◆ CompensatorPointCountSet()
void CompensatorPointCountSet ( int32_t compensatorNumber,
int32_t pointCount )
pointCountthe number of points which will be stored in the table
CompensatorPointCountSet sets the number of Compensator points allocated on the controller. This must be configured before creating Axis or MultiAxis objects, as these counts change the dynamic memory allocation inside the controller's firmware.
Motion: Compensator
const int INDEX_ZERO = 0;
const int INDEX_ONE = 1;
// print compensator info
// get rmp controller
// get & configure axes
// set compensator0
inputAxis: movingAxis,
inputAxisMinimum: MIN,
inputAxisMaximum: MAX,
inputAxisDelta: DELTA,
outputAxis: followerAxis,
table: table0);
// set compensator1
compensatorNumber: INDEX_ONE,
table: table1);
// get results
// print results
// verify compensation
const int AXIS_1_INDEX
Definition _constants.cs:21
Definition rsi.h:5963
Compensator output types.
Definition rsienums.h:1507
RSIAxisMasterType
Definition rsienums.h:1267
CompensatorCountSet
