Motion: Hold
Motion Hold Move Released By Software Address sample application.
Create a motion hold on an axis that is released by setting a bit located at a software address in the user buffer.
Precondition
This sample code presumes that the user has set the tuning parameters(PID, PIV, etc.) prior to running this program so that the motor can rotate in a stable manner.
#include <thread>
#include "SampleApps.h"
int MotionHoldReleasedBySoftwareAddress::Run()
/* CONSTANTS */
const int AXIS_COUNT = 1;
const int AXIS_NUMBER = 0;
// Index for the address in the user buffer to use for the motion hold
const int USER_BUFFER_INDEX = 0;
// Motion parameters
const double MOTION_DISTANCE = 0.25;
const std::chrono::duration HOLD_TIME = std::chrono::milliseconds(2000);
USE_HARDWARE = false;
const char rmpPath[] = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)"
/* SAMPLE APP BODY */
MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
if (USE_HARDWARE)
// GET AXIS READY
axis->UserUnitsSet(USER_UNITS); // Specify the counts per Unit.
axis->PositionSet(0); // Make sure motor starts at position 0 every time.
axis->ErrorLimitTriggerValueSet(1); // Set the position error trigger value
axis->AmpEnableSet(true); // Enable the motor.
// GET AN AVAILABLE MEMORY ADDRESS
uint64_t userBufferAddress = controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, USER_BUFFER_INDEX);
// SET MOTION HOLD ON AVAILABLE SOFTWARE ADDRESS
axis->MotionHoldTypeSet(RSIMotionHoldType::RSIMotionHoldTypeCUSTOM); // Use TypeCUSTOM to hold execution based on a particular bit turning ON or OFF.
axis->MotionHoldUserAddressSet(userBufferAddress); // Specify the available hostAddress . This address' value will be used to evaluate the motion hold condition.
axis->MotionHoldUserMaskSet(0x1); // Specify the bit you want to mask/watch from the MotionHoldUserAddressSet' address value (this evaluates using a logic AND)
axis->MotionHoldUserPatternSet(0x1); // Specify the bit value that will release the motion hold. (When this value is met, motion hold will be released)
// Check the condition to be false at first
if (controller->MemoryGet(userBufferAddress) != 0x0) // Check Available host address value is mask to be false (in this case 0x0)
controller->MemorySet(userBufferAddress, 0x0); // if not, mask it to false value/condition (in this case 0x0)
// COMMAND MOTION (NO HOLD YET)
printf("\nCommanding Motion...\n");
axis->MoveRelative(MOTION_DISTANCE); // Command simple relative motion. (This motion will have no HOLD)
// SET MOTION HOLD
printf("\nSetting Motion Hold...\n");
axis->MotionAttributeMaskOnSet(RSIMotionAttrMask::RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask ON. (This initializes the HOLD on a particular motion)
// COMMAND MOTION AGAIN (MOTION WILL BE HELD)
printf("Commanding Motion...\n");
axis->MoveRelative(MOTION_DISTANCE); // Command simple relative motion. (This motion will be HOLD by the condition above)
std::this_thread::sleep_for(HOLD_TIME); // Sleep for 3 second before releasing motion hold.
// RELEASE MOTION HOLD (MOTION WILL START)
printf("Releasing Motion Hold...\n");
controller->MemorySet(userBufferAddress, 0x1); // Release Motion Hold by specifying the host address value to SET Condition (in this case 0x10000)
axis->MotionDoneWait(); // Wait for motion to be done
controller->MemorySet(userBufferAddress, 0x0); // Specify host address value back to false value/condition (in this case 0x0)
// CLEAR MOTION HOLD
printf("\nClearing Motion Hold...\n");
axis->MotionAttributeMaskOffSet(RSIMotionAttrMask::RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask OFF. (This will clear any motion HOLDS that were set on this Axis)
// COMMAND MOTION AGAIN (NO HOLD)
axis->MoveRelative(-2 * MOTION_DISTANCE); // This motion will have no HOLD since the previous line has set the motion attribute mask OFF.
axis->MotionDoneWait(); // Wait for Motion to be completed.
// Abort and Clear Faults
axis->Abort();
catch (RsiError const& err)
printf("%s\n", err.text); // If there are any exceptions/issues this will be printed out.
return -1;
return 0;
Definition rsi.h:6515
Set the motion hold type.
Definition rsi.h:111
@ RSIControllerAddressTypeUSER_BUFFER
First location in User Buffer.
Definition rsienums.h:408
@ RSIMotionAttrMaskHOLD
Prevents the move from executing until a specific trigger condition is met. See MotionHold methods.
Definition rsienums.h:1152
