◆ InterruptWait()
RSIEventType InterruptWait ( int32_t milliseconds)
inherited
InterruptWait suspends the current thread until an interrupt arrives from the controller. This is commonly used while waiting for specific interrupts such as Motion Done, velocity reached, or recorder done. Please see RSIEventType for options. You can specify an extact wait time or use RSIWait.
millisecondsMilliseconds to wait -or- an RSIWait value to return immediately or wait forever.
(RSIEventType) Event which takes place or RSIEventTypeTIMEOUT event after time elapses.
User Limits
// Constants
const int AXIS_COUNT = 1;
const int USER_LIMIT_FIRST = 0; // Specify which user limit to use.
const RSIUserLimitLogic LOGIC = RSIUserLimitLogic.RSIUserLimitLogicEQ; // Logic for input value comparison.
const RSIUserLimitTriggerType TRIGGER_TYPE = RSIUserLimitTriggerType.RSIUserLimitTriggerTypeSINGLE_CONDITION; // Choose the how the condition (s) should be evaluated.
const RSIAction ACTION = RSIAction.RSIActionTRIGGERED_MODIFY; // Choose the action you want to cause when the User Limit triggers.
const int DURATION = 0; // Enter the time delay before the action is executed after the User Limit has triggered.
const bool ONE_SHOT = true; // if true, User Limit will only trigger ONCE
// User Limit Interrupt constants
const int TC_COMMAND_POSITION_INDEX = 2;
const int TC_ACTUAL_POSITION_INDEX = 3;
public void UserLimitCommandPositionDirectSet()
// Some Necessary Pre User Limit Configuration
controller.AxisCountSet(AXIS_COUNT);
controller.UserLimitCountSet(USER_LIMIT_COUNT); // Set the amount of UserLimits that you want to use.
axis = CreateAndReadyAxis(Constants.AXIS_NUMBER); // Initialize your axis object.
axis.TriggeredModifyDecelerationSet(Constants.DECELERATION);
axis.TriggeredModifyJerkPercentSet(Constants.JERK_PERCENT);
// USER LIMIT CONDITION 0 (trigger on digital input)
controller.UserLimitConditionSet(USER_LIMIT_FIRST, 0, LOGIC, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeDIGITAL_INPUTS), 0x400000, 0x400000); // Set your User Limit Condition (1st step to setting up your user limit)
// controller.UserLimitOutputSet(USER_LIMIT_FIRST, RSIDataType.RSIDataTypeDOUBLE, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTC_ACTUAL_POSITION), controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER), true);
controller.UserLimitConfigSet(USER_LIMIT_FIRST, TRIGGER_TYPE, ACTION, axis.NumberGet(), DURATION, ONE_SHOT); // Set your User Limit Configuration. (2nd step to setting up your user limit)
// CONDITION 0 (wait for first user limit to trigger)
controller.UserLimitConditionSet(USER_LIMIT_SECOND, 0, RSIUserLimitLogic.RSIUserLimitLogicEQ, controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSERLIMIT_STATUS, USER_LIMIT_FIRST), 1, 1);
// CONDITION 1 (AND wait for Axis command velcity = 0.0)
controller.UserLimitConditionSet(USER_LIMIT_SECOND, 1, RSIUserLimitLogic.RSIUserLimitLogicEQ, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_VELOCITY), 0.0);
// OUTPUT (copy value from UserBuffer to TC.CommandPosition when trigered)
//controller.UserLimitOutputSet(USER_LIMIT_SECOND, RSIDataType.RSIDataTypeDOUBLE, controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER), axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTC_COMMAND_POSITION), true);
controller.UserLimitConfigSet(USER_LIMIT_SECOND, RSIUserLimitTriggerType.RSIUserLimitTriggerTypeCONDITION_AND, RSIAction.RSIActionNONE, 0, 0, ONE_SHOT);
// get the Axis moving
axis.ClearFaults();
axis.AmpEnableSet(true);
axis.MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
ConfigureUserLimitInterrupts(USER_LIMIT_FIRST);
ConfigureUserLimitInterrupts(USER_LIMIT_SECOND);
// wait for (and print) interrupts
WaitForInterrupts();
public void ConfigureUserLimitInterrupts(int userLimitIndex)
controller.UserLimitInterruptUserDataAddressSet(userLimitIndex, COMMAND_POSITION_INDEX, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION));
controller.UserLimitInterruptUserDataAddressSet(userLimitIndex, ACTUAL_POSITION_INDEX, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeACTUAL_POSITION));
public void WaitForInterrupts()
bool done = false;
int timeout_millseconds = 10;
while (!done)
RSIEventType eventType = controller.InterruptWait(timeout_millseconds);
Console.WriteLine("IRQ: " + eventType.ToString() + " at sample " + controller.InterruptSampleTimeGet());
switch (eventType)
Console.WriteLine("UserLimit " + controller.InterruptSourceNumberGet());
Console.WriteLine("CmdPos: " + controller.InterruptUserDataDoubleGet(COMMAND_POSITION_INDEX));
Console.WriteLine("ActPos: " + controller.InterruptUserDataDoubleGet(ACTUAL_POSITION_INDEX));
Console.WriteLine("TC.CmdPos: " + controller.InterruptUserDataDoubleGet(TC_COMMAND_POSITION_INDEX));
Console.WriteLine("TC.ActPos: " + controller.InterruptUserDataDoubleGet(TC_ACTUAL_POSITION_INDEX));
done = true;
default:
InterruptWait will return logged Interrupts until there are none in the FIFO buffer. Then it begin waiting with a timeout for the next.
RapidCodeMotion::InterruptEnableSet, MotionController::InterruptEnableSet, RapidCodeMotion::InterruptWake, MotionController::InterruptWake
ControllerInterrupts.cpp, Homing.cs, UserLimit.cs, and UserLimitCommandPositionDirect.cs.
