PathMotion.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: Path Motion.
#include <iostream>
#include <fstream>
#include "SampleApps.h"
int PathMotion::Run()
/* CONSTANTS */
const int AXIS_COUNT = (2);
const int AXIS_X = 0;
const int AXIS_Y = 1;
// Default file path for recording the path followed by the axes
const char* const PATH_MOTION_FILEPATH = "PathMotion.csv";
USE_HARDWARE = false;
/* SAMPLE APP BODY */
Axis* axisX;
Axis* axisY;
MultiAxis* multiAxisXY;
double running_x = 0;
double running_y = 0;
double line_A[2] = { running_x, running_y };
running_x += -0.5;
double line_B[2] = { running_x, running_y };
running_y += -0.5;
double line_C[2] = { running_x, running_y };
//curve down
running_y += (-0.25);
double arc_center_A[2] = { running_x,running_y };
running_x += (0.25);
//curve left
running_x += -0.25;
double arc_center_B[2] = { running_x,running_y };
running_y += -0.25;
//curve up
running_y += 0.25;
double arc_center_C[2] = { running_x,running_y };
running_x += -0.25;
//curve right
running_x += 0.25;
double arc_center_D[2] = { running_x,running_y };
running_y += 0.25;
running_x += -0.5;
running_y += 0.5;
double line_D[2] = { running_x, running_y };
// Create and initialize RsiController class
if (USE_HARDWARE)
axisX->PositionSet(0);
axisX->Abort();
axisY->PositionSet(0);
axisY->Abort();
multiAxisXY->AxisAdd(axisX);
multiAxisXY->AxisAdd(axisY);
// make sure all axes are enabled and ready
multiAxisXY->Abort();
multiAxisXY->ClearFaults();
axisX->Home();
axisY->Home();
// set the trajectory info
multiAxisXY->VectorVelocitySet(1.0 * USER_UNITS);
multiAxisXY->VectorAccelerationSet(10.0 * USER_UNITS);
multiAxisXY->VectorDecelerationSet(10.0 * USER_UNITS);
// start path list
double start_positions[2] = { axisX->CommandPositionGet(),axisY->CommandPositionGet() };
multiAxisXY->PathListStart(start_positions);
// turn on blending (smooth corners)
multiAxisXY->PathBlendSet(true);
// Lines and arcs
multiAxisXY->PathLineAdd(line_A);
multiAxisXY->PathLineAdd(line_B);
multiAxisXY->PathLineAdd(line_C);
multiAxisXY->PathArcAdd(arc_center_A, -90.0);
multiAxisXY->PathArcAdd(arc_center_B, -90.0);
multiAxisXY->PathArcAdd(arc_center_C, -90.0);
multiAxisXY->PathArcAdd(arc_center_D, -90.0);
multiAxisXY->PathLineAdd(line_D);
// end path list
multiAxisXY->PathListEnd();
// execute the motion
multiAxisXY->PathMotionStart();
// log positions
std::ofstream myfile;
myfile.open(PATH_MOTION_FILEPATH);
myfile << "samples,x,y,\n";
while (!multiAxisXY->MotionDoneGet()) {
myfile << controller->SampleCounterGet() << "," << axisX->CommandPositionGet() << "," << axisY->CommandPositionGet() << "\n";
controller->SampleWait(10);
myfile.close();
printf("\n%s\n", PATH_MOTION_FILEPATH);
catch (RsiError const& err)
printf("\n%s\n", err.text);
return -1;
return 0;
double CommandPositionGet()
void AmpDisableActionSet(RSIMotorDisableAction action)
Set the Amp Disable action.
Execute the homing routine.
void PathListStart(const double *const startPosition)
Start a line and arc point list for path motion.
void PathMotionStart()
Start the path motion.
void PathArcAdd(const double *const center, double angle)
Add an arc segment to the path.
void VectorDecelerationSet(double deceleration)
Set the vector deceleration.
void PathLineAdd(const double *const position)
Add a line segment to the path.
void PathBlendSet(bool blend)
Set the blending attribute.
void VectorAccelerationSet(double acceleration)
Set the vector acceleration.
void PathListEnd()
End a line and arc point list for path motion.
void AxisAdd(Axis *axis)
void VectorVelocitySet(double velocity)
Set the vector velocity.
Definition rsi.h:12018
bool MotionDoneGet()
Definition rsi.h:111
@ RSIMotorDisableActionNONE
No action taken when disabled.
Definition rsienums.h:1461
@ RSIActionNONE
Definition rsienums.h:1257
