◆ RecorderBufferSizeSet()
void RecorderBufferSizeSet ( int32_t recorderNumber,
int32_t bufferSize )
RecorderBufferSizeSet sets the buffer size for the Recorder. See how much memory is available for a Recorder by using ExternalMemorySizeGet.
Recorder
using NUnit.Framework;
using System;
#endif
[Test]
public void Recorder()
const int INPUT_INDEX = 0;
controller.AxisCountSet(1);
Definition rsi.h:5870
Definition rsi.h:11559
void RecorderStart()
Start recording data.
void RecorderStop()
void RecorderReset()
bool RecorderEnabledGet()
RapidCodeOS * OS
Definition rsi.h:3846
Definition rsienums.h:434
RecorderBufferSizeGet, ExternalMemorySizeGet
