InputOutput.cs
62using RSI.RapidCode.dotNET; // Import our RapidCode Library.
63using NUnit.Framework;
64using System;
65
66#if DOXYGEN
67// needed for docs generation
68using RSI.RapidCode;
69#else
70// needed for project to compile (NetworkNode alias maps to RapidCodeNetworkNode for Doxygen)
71using NetworkNode = RSI.RapidCode.dotNET.RapidCodeNetworkNode;
72#endif
73
75[TestFixture]
76[Category("Software")]
77class InputOutput : SampleAppTestBase
78{
79
80 [Test, Timeout(Constants.MAX_TEST_TIME)]
81 [Ignore("Needs a network with a real node to run, but we want the snippet for docs. At least it's compiled!")]
82 public void GeneralPurposeIO()
83 {
84 Assert.DoesNotThrow(() =>
85 {
87 const int nodeIndex = 0;
88 const int digitalInIndex = 0;
89 const int digitalOutIndex = 0;
90 const int analogIndex = 0;
91
92 // get node
93 NetworkNode node = controller.NetworkNodeGet(nodeIndex);
95
96 // digital io
97 bool dIn = node.DigitalInGet(digitalInIndex);
98 bool dOut = node.DigitalOutGet(digitalOutIndex);
99 node.DigitalOutSet(digitalOutIndex, true);
100
101 // analog io
102 int aIn = node.AnalogInGet(analogIndex);
103 int aOut = node.AnalogOutGet(analogIndex);
104 node.AnalogOutSet(analogIndex, 1234);
106 });
107 }
108
109 [Test, Timeout(Constants.MAX_TEST_TIME)]
110 public void DedicatedIO()
111 {
113 // Retrieve dedicated inputs with generic and specific function.
114 Console.WriteLine("RSIMotorDedicatedInLIMIT_HW_NEG: {0} and {1}",
115 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_NEG),
116 axis.NegativeLimitGet());
117
118 Console.WriteLine("RSIMotorDedicatedInLIMIT_HW_POS: {0} and {1}",
119 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_POS),
120 axis.PositiveLimitGet());
121
122 Console.WriteLine("RSIMotorDedicatedInHOME: {0} and {1}",
123 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInHOME),
124 axis.HomeSwitchGet());
125
126 Console.WriteLine("RSIMotorDedicatedInAMP_FAULT: {0} and {1}",
127 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_FAULT),
128 axis.AmpFaultGet());
129
130 Console.WriteLine("RSIMotorDedicatedInAMP_ACTIVE: {0} and {1}",
131 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_ACTIVE),
132 axis.AmpEnableGet());
134 }
135
136 [Test, Timeout(Constants.MAX_TEST_TIME)]
137 public void NetworkInputsAndOutputs()
138 {
140 // Get Input Values
141 int inputCount = controller.NetworkInputCountGet(); // Get number of Network Inputs (PDOs)
142
143 for (int i = 0; i < inputCount; i++)
144 {
145 int size = controller.NetworkInputBitSizeGet(i); // Read Input BitSize
146 int offset = controller.NetworkInputBitOffsetGet(i); // Read Input BitOffset
147 string name = controller.NetworkInputNameGet(i); // Read Input Name
148 UInt64 value = controller.NetworkInputValueGet(i); // Read Input Value
149 }
150
151 // Get Output Values
152 int outputCount = controller.NetworkOutputCountGet(); // Get number of Network Outputs (SDOs)
153
154 for (int i = 0; i < outputCount; i++)
155 {
156 int size = controller.NetworkOutputBitSizeGet(i); // Read Output BitSize
157 int offset = controller.NetworkOutputBitOffsetGet(i); // Read Output BitOffset
158 string name = controller.NetworkOutputNameGet(i); // Read Output Name
159 UInt64 value = controller.NetworkOutputSentValueGet(i); // Read Output Value
160 controller.NetworkOutputOverrideValueSet(i, value);
161 }
163 }
164
165
166 //TODO expand examples once iopoint is expanded.
167 [Test]
168 public void IOPoints()
169 {
172 const int NODE_INDEX = 0; // The EtherCAT Node we will be communicating with
173 //const int INPUT_INDEX = 0; // The PDO Index in that Node
174 const int OUTPUT_INDEX = 0; // The PDO Index in that Node
175
176 IOPoint output0 = IOPoint.CreateDigitalOutput(controller.NetworkNodeGet(NODE_INDEX), OUTPUT_INDEX); // Automatically gets the memory index of a specified node and input index
177
179 output0.Set(false);
180
182 controller.SampleWait(1);
183 Assert.That(output0.Get(), Is.False, "The getter function should return a value equal to false");
185 }
186
187 //TODO expand examples once iopoint is expanded.
188 [Test]
189 public void IOPointUserBuffer()
190 {
193 const int INPUT_INDEX = 0;
194 const int OUTPUT_INDEX = 1; // The PDO Index in that Node
195
196 UInt64 userBufferAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0); // Grabing an memory address to store a simulated IO point.
197
198 IOPoint input0 = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX); // Automatically gets the memory index of a specified node and input index
199 IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX); // Automatically gets the memory index of a specified node and input index
200
201 //---ACT/ASSERT---
202 output0.Set(false);
203 Assert.That(output0.Get(), Is.False, "The getter function should return a value equal to false");
204 output0.Set(true);
205 Assert.That(output0.Get(), Is.True, "The getter function should return a value equal to true");
206 controller.MemorySet(input0.AddressGet(), 0);
207 Assert.That(input0.Get(), Is.False, "The getter function should return a value equal to false");
208 controller.MemorySet(input0.AddressGet(), 1);
209 Assert.That(input0.Get(), Is.True, "The getter function should return a value equal to true");
211 }
212
213 [Test]
214 public void SingleAxisSyncOutputs()
215 {
217 const int TOTAL_POINTS = 4; // total number of points
218 const int EMPTY_CT = -1; // Number of points that remains in the buffer before an e-stop
219 const int OUTPUT_INDEX = 0; // This is the index of the digital output that will go active when the user limit triggers.
220 const int NODE_INDEX = 0; // The EtherCAT Node we will be communicating with
221
222 double[] positions = { 1.0, 2.0, 3.0, 4.0 }; // These will be the streaming motion 5 positions.
223 double[] times = { 0.5, 0.1, 0.2, 0.4 }; // These will be the streaming motion 5 positions' time.
224 int outputEnableID = 2; // The motion element ID at which to set the output
225 int outputDisableID = 3; // The motion element ID at which to set the output
226
227 // Set up the inputs
228 // IOPoint output0 = IOPoint.CreateDigitalOutput(axis, RSIMotorGeneralIo.RSIMotorGeneralIo16); // Retrieve DOUT 1, Method 1: requires you know the io adress in memory, slightly faster
229 IOPoint output0 = IOPoint.CreateDigitalOutput(controller.NetworkNodeGet(NODE_INDEX), OUTPUT_INDEX); // Retrieve DOUT 1 Method 2: only need to know node index
230 output0.Set(false); // Set the output low
231
232 // Set up Sync Outputs
233 axis.StreamingOutputsEnableSet(true); // Enable streaming output.
234
235 // ENABLE the Sync Output(s)
236 axis.StreamingOutputAdd(output0, true, outputEnableID); // This will turn DOUT1 High when the streaming motion reaches its 3rd motion point.
237 axis.StreamingOutputAdd(output0, false, outputDisableID); // This will turn DOUT1 Low when the streaming motion reaches its 4th motion point.
238
239 // DISABLE the Sync Output(s)
240 // axis.StreamingOutputAdd(output0, false, outPutEnableID);
241
242 axis.MovePT(RSIMotionType.RSIMotionTypePT, positions, times, TOTAL_POINTS, EMPTY_CT, false, true); // Start Streaming Motion
243
244 while (!axis.MotionDoneGet())
245 {
246 if (axis.MotionIdExecutingGet() > outputEnableID && axis.CommandPositionGet() < outputEnableID)
247 {
248 Assert.That(output0.Get(), Is.EqualTo(true), "The output should be triggered");
249 }
250 else
251 {
252 Assert.That(output0.Get(), Is.EqualTo(false), "The output should NOT be triggered");
253 }
254 }
255
256 axis.StreamingOutputsEnableSet(false); // Disable Sync Outputs.
257 axis.AmpEnableSet(false); // Disable the motor.
259 }
260}
double CommandPositionGet()
bool AmpEnableGet()
bool HomeSwitchGet()
bool PositiveLimitGet()
uint16_t MotionIdExecutingGet()
bool NegativeLimitGet()
bool AmpFaultGet()
bool DedicatedInGet(RSIMotorDedicatedIn motorDedicatedInNumber)
Read a digital input.
void Set(bool state)
bool Get()
Definition rsi.h:11559
NetworkNode * NetworkNodeGet(int32_t nodeNumber)
NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializ...
Sets a PDO output directly.
int32_t NetworkInputBitOffsetGet(int32_t index)
uint64_t NetworkOutputSentValueGet(int32_t index)
Gets the value sent out over EtherCAT.
Get the name of a PDO output.
int32_t NetworkOutputBitOffsetGet(int32_t index)
Get the raw PDO offset for an output.
void DigitalOutSet(int32_t digitalOutNumber, bool state)
Set the state of a digital output.
bool DigitalInGet(int32_t digitalInNumber)
Get the state of a digital input.
int32_t AnalogInGet(int32_t analogChannel)
bool DigitalOutGet(int32_t digitalOutNumber)
Get the state of a digital output.
int32_t AnalogOutGet(int32_t analogChannel)
Get the value of an analog output.
void AnalogOutSet(int32_t analogChannel, int32_t analogValue)
Set the value of an analog output.
Represents an EtherCAT node / SubDevice (Drive, I/O Block, etc) on the network. This class provides a...
Definition rsi.h:3854
bool MotionDoneGet()
RSIMotionType
Definition rsienums.h:1038
RSIMotorDedicatedIn
Definition rsienums.h:889
