UpdateBufferPoints.cpp
24
25#include <cassert>
26#include "rsi.h" // Import our RapidCode Library.
27#include <cmath>
28#include "SampleApps.h"
29#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
30
31using namespace RSI::RapidCode; // Import the RapidCode namespace
32
34int UpdateBufferPoints::Run()
35{
36 /* CONSTANTS */
37 // *NOTICE* The following constants must be configured before attempting to run with hardware.
38
39 // Axis configuration parameters
40 const int AXIS_COUNT = 1; // number of axes
41 const int AXIS_NUMBER = 0; // axis number
42
43 const double USER_UNITS = 1048576; // counts per unit / user units (set as appropiate)
44
45 // Motion parameters
46 const double TIME_SLICE = 0.001; // 0.001s = 1ms
47 const int REVS = 2; // number of revolutions
48 const int RPS = 1; // revs / sec
49 const int TOTAL_POINTS = (int)(REVS / TIME_SLICE / RPS); // total number of points
50 const int BUFFER_SZ = 100; // Number of points to send in a buffer
51 const int EMPTY_CT = 10; // Number of points that remains in the beffer before an e-stop
52
53 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
54 USE_HARDWARE = false;
55
56 /* SAMPLE APP BODY */
57
58 // Initizalize the controller from software w/ multiple axes
59 MotionController* controller = MotionController::CreateFromSoftware();
61
62 // Setup the controller for the appropriate hardware configuration.
63 if (USE_HARDWARE)
64 {
66 }
67 else
68 {
69 SampleAppsHelper::SetupControllerForPhantoms(controller, AXIS_COUNT, { AXIS_NUMBER });
70 }
71
72 MultiAxis* multiAxis;
73
74 try
75 {
76 // add an additional axis for the multiaxis supervisor
77 controller->MotionCountSet(AXIS_COUNT + 1);
78
79 // create the multiaxis using the ID of the first free axis (0 indexed)
80 multiAxis = controller->MultiAxisGet(AXIS_COUNT);
82
83 // Get the axis and configure it
84 Axis* axis = controller->AxisGet(AXIS_NUMBER); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
85 SampleAppsHelper::CheckErrors(axis); // [Helper Function] Check that the axis has been initialize correctly.
86
87 axis->PositionSet(0); // Make sure motor starts at position 0 everytime.
88 axis->UserUnitsSet(USER_UNITS); // Change your user units.
89 axis->ErrorLimitActionSet(RSIAction::RSIActionNONE); // Set Error Limit Action.
90 axis->Abort(); // If there is any motion happening, abort it.
91 axis->ClearFaults(); // Clear faults.>
92
93 multiAxis->AxisAdd(axis); // Add the axis to the multiaxis supervisor
94
95 // populate the positions and times
96 std::vector<double> positions, times;
97 for (int i = 0; i < TOTAL_POINTS; i += AXIS_COUNT)
98 {
99 positions.push_back(i * TIME_SLICE * RPS);
100 times.push_back(TIME_SLICE);
101 }
102
103 // prepare the controller (and drive)
104 multiAxis->Abort();
105 multiAxis->ClearFaults();
106 assert(multiAxis->StateGet() == RSIState::RSIStateIDLE);
107 multiAxis->AmpEnableSet(true);
108
109 // reset the motion ID to 0
110 multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0], &times[0], 1, -1, false, true);
111 multiAxis->MotionIdSet(0);
112
113 // Establish how to keep track of what blocks have been sent
114 int curMotionElementID = 0, curMotionID = 0, finalMotionID = 0;
115 int numPointsToSend = BUFFER_SZ;
116 int endOfLastSent = 0;
117 bool exitCondition = false;
118
119 // Set up a motion hold gate so we can start buffering blocks
120 const int motionHoldGate = 3;
121 controller->MotionHoldGateSet(motionHoldGate, true);
122 multiAxis->MotionHoldGateSet(motionHoldGate);
123
124 for (int i = 0; i < 2; ++i)
125 {
126 multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0] + endOfLastSent * AXIS_COUNT, &times[0] + endOfLastSent, numPointsToSend, EMPTY_CT, false, exitCondition);
127 endOfLastSent += numPointsToSend;
128 ++finalMotionID;
129 }
130
131 // Set up the interrupt frequency period
132 controller->SyncInterruptPeriodSet(10); // this generates an interrupt every x cycles of a 1KHz sample rate
133 // With our timeslices of 1ms, this is 10*1ms=10ms
134 controller->SyncInterruptEnableSet(true);
135
136 controller->MotionHoldGateSet(motionHoldGate, false); // release the hold gate to start moving
137
138 while (!exitCondition)
139 {
140 int32_t sampleRecieved = controller->SyncInterruptWait(); // see above for timing
141 curMotionID = multiAxis->MotionIdExecutingGet(); // this takes an unspecified amount of time (non-rtos) so this is going to be called sometime after the interrupt gets handled.
142 // There's an additional delay to retrieve the data as well.
143 curMotionElementID = multiAxis->MotionElementIdExecutingGet();
144
145 /*
146 Each MovePT assigns a new MotionID for each call to a move update (with the bufferred points)
147 Working under the assumption that each Buffer gets a new ID, send two (or several) smaller ones
148 and when the change in IDs is greater than some number, send a new one
149 */
150
151 // change this logic to manage the number of buffered moves (and points) as appropiate
152 // generate points as appropiate
153 if (std::abs(finalMotionID - curMotionID) < 2)
154 {
155 // check end condition
156 if (TOTAL_POINTS <= (endOfLastSent + BUFFER_SZ))
157 {
158 numPointsToSend = TOTAL_POINTS - endOfLastSent; // send the remaining points
159 exitCondition = true;
160 }
161 multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0] + endOfLastSent * AXIS_COUNT, &times[0] + endOfLastSent, numPointsToSend, EMPTY_CT, false, exitCondition);
162
163 printf("MotionID %d\nEnd of Last Sent %d\nElement ID %d\nNum to Send %d\nIs Done %s\n===========================================\n\n",
164 curMotionID, endOfLastSent, curMotionElementID, numPointsToSend, exitCondition ? "yes" : "no");
165
166 endOfLastSent += numPointsToSend;
167 ++finalMotionID;
168 }
169 }
170 printf("Updates Done. Waiting to finish motion.\n");
171 multiAxis->MotionDoneWait();
172 printf("Motion Complete. Final Motion ID: %d\tFinal Element ID %d\n", multiAxis->MotionIdExecutingGet(), multiAxis->MotionElementIdExecutingGet());
173
174 multiAxis->EStopAbort();
175 }
176 catch (RsiError const& err) {
177 printf("\n%s\n", err.text);
178 return -1;
179 }
180 controller->Delete();
181 return 0;
182}
void MotionHoldGateSet(int32_t gateNumber, bool hold)
Set the Motion Hold Gate.
int32_t SyncInterruptWait()
uint16_t MotionElementIdExecutingGet()
void AxisAdd(Axis *axis)
void MotionIdSet(uint16_t id)
Set the Motion identifier.
RSIState StateGet()
void MotionHoldGateSet(bool hold)
void EStopAbort()
E-Stop, then abort an axis.
@ RSIMotionTypePT
Definition rsienums.h:1180
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIStateIDLE
Idle, ready for anything.
Definition rsienums.h:1016
