10#include "SampleAppsHelper.h"
18 const std::string SAMPLE_APP_NAME =
"Math Blocks: Calculate Acceleration from Velocity";
24 const int NUM_AXES = 1;
25 const int AXIS_INDEX = 0;
26 const double VELOCITY = 1.0;
27 const double ACCELERATION = 0.123;
35 int initialMathBlockCount = -1;
55 const int subtractionMathBlockIndex = initialMathBlockCount;
56 const int previousVelocityMathBlockIndex = initialMathBlockCount + 1;
73 RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = RSIAxisAddressType::RSIAxisAddressTypeCOMMAND_VELOCITY;
82 controller->
AddressGet(RSIControllerAddressType::RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, previousVelocityMathBlockIndex);
86 subtractionConfig.
Operation = RSIMathBlockOperation::RSIMathBlockOperationSUBTRACT;
89 uint64_t userBufferAddr0 = controller->
AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, 0);
95 previousVelocityConfig.
InputDataType0 = RSIDataType::RSIDataTypeDOUBLE;
97 previousVelocityConfig.
InputDataType1 = RSIDataType::RSIDataTypeDOUBLE;
98 previousVelocityConfig.
ProcessDataType = RSIDataType::RSIDataTypeDOUBLE;
99 previousVelocityConfig.
Operation = RSIMathBlockOperation::RSIMathBlockOperationMULTIPLY;
103 controller->
MathBlockConfigSet(previousVelocityMathBlockIndex, previousVelocityConfig);
127 std::cout <<
"Calculated acceleration from MathBlock: " << calculatedAcceleration << std::endl;
130 if (std::abs(calculatedAcceleration - ACCELERATION) <= 0.000001)
132 std::cout <<
"The MathBlock is calculating the Axis' acceleration by subtracting previous velocity from current velocity." << std::endl;
137 std::cerr <<
"Error: The calculated acceleration does not match the expected value" << std::endl;
141 catch (
const std::exception &ex)
143 std::cerr << ex.what() << std::endl;
147 if (initialMathBlockCount != -1) { controller->
MathBlockCountSet(initialMathBlockCount); }
double UserUnitsGet()
int32_t MathBlockCountGet()
int32_t MotionDoneWait()
RSIDataType ProcessDataType
Data type for processing.
uint64_t InputAddress0
RSIDataType InputDataType0
uint64_t InputAddress1
RSIDataType InputDataType1
double Double
