MultiaxisMotion.cpp
26
27#include "rsi.h" // Import our RapidCode Library.
28#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
29#include <conio.h>
30#include "SampleApps.h"
31
32using namespace RSI::RapidCode; // Import the RapidCode namespace
33
34/*This function will print all the results to the screen*/
36void PrintResult(Axis* axisX, Axis* axisY)
37{
38 printf("Motion Done \n AxisX position-> Commanded: %f \tActual: %f\n",
39 axisX->CommandPositionGet(),
40 axisX->ActualPositionGet());
41
42 printf(" AxisY position-> Commanded: %f \tActual: %f\n",
43 axisY->CommandPositionGet(),
44 axisY->ActualPositionGet());
45}
46
48int MultiaxisMotion::Run()
49{
51 /* CONSTANTS */
52 // *NOTICE* The following constants must be configured before attempting to run with hardware.
53
54 // Axis configuration parameters
55 const int AXIS_COUNT = 2;
56 const int AXIS_X = 0;
57 const int AXIS_Y = 1;
58
59 const int MOTION_COUNT = 1;
60
61 const double USER_UNITS = 1048576;
62
63 // Motion parameters
64 const double START_POSITION[AXIS_COUNT] = { 0, 0 };
65 const double END_POSITION[AXIS_COUNT] = { 1, 2 };
66 const double VELOCITY[AXIS_COUNT] = { 1, 2 };
67 const double ACCELERATION[AXIS_COUNT] = { 10, 20 };
68 const double DECELERATION[AXIS_COUNT] = { 10, 20 };
69 const double JERK_PERCENTAGE[AXIS_COUNT] = { 0, 0 };
70
71 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
72 USE_HARDWARE = false;
73
74 /* SAMPLE APP BODY */
75
76 // Create and initialize RsiController class
77 MotionController* controller = MotionController::CreateFromSoftware();
79
80 // Setup the controller for the appropriate hardware configuration.
81 if (USE_HARDWARE)
82 {
84 }
85 else
86 {
87 SampleAppsHelper::SetupControllerForPhantoms(controller, AXIS_COUNT, { AXIS_X, AXIS_Y });
88 }
89
90 try
91 {
92 // enable one MotionSupervisor for the MultiAxis
93 controller->MotionCountSet(controller->AxisCountGet() + 1);
94
95 // Get Axis X and Y respectively.
96 Axis* axisX = controller->AxisGet(AXIS_X);
98 axisX->UserUnitsSet(USER_UNITS);
99 axisX->PositionSet(0);
101
102 Axis* axisY = controller->AxisGet(AXIS_Y);
104 axisY->UserUnitsSet(USER_UNITS);
105 axisY->PositionSet(0);
107
108 // Initialize a MultiAxis, using the last MotionSupervisor.
109 MultiAxis* multiAxisXY = controller->MultiAxisGet(controller->MotionCountGet() - 1);
111 multiAxisXY->AxisAdd(axisX);
112 multiAxisXY->AxisAdd(axisY);
113
114 // make sure all axes are enabled and ready
115 multiAxisXY->Abort();
116 multiAxisXY->ClearFaults();
117 multiAxisXY->AmpEnableSet(true);
118
119 // Set SYNC_START motion attribute mask.
121 printf("\nMotionStart...");
122
123 // Commanding motion using Syncpptart to start motion for both the axis at the same time.
124 multiAxisXY->MoveSCurve(END_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENTAGE);
125 multiAxisXY->MotionDoneWait();
126
127 // Calling function created on top.
128 PrintResult(axisX, axisY);
129
130 // Set SYNC_END motion attribute mask
132 printf("\nMotionStart...");
133
134 // Commanding motion using SyncEnd to end motion for both the axis at the same time.
135 multiAxisXY->MoveSCurve(START_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENTAGE);
136 multiAxisXY->MotionDoneWait();
137
138 // Calling function created on top
139 PrintResult(axisX, axisY);
140
141 printf("\nTrapezoidal Motion Done\n");
142
143 // Disable the all the axes
144 multiAxisXY->AmpEnableSet(false);
145 }
146 catch (RsiError const& err)
147 {
148 printf("\n%s\n", err.text);
149 return -1;
150 }
151 controller->Delete();
152 return 0;
154}
double CommandPositionGet()
double ActualPositionGet()
int32_t AxisCountGet()
int32_t MotionCountGet()
Point-to-point S-Curve Move.
void AxisAdd(Axis *axis)
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIMotionAttrMaskSYNC_START
Synchronize start of motion for all axes.
Definition rsienums.h:1221
@ RSIMotionAttrMaskSYNC_END
Synchronize end of motion for all axes.
Definition rsienums.h:1220
