Motion: Compensator
Learn how to configure and use compensators for motion correction.
In this page:
📜 Compensator: Single Axis
Learn how to configure a Compensator 📖 that modifies the motion of itself, useful for correcting mechanical non-linearities or backlash on a single axis.
/* This sample demonstrates how to configure a compensator that modifies the motion of itself.
The axis command position is used as the input to apply compensation to the same axis,
useful for correcting mechanical non-linearities or backlash.
Console.WriteLine("📜 Compensator: Single Axis");
const int INDEX_ZERO = 0;
const int MIN = 10;
const int MAX = 110;
const int DELTA = 10;
const double VELOCITY = 20.0;
const double ACCELERATION = 30.0;
const double DECELERATION = 30.0;
const double JERK = 50.0;
// compensator table (values are in raw counts not user units)
// at position: 10 20 30 40 50 ... ... 110
// adjust by: ↓ ↓ ↓ ↓ ↓ ... ... ↓
double[] table = new double[POINTS] { 0, 2, -3, -5, -3, 2, -3, 0, 2, -3, -5 };
// print compensator info
Console.WriteLine("Compensator Table:");
for (int i = 0; i < POINTS; i++)
int inputPos = MIN + (i * DELTA);
Console.WriteLine($"@ Pos: {inputPos}, Compensate by: {table[i]}");
// get rmp controller
controller.CompensatorCountSet(1);
controller.CompensatorPointCountSet(compensatorNumber: INDEX_ZERO, pointCount: table.Length);
// get & configure axis
double originalUserUnits = axis.UserUnitsGet();
axis.UserUnitsSet(1); // For demonstration simplicity, set user units to 1 even for hardware axes, since compensators work in raw counts
// verify the three values are equal before configuring compensator
if (controller.CompensatorPointCountGet(INDEX_ZERO) == table.Length && POINTS == table.Length)
// configure compensator using AXIS_COMMAND_POSITION as input to modify same axis
inputAxis: axis,
inputAxisType: RSIAxisMasterType.RSIAxisMasterTypeAXIS_COMMAND_POSITION,
inputAxisMinimum: MIN,
inputAxisMaximum: MAX,
inputAxisDelta: DELTA,
outputAxis: axis,
table: table);
// command motion
axis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
axis.PositionSet(MIN);
axis.MoveSCurve(position: MIN + DELTA, VELOCITY, ACCELERATION, DECELERATION, JERK); // move to 2nd point
axis.MotionDoneWait();
// get results
double compPos = axis.CompensationPositionGet();
// print results
Console.WriteLine($"Compensation position: {compPos} (expected: {table[1]})");
axis.AmpEnableSet(false);
axis.UserUnitsSet(originalUserUnits);
// verify compensation
if (compPos != table[1])
double UserUnitsGet()
Compensator output types.
Definition rsienums.h:1602
RSIAxisMasterType
Definition rsienums.h:1359
📜 Compensator: 1D
Learn how to configure a 1-dimensional Compensator 📖 with overlapping compensation tables to modify follower axis motion based on moving axis position.
const int INDEX_ONE = 1;
// get & configure axes
// set compensator0
inputAxis: movingAxis,
outputAxis: followerAxis,
table: table0);
// set compensator1
compensatorNumber: INDEX_ONE,
table: table1);
// get results
// print results
const int AXIS_1_INDEX
Definition _constants.cs:21
📜 Compensator: 2D
Learn how to configure a 2-dimensional Compensator 📖 to apply flatness compensation or surface mapping based on two input axes (X and Y) to an output axis (Z).
/* This sample demonstrates how to configure and use a 2-dimensional compensator.
A 2D compensation table is applied to a Z axis based on the positions of X and Y axes,
useful for flatness compensation or surface mapping applications.
Console.WriteLine("📜 Compensator: 2D");
const int X_MIN = 0;
const int X_MAX = 500;
const int X_DELTA = 100;
const int X_POINTS = ((X_MAX - X_MIN) / X_DELTA) + 1; // 6 points
const int Y_MIN = 0;
const int Y_MAX = 500;
const int Y_DELTA = 100;
const int Y_POINTS = ((Y_MAX - Y_MIN) / Y_DELTA) + 1; // 6 points
const int TOTAL_POINTS = X_POINTS * Y_POINTS; // 36 points total
// compensator table values use axis COUNTS (not user units)
// table is organized as rows (X) & columns (Y)
double[] table = new double[TOTAL_POINTS] {
0, 0, 0, 0, 0, 0,
100, 200, -200, 10, 300, 0,
100, 200, -500, 400, 500, 0,
0, 0, 0, 0, 0, 0,
-300, 300, -300, -300, -300, 0,
0, 0, 0, 0, 0, 0,
Console.WriteLine($"X Range: {X_MIN} to {X_MAX}, Delta: {X_DELTA}");
Console.WriteLine($"Y Range: {Y_MIN} to {Y_MAX}, Delta: {Y_DELTA}");
Console.WriteLine($"Points: {TOTAL_POINTS}");
Console.WriteLine($"2D Compensator Table ({X_POINTS}x{Y_POINTS}):");
for (int i = 0; i < Y_POINTS; i++)
for (int j = 0; j < X_POINTS; j++)
Console.Write($"{table[i * X_POINTS + j],6}");
Console.WriteLine();
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 3);
controller.CompensatorPointCountSet(INDEX_ZERO, table.Length); // set number points allocated on the controller
Axis x = controller.AxisGet(axisNumber: Constants.AXIS_0_INDEX);
Helpers.CheckErrors(x);
Axis y = controller.AxisGet(axisNumber: Constants.AXIS_1_INDEX);
Helpers.CheckErrors(y);
Axis z = controller.AxisGet(axisNumber: Constants.AXIS_2_INDEX);
Helpers.CheckErrors(z);
// set position error limit trigger
// init the 2D compensator
firstInputAxis: x,
firstInputAxisType: RSIAxisMasterType.RSIAxisMasterTypeAXIS_ACTUAL_POSITION,
firstInputAxisMinimum: X_MIN,
firstInputAxisMaximum: X_MAX,
firstInputAxisDelta: X_DELTA,
secondInputAxis: y,
secondInputAxisType: RSIAxisMasterType.RSIAxisMasterTypeAXIS_ACTUAL_POSITION,
secondInputAxisMinimum: Y_MIN,
secondInputAxisMaximum: Y_MAX,
secondInputAxisDelta: Y_DELTA,
outputAxis: z,
table: table);
// get results
x.PositionSet(0);
y.PositionSet(0);
double compPos1 = z.CompensationPositionGet();
x.PositionSet(X_DELTA);
y.PositionSet(Y_DELTA);
double compPos2 = z.CompensationPositionGet();
// print results
Console.WriteLine($"Compensation at (0,0): {compPos1} (expected: {table[0]})");
Console.WriteLine($"Compensation at ({X_DELTA},{Y_DELTA}): {compPos2} (expected: {table[7]})");
// verify accuracy
if (compPos1 != table[0] || compPos2 != table[7])
Helpers.AbortMotionObject(x);
Helpers.AbortMotionObject(y);
Helpers.AbortMotionObject(z);
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
