10.6.0
SetupController()
static void SetupController
MotionController
controller
static
static
void
SetupController
MotionController
*controller)
// Set the axis and motion counts
controller->
AxisCountSet
SampleAppsConfig::AXIS_COUNT
controller->
MotionCountSet
SampleAppsConfig::MOTION_COUNT
controller->
MathBlockCountSet
SampleAppsConfig::MATH_BLOCK_COUNT
controller->
UserLimitCountSet
SampleAppsConfig::USER_LIMIT_COUNT
controller->
RecorderCountSet
SampleAppsConfig::RECORDER_COUNT
// Get the axis objects and check them for errors
*axisX = controller->
AxisGet
SampleAppsConfig::AXIS_X_INDEX
CheckErrors
(axisX);
*axisY = controller->
AxisGet
SampleAppsConfig::AXIS_Y_INDEX
CheckErrors
(axisY);
// Check if we are using hardware or phantom axes
if
SampleAppsConfig::USE_HARDWARE
SampleAppsConfig::ConfigureHardwareAxes
(controller, {axisX, axisY});
// Set the user units
axisX->
UserUnitsSet
SampleAppsConfig::AXIS_X_USER_UNITS
axisY->
UserUnitsSet
SampleAppsConfig::AXIS_Y_USER_UNITS
// Configure them as phantoms
ConfigurePhantomAxis
(controller,
(controller,
// Clear Faults
axisX->
ClearFaults
axisY->
ClearFaults
// Start or shutdown the network depending on the configuration
if
StartTheNetwork
(controller);
if
(controller->
NetworkStateGet
() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
controller->
NetworkStateGet
() != RSINetworkState::RSINetworkStateSHUTDOWN)
std::cout <<
"The Sample Apps are configured to use Phantom Axes, but the network is not in the UNINITIALIZED or SHUTDOWN state.\n"
std::cout <<
"If you intended to run with hardware, then follow the steps in README.md and /include/SampleAppsHelper.h\n"
ShutdownTheNetwork
(controller);
AxisConfiguration.cpp
CalculateAccelerationFromVelocity.cpp
DifferenceOfPositionUserLimit.cpp
PhantomAxis.cpp
PointToPoint.cpp
, and
SampleAppsHelper.h
Definition at line
337
of file
SampleAppsHelper.h
SampleAppsHelper
1.10.0
