#include "SampleAppsHelper.h"
#include "rsi.h"
int main()
const std::string SAMPLE_APP_NAME = "Axis Configuration: Phantom Axis";
int exitCode = -1;
const double positionToleranceMax = std::numeric_limits<double>::max() / 10.0;
std::cout << "Phantom Axis created with index: " << axisIndex << std::endl;
exitCode = 0;
exitCode = -1;
Set the Amp Fault action.
Set the motor type.
static void SetupController(MotionController *controller)
static constexpr int AXIS_COUNT
Number of axes to configure on the controller.
