteLine($"\tPosition while held: {positionWhileHeld} (should be 0)");
// release motion hold by setting the address
controller.MemorySet(softwareAddress, 0x1);
Console.WriteLine("\tReleasing hold via address...");
controller.MemorySet(softwareAddress, 0x0); // reset to false
Console.WriteLine($"\tPosition after release: {axis.CommandPositionGet()} (expected: {MOVE_DISTANCE})");
// command motion again - will be held again
Console.WriteLine($"\tSecond motion commanded to move {MOVE_DISTANCE} (held)");
Thread.Sleep(100);
// release motion hold again
Console.WriteLine($"\tThird motion commanded to move {MOVE_DISTANCE} (no hold)");
Console.WriteLine($"\tFinal position: {axis.CommandPositionGet()} (expected: {MOVE_DISTANCE * 3})");
// clean up
Definition _constants.cs:26
double CommandPositionGet()
