◆ SoftwarePosLimitActionSet()
void SoftwarePosLimitActionSet ( RSIAction action)
SoftwarePosLimitActionSet sets the action that will occur when the Software Positive Limit Event triggers.
actionAction taken on Limit trigger. A RSIAction value.
Note:
Axis: Configuration
controller.AxisCountSet(controller.AxisCountGet() + 1); // Configure one additional axis to be used for the phantom axis
int axisNumber = controller.AxisCountGet() - 1; // Set the axis number to the last axis on the network (subtract one because the axes are zero indexed)
axis = controller.AxisGet(axisNumber); // Initialize Axis class
HelperFunctions.CheckErrors(axis); // [Helper Function] Check that the axis has been initialized correctly
axis.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
axis.HardwareNegLimitActionSet(RSIAction.RSIActionNONE); // Set Hardware Negative Limit Action.
axis.HardwarePosLimitActionSet(RSIAction.RSIActionNONE); // Set Hardware Positive Limit Action.
axis.HomeActionSet(RSIAction.RSIActionNONE); // Set Home Action.
axis.SoftwareNegLimitActionSet(RSIAction.RSIActionNONE); // Set Software Negative Limit Action.
axis.SoftwarePosLimitActionSet(RSIAction.RSIActionNONE); // Set Software Positive Limit Action.
const double positionToleranceMax = Double.MaxValue / 10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
axis.PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
axis.PositionToleranceFineSet(positionToleranceMax); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
axis.MotorTypeSet(RSIMotorType.RSIMotorTypePHANTOM); // Set the MotorType to phantom
Go to axis screen->Limits & Actions. In image below, SoftwarePosLimitActionSet sets the action type shown in the Positive (+) Software box. It is currently set to E_STOP.
SoftwarePosLimitActionGet
AxisConfig.cs, PathMotion.cpp, PhantomAxis.cpp, SampleAppsHelper.h, and axis-config-phantom-axis.cs.
