PVTmotionMultiAxis.cpp
16
17#include "rsi.h" // Import our RapidCode Library.
18#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
19#include "SampleApps.h"
20
21using namespace RSI::RapidCode; // Import the RapidCode namespace
22
24int PVTmotionMultiAxis::Run()
25{
26 /* CONSTANTS */
27 // *NOTICE* The following constants must be configured before attempting to run with hardware.
28
29 // Axis configuration parameters
30 const int AXIS_COUNT = 2;
31 const int AXIS_X = 0;
32 const int AXIS_Y = 1;
33
34 const double USER_UNITS = 1048576;
35
36 // Motion parameters
37 const int POINTS = (3000); //total points used
38 const double TIME_SLICE = (0.001); //each point processed within 1ms
39
40 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
41 USE_HARDWARE = false;
42
43 // The rmpPath only needs to be set if the project directory is different than the rapid setup directory.
44 // *NOTICE* When setting the rmpPath, be sure to uncomment the rmpPath arguement in MotionController::CreateFromSoftware() in the Run() function.
45 const char rmpPath[] = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)
46
47 /* SAMPLE APP BODY */
48
49 // Initialize MotionController class.
50 MotionController *controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
51 SampleAppsHelper::CheckErrors(controller); // [Helper Function] Check that the axis has been initialize correctly.
52
53 // Setup the controller for the appropriate hardware configuration.
54 if (USE_HARDWARE)
55 {
57 }
58 else
59 {
60 SampleAppsHelper::SetupControllerForPhantoms(controller, AXIS_COUNT, { AXIS_X, AXIS_Y });
61 }
62
63 try
64 {
65 // enable one MotionSupervisor for the MultiAxis
66 controller->MotionCountSet(controller->AxisCountGet() + 1);
67
68 // Get Axis X and Y respectively.
69 Axis* axisX = controller->AxisGet(AXIS_X);
71 axisX->UserUnitsSet(USER_UNITS);
73
74 Axis* axisY = controller->AxisGet(AXIS_Y);
76 axisY->UserUnitsSet(USER_UNITS);
78
79 // Initialize a MultiAxis, using the last MotionSupervisor.
80 MultiAxis* multiAxisXY = controller->MultiAxisGet(controller->MotionCountGet() - 1);
82 multiAxisXY->AxisAdd(axisX);
83 multiAxisXY->AxisAdd(axisY);
84
85 long radius = 3; //radius of circle
86
87 double PI = 3.14159265358979323; //variable used in equation to convert degrees to radians
88
89 double degrees = 90.00 / (POINTS); //angle between each point. Used in the equation below.
90
91 double position[POINTS * AXIS_COUNT]; //defining size of position array
92 double vel[POINTS * AXIS_COUNT]; //defining size of velocity array
93 double time[POINTS]; //defining size of time array
94
96 for (int i = 0, x = 0, y = 1; i < POINTS; i++)
97 {
98 position[x] = (radius*cos((i + 1)*degrees*PI / 180.0));
99 position[y] = (radius*sin((i + 1)*degrees*PI / 180.0));
100
101 x = x + 2;
102 y = y + 2;
103
104 time[i] = TIME_SLICE;
105 }
106
108 for (int i = 0, x = 0, y = 1; i < (POINTS - 1); i++)
109 {
110 vel[x] = (position[x + 2] - position[x]) / TIME_SLICE;
111 vel[y] = (position[y + 2] - position[y]) / TIME_SLICE;
112
113 x = x + 2;
114 y = y + 2;
115 }
116
117 //Final two points (X Axis Final Vel, Y Axis Final Vel) need to be set to 0.
118 vel[(POINTS * 2) - 2] = 0; //X Axis
119 vel[(POINTS * 2) - 1] = 0; //Y Axis
120
121 // Set the initial position of the axes.
122 axisX->PositionSet(radius);
123 axisY->PositionSet(0);
124
125 multiAxisXY->Abort();
126 multiAxisXY->ClearFaults();
127 multiAxisXY->AmpEnableSet(true);
128
129 multiAxisXY->MovePVT(position, vel, time, POINTS, -1, false, true);
130 multiAxisXY->MotionDoneWait();
131
132 multiAxisXY->AmpEnableSet(false);
133 }
134 catch (RsiError const& err)
135 {
136 printf("\n%s\n", err.text);
137 return -1;
138 }
139 controller->Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
140 return 0;
141}
int32_t AxisCountGet()
int32_t MotionCountGet()
void AxisAdd(Axis *axis)
@ RSIActionNONE
Definition rsienums.h:1163
