PhantomAxis.cpp
10#include "SampleAppsHelper.h" // Import our helper functions.
11#include "rsi.h" // Import our RapidCode Library.
12
13using namespace RSI::RapidCode; // Import the RapidCode namespace
14
15int main()
16{
17 const std::string SAMPLE_APP_NAME = "Axis Configuration: Phantom Axis";
18
19 // Print a start message to indicate that the sample app has started
20 SampleAppsHelper::PrintHeader(SAMPLE_APP_NAME);
21
22 /* CONSTANTS */
23 // *NOTICE* The following constants must be configured before attempting to run with hardware.
24 const int NUM_AXES = 1; // The number of axes to configure, default is 0 for this template
25 const int AXIS_INDEX = 0; // The index of the axis to configure
26
27 /* RAPIDCODE INITIALIZATION */
28
29 // Create the controller
31 MotionController *controller = MotionController::Create(&params);
32
33 // Set the exit code to an error value.
34 int exitCode = -1;
35 try // Ensure that the controller is deleted if an error occurs.
36 {
37 // Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
39 SampleAppsHelper::SetupController(controller, NUM_AXES);
40
41 /* SET CONTROLLER OBJECT COUNTS HERE*/
42 // Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
43 // controller->AxisCountSet(NUM_AXES);
44
45 /* SAMPLE APP BODY */
46
48 // Get the axis
49 Axis *axis = controller->AxisGet(AXIS_INDEX);
51
52 // Configure the axis as a phantom axis
53 // These limits are not meaningful for a Phantom Axis (e.g., a phantom axis has no actual position so a position error trigger is not necessary)
54 // Therefore, you must set all of their actions to "NONE".
55 axis->PositionSet(0); // Set the position to 0
56 axis->ErrorLimitActionSet(RSIAction::RSIActionNONE); // Set Error Limit Action.
57 axis->AmpFaultActionSet(RSIAction::RSIActionNONE); // Set Amp Fault Action.
58 axis->AmpFaultTriggerStateSet(1); // Set Amp Fault Trigger State.
59 axis->HardwareNegLimitActionSet(RSIAction::RSIActionNONE); // Set Hardware Negative Limit Action.
60 axis->HardwarePosLimitActionSet(RSIAction::RSIActionNONE); // Set Hardware Positive Limit Action.
61 axis->SoftwareNegLimitActionSet(RSIAction::RSIActionNONE); // Set Software Negative Limit Action.
62 axis->SoftwarePosLimitActionSet(RSIAction::RSIActionNONE); // Set Software Positive Limit Action.
63 axis->HomeActionSet(RSIAction::RSIActionNONE); // Set Home Action.
64
65 // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
66 const double positionToleranceMax = std::numeric_limits<double>::max() / 10.0;
67 axis->PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
68
69 // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
70 axis->PositionToleranceFineSet(positionToleranceMax);
71
72 axis->MotorTypeSet(RSIMotorType::RSIMotorTypePHANTOM); // Set the MotorType to phantom
74
75 std::cout << "Phantom Axis created with index: " << AXIS_INDEX << std::endl;
76
77 exitCode = 0; // Set the exit code to success.
78 }
79 catch (const std::exception &ex)
80 {
81 std::cerr << ex.what() << std::endl;
82 exitCode = -1;
83 }
84 // Clean up the controller and any other objects as needed
85 SampleAppsHelper::Cleanup(controller);
86
87 // Delete the controller as the program exits to ensure memory is deallocated in the correct order
88 controller->Delete();
89
90 // Print a message to indicate the sample app has finished and if it was successful or not
91 SampleAppsHelper::PrintFooter(SAMPLE_APP_NAME, exitCode);
92
93 return exitCode;
94}
Set the Amp Fault action.
Set the motor type.
Definition rsi.h:5789
Definition rsi.h:800
Definition rsi.h:866
