Motion: Multi-Axis
Multi-Axis Motion sample application.
We have created arrays for start_position, end_position, velocity, accel, decel and jerkPct and used them in function called MoveSCurve which commands motion for both the axis->
Syncpptart commands both motors to start moving at the same time towards their respective end_positions. SyncEnd commands both the motors to end their motion at the same time when moving towards start_positions.
Precondition
This sample code presumes that the user has set the tuning parameters(PID, PIV, etc.) prior to running this program so that the motor can rotate in a stable manner.
#include <conio.h>
#include "SampleApps.h"
/*This function will print all the results to the screen*/
void PrintResult(Axis* axisX, Axis* axisY)
printf("Motion Done \n AxisX position-> Commanded: %f \tActual: %f\n",
axisX->ActualPositionGet());
printf(" AxisY position-> Commanded: %f \tActual: %f\n",
axisY->ActualPositionGet());
int MultiaxisMotion::Run()
/* CONSTANTS */
const int AXIS_COUNT = 2;
const int AXIS_X = 0;
const int AXIS_Y = 1;
const int MOTION_COUNT = 1;
// Motion parameters
const double START_POSITION[AXIS_COUNT] = { 0, 0 };
const double END_POSITION[AXIS_COUNT] = { 1, 2 };
const double VELOCITY[AXIS_COUNT] = { 1, 2 };
const double ACCELERATION[AXIS_COUNT] = { 10, 20 };
const double DECELERATION[AXIS_COUNT] = { 10, 20 };
const double JERK_PERCENTAGE[AXIS_COUNT] = { 0, 0 };
USE_HARDWARE = false;
/* SAMPLE APP BODY */
// Create and initialize RsiController class
if (USE_HARDWARE)
axisX->PositionSet(0);
axisY->PositionSet(0);
multiAxisXY->AxisAdd(axisX);
multiAxisXY->AxisAdd(axisY);
// make sure all axes are enabled and ready
multiAxisXY->Abort();
multiAxisXY->ClearFaults();
// Set SYNC_START motion attribute mask.
printf("\nMotionStart...");
// Commanding motion using Syncpptart to start motion for both the axis at the same time.
multiAxisXY->MoveSCurve(END_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENTAGE);
// Calling function created on top.
PrintResult(axisX, axisY);
// Set SYNC_END motion attribute mask
// Commanding motion using SyncEnd to end motion for both the axis at the same time.
multiAxisXY->MoveSCurve(START_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENTAGE);
printf("\nTrapezoidal Motion Done\n");
// Disable the all the axes
catch (RsiError const& err)
printf("\n%s\n", err.text);
return -1;
controller->Delete();
return 0;
double CommandPositionGet()
double ActualPositionGet()
Point-to-point S-Curve Move.
void AxisAdd(Axis *axis)
Definition rsi.h:12226
Definition rsi.h:111
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIMotionAttrMaskSYNC_START
Synchronize start of motion for all axes.
Definition rsienums.h:1221
@ RSIMotionAttrMaskSYNC_END
Synchronize end of motion for all axes.
Definition rsienums.h:1220
constexpr bool USE_HARDWARE
Definition config.h:40
