Learn how to use Math Blocks for calculations and data processing.
- Warning
In this page:
📜 Math Blocks: Calculate Acceleration from Velocity
Learn how to use Math Blocks to calculate acceleration from velocity data for motion analysis and control applications.
const int NUM_AXES = 1;
const int AXIS_INDEX = 0;
const double VELOCITY = 1.0;
const double ACCELERATION = 0.123;
int initialMathBlockCount = -1;
int exitCode = -1;
initialMathBlockCount = controller->MathBlockCountGet();
const int subtractionMathBlockIndex = initialMathBlockCount;
const int previousVelocityMathBlockIndex = initialMathBlockCount + 1;
controller->MathBlockCountSet(initialMathBlockCount + 2);
controller->MemoryDoubleSet(userBufferAddr0, 1.0);
controller->MathBlockConfigSet(subtractionMathBlockIndex, subtractionConfig);
controller->MathBlockConfigSet(previousVelocityMathBlockIndex, previousVelocityConfig);
controller->SampleWait(1);
controller->SampleWait(10);
double calculatedVelocityDelta = controller->MathBlockProcessValueGet(subtractionMathBlockIndex).Double;
double calculatedAcceleration = calculatedVelocityDelta * controller->SampleRateGet() * controller->SampleRateGet() / axis->
UserUnitsGet();
std::cout << "Calculated acceleration from MathBlock: " << calculatedAcceleration << std::endl;
if (std::abs(calculatedAcceleration - ACCELERATION) <= 0.000001)
std::cout << "The MathBlock is calculating the Axis' acceleration by subtracting previous velocity from current velocity." << std::endl;
exitCode = 0;
std::cerr << "Error: The calculated acceleration does not match the expected value" << std::endl;
exitCode = -1;
exitCode = -1;
if (initialMathBlockCount != -1) { controller->MathBlockCountSet(initialMathBlockCount); }
controller->Delete();
Source: calculate-acceleration-from-velocity.cpp
📜 Math Blocks: Difference of Position User Limit
Learn how to use Math Blocks to monitor position differences and implement user limits for advanced motion control and safety applications.
const int NUM_AXES = 2;
const int AXIS_X_INDEX = 0;
const int AXIS_Y_INDEX = 1;
const double MAX_POSITION_DIFFERENCE = 0.5;
const int USER_LIMIT_DURATION = 0;
const double RELATIVE_POSITION = 2 * MAX_POSITION_DIFFERENCE;
const double VELOCITY = 1;
const double ACCELERATION = 10;
const double DECELERATION = 10;
const double JERK_PCT = 0;
int initialUserLimitCount = -1;
int exitCode = -1;
initialUserLimitCount = controller->UserLimitCountGet();
const int multiAxisIndex = controller->AxisCountGet();
controller->MotionCountSet(multiAxisIndex + 1);
const int userLimitIndex = initialUserLimitCount;
controller->UserLimitCountSet(initialUserLimitCount + 1);
const int mathBlockIndex = initialMathBlockCount;
controller->MathBlockCountSet(initialMathBlockCount + 1);
Axis *axisX = controller->AxisGet(AXIS_X_INDEX);
Axis *axisY = controller->AxisGet(AXIS_Y_INDEX);
MultiAxis *multiAxis = controller->LoadExistingMultiAxis(multiAxisIndex);
controller->MathBlockConfigSet(mathBlockIndex, mathBlockConfig);
std::cout << "MathBlock configured to subtract the position of the second axis from the position of the first axis." << std::endl;
uint64_t mathBlockProcessValueAddress =
controller->UserLimitConditionSet(
controller->UserLimitConfigSet(
USER_LIMIT_DURATION
std::cout << "UserLimit configured to trigger when the absolute position difference is greater than " << MAX_POSITION_DIFFERENCE
<< " and abort motion." << std::endl;
std::cout << "Moving the axes to trigger the UserLimit..." << std::endl;
axisX->
MoveRelative(RELATIVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PCT);
controller->UserLimitDisable(userLimitIndex);
std::cout << "Both axes are in the error state after the UserLimit triggered (This is the intended behavior)." << std::endl;
exitCode = 0;
std::cout << "Error: The axes should be in an error state after the UserLimit triggers, but they are not." << std::endl;
std::cout <<
"First Axis State: " << RSIStateMap.at(axisX->
StateGet()) << std::endl;
std::cout <<
"Second Axis State: " << RSIStateMap.at(axisY->
exitCode = -1;
exitCode = -1;
if (initialUserLimitCount != -1) { controller->UserLimitCountSet(initialUserLimitCount); }
Source: difference-of-position-user-limit.cpp
