33using RSI.RapidCode.dotNET;
37using System.Threading;
39using System.Runtime.InteropServices;
51 Console.WriteLine(
"G-Code Callback executed: " + data.
LineNumber +
" " + data.
LineText);
61public class GcodeMotion : SampleAppTestBase
70 public void Teardown()
78 jointsMultiAxis?.
Abort();
85 var actualUnits = model.UnitsGet();
86 Assert.That(actualUnits, Is.EqualTo(expectedUnits), $
"Expected model units to be '{expectedUnits}' but was '{actualUnits}' instead!");
87 var actualName = model.NameGet();
88 Assert.That(actualName, Is.EqualTo(expectedName), $
"Expected model name to be '{expectedName}' but was '{actualName}' instead!");
92 public void GcodeBasic()
96 string gcodeProgram =
"G91; Sets the programming mode to RELATIVE\n" +
97 "G64; Turns off exact stop mode(Default)\n" +
98 "G1 X1.0 Y0.0 Z0.0 A1.0 F60.0; Move on USERUNIT in positive x direction at 60in/min. Moves Free axis A to position 1.0.\n" +
99 "G3 X1 Y1 I0 J1; Counter clockwise arc with a center point of 0,1,0 and end point of 1,1,0 relative to the current position\n" +
100 "M80; Show how to use an M-code with GcodeCallback!\n";
103 const string xLabel =
"X-Axis";
104 const string yLabel =
"Y-Axis";
105 const string zLabel =
"Z-Axis";
106 const string aLabel =
"A-Axis";
118 Axis[] axes =
new Axis[] { x_axis, y_axis, z_axis, a_axis };
119 jointsMultiAxis.
AxesAdd(axes, axes.Length);
123 const string modelName =
"RSI_XYZA";
124 const double scaling = 1.0, offset = 0.0;
149 Console.WriteLine(
"Error loading G-Code: " + e.Message);
158 Console.WriteLine(
"G-code estimated run time: " + robot.
Gcode.
DurationGet() +
" seconds");
161 Int64 activeLineNumber = 0;
168 Console.WriteLine(
"G-Code Line Number: " + activeLineNumber);
177 Assert.That(robot.
Gcode.
LineCountGet(), Is.EqualTo(gcodeProgram.Count(c => c.Equals(
'\n'))));
178 VerifyModel(robot.
ModelGet(), modelName);
182 public void ChangingUnits()
186 const string xLabel =
"X-Axis";
187 const string yLabel =
"Y-Axis";
188 const string zLabel =
"Z-Axis";
189 const string aLabel =
"A-Axis";
190 const string bLabel =
"B-Axis";
191 const string cLabel =
"C-Axis";
207 Axis[] axes =
new Axis[] { x_axis, y_axis, z_axis, a_axis, b_axis, c_axis };
208 jointsMultiAxis.
211 const string modelName =
"RSI_XYZABC_Centimeters";
213 const double scaling = 1.0, offset = 0.0;
243 VerifyModel(robot.
ModelGet(), modelName, units);
void FreeAxisLetterSet(const char gcodeLetter, const int32_t freeAxisIndex)=0
Map a letter in a Gcode file to a free axis. It will be used to specify the free axis' motion.
void CallbackRegister(Cartesian::GcodeCallback *callback, bool containsMotion=false)=0
Register a catch-all M-code callback.
int32_t LineCountGet()=0
Get the number of lines in the last loaded G-Code program.
int32_t ExecutingLineNumberGet()=0
Get the currently executing line number.
LinearUnits UnitsGet()=0
Get the currently active unit as set by G20/G21.
void AccelerationRateSet(double programmingUnitsPerMinuteSquared)=0
REQUIRED before Load() or LoadFile(). Sets the target acceleration for the machine (units/minute^2)....
void UnitsSet(LinearUnits units)=0
Set the currently active unit (same as calling G20/G21)
double DurationGet()=0
Get the time duration required to run the loaded G-Code program in seconds.
void FeedRateSet(double programmingUnitsPerMinute)=0
REQUIRED before Load() or LoadFile() if your g-code does not have 'F' in its contents....
void Load(const char *const text)=0
Load a G-code program from a string.
void Run()=0
Run the loaded G-Code file (or string). The behavior is non-blocking. Use DoneWait() to block.
Handles callbacks for M-codes within a G-code file.
bool IsRunning()=0
Returns true if a Gcode program is executing, false otherwise.
void FreeAxisAdd(const ModelAxisMapping &freeAxis)
Map a free axis in the kinematic model. The Axis' DefaultVelocity/Acceleration will be used for free ...
uint64_t MotionDoneWait()=0
void EStop()=0
void ClearFaults()=0
Delete a Robot.
RSI::RapidCode::Cartesian::Gcode * Gcode
An object to load and run Gcode files.
void AxisRemoveAll()
int32_t ErrorLogCountGet()
make a Callback class and register it with the Gcode object
CartesianAxis
LinearUnits
const char * LineText
The actual line content from the G-code file.
int32_t LineNumber
The line number in the G-code file where the M-code is encountered.
Holds data for the G-code M-code callback mechanism.
Data for adding joint or free-axis mappings when building a kinematic model.
