MotionHoldReleasedBySoftwareAddress.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: Motion Hold.
#include <thread>
#include "SampleApps.h"
int MotionHoldReleasedBySoftwareAddress::Run()
/* CONSTANTS */
const int AXIS_COUNT = 1;
const int AXIS_NUMBER = 0;
// Index for the address in the user buffer to use for the motion hold
const int USER_BUFFER_INDEX = 0;
// Motion parameters
const double MOTION_DISTANCE = 0.25;
const std::chrono::duration HOLD_TIME = std::chrono::milliseconds(2000);
USE_HARDWARE = false;
const char rmpPath[] = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)"
/* SAMPLE APP BODY */
MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
if (USE_HARDWARE)
// GET AXIS READY
axis->UserUnitsSet(USER_UNITS); // Specify the counts per Unit.
axis->PositionSet(0); // Make sure motor starts at position 0 every time.
axis->ErrorLimitTriggerValueSet(1); // Set the position error trigger value
axis->AmpEnableSet(true); // Enable the motor.
// GET AN AVAILABLE MEMORY ADDRESS
uint64_t userBufferAddress = controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, USER_BUFFER_INDEX);
// SET MOTION HOLD ON AVAILABLE SOFTWARE ADDRESS
axis->MotionHoldTypeSet(RSIMotionHoldType::RSIMotionHoldTypeCUSTOM); // Use TypeCUSTOM to hold execution based on a particular bit turning ON or OFF.
axis->MotionHoldUserAddressSet(userBufferAddress); // Specify the available hostAddress . This address' value will be used to evaluate the motion hold condition.
axis->MotionHoldUserMaskSet(0x1); // Specify the bit you want to mask/watch from the MotionHoldUserAddressSet' address value (this evaluates using a logic AND)
axis->MotionHoldUserPatternSet(0x1); // Specify the bit value that will release the motion hold. (When this value is met, motion hold will be released)
// Check the condition to be false at first
if (controller->MemoryGet(userBufferAddress) != 0x0) // Check Available host address value is mask to be false (in this case 0x0)
controller->MemorySet(userBufferAddress, 0x0); // if not, mask it to false value/condition (in this case 0x0)
// COMMAND MOTION (NO HOLD YET)
printf("\nCommanding Motion...\n");
axis->MoveRelative(MOTION_DISTANCE); // Command simple relative motion. (This motion will have no HOLD)
// SET MOTION HOLD
printf("\nSetting Motion Hold...\n");
axis->MotionAttributeMaskOnSet(RSIMotionAttrMask::RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask ON. (This initializes the HOLD on a particular motion)
// COMMAND MOTION AGAIN (MOTION WILL BE HELD)
printf("Commanding Motion...\n");
axis->MoveRelative(MOTION_DISTANCE); // Command simple relative motion. (This motion will be HOLD by the condition above)
std::this_thread::sleep_for(HOLD_TIME); // Sleep for 3 second before releasing motion hold.
// RELEASE MOTION HOLD (MOTION WILL START)
printf("Releasing Motion Hold...\n");
controller->MemorySet(userBufferAddress, 0x1); // Release Motion Hold by specifying the host address value to SET Condition (in this case 0x10000)
axis->MotionDoneWait(); // Wait for motion to be done
controller->MemorySet(userBufferAddress, 0x0); // Specify host address value back to false value/condition (in this case 0x0)
// CLEAR MOTION HOLD
printf("\nClearing Motion Hold...\n");
axis->MotionAttributeMaskOffSet(RSIMotionAttrMask::RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask OFF. (This will clear any motion HOLDS that were set on this Axis)
// COMMAND MOTION AGAIN (NO HOLD)
axis->MoveRelative(-2 * MOTION_DISTANCE); // This motion will have no HOLD since the previous line has set the motion attribute mask OFF.
axis->MotionDoneWait(); // Wait for Motion to be completed.
// Abort and Clear Faults
axis->Abort();
catch (RsiError const& err)
printf("%s\n", err.text); // If there are any exceptions/issues this will be printed out.
return -1;
return 0;
Definition rsi.h:5963
Set the motion hold type.
Definition rsi.h:111
@ RSIControllerAddressTypeUSER_BUFFER
First location in User Buffer.
Definition rsienums.h:408
@ RSIMotionAttrMaskHOLD
Prevents the move from executing until a specific trigger condition is met. See MotionHold methods.
Definition rsienums.h:1117
