MultiaxisMotion.cpp
Attention
See the following Concept pages for a detailed explanation of this sample: S-Curve Motion.
#include <conio.h>
#include "SampleApps.h"
/*This function will print all the results to the screen*/
void PrintResult(Axis* axisX, Axis* axisY)
printf("Motion Done \n AxisX position-> Commanded: %f \tActual: %f\n",
axisX->ActualPositionGet());
printf(" AxisY position-> Commanded: %f \tActual: %f\n",
axisY->ActualPositionGet());
int MultiaxisMotion::Run()
/* CONSTANTS */
const int AXIS_COUNT = 2;
const int AXIS_X = 0;
const int AXIS_Y = 1;
const int MOTION_COUNT = 1;
// Motion parameters
const double START_POSITION[AXIS_COUNT] = { 0, 0 };
const double END_POSITION[AXIS_COUNT] = { 1, 2 };
const double VELOCITY[AXIS_COUNT] = { 1, 2 };
const double ACCELERATION[AXIS_COUNT] = { 10, 20 };
const double DECELERATION[AXIS_COUNT] = { 10, 20 };
const double JERK_PERCENTAGE[AXIS_COUNT] = { 0, 0 };
USE_HARDWARE = false;
/* SAMPLE APP BODY */
// Create and initialize RsiController class
if (USE_HARDWARE)
axisX->PositionSet(0);
axisX->ErrorLimitActionSet(RSIAction::RSIActionNONE);
axisY->PositionSet(0);
axisY->ErrorLimitActionSet(RSIAction::RSIActionNONE);
multiAxisXY->AxisAdd(axisX);
multiAxisXY->AxisAdd(axisY);
// make sure all axes are enabled and ready
multiAxisXY->Abort();
multiAxisXY->ClearFaults();
// Set SYNC_START motion attribute mask.
multiAxisXY->MotionAttributeMaskOnSet(RSIMotionAttrMask::RSIMotionAttrMaskSYNC_START);
printf("\nMotionStart...");
// Commanding motion using Syncpptart to start motion for both the axis at the same time.
multiAxisXY->MoveSCurve(END_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENTAGE);
// Calling function created on top.
PrintResult(axisX, axisY);
// Set SYNC_END motion attribute mask
multiAxisXY->MotionAttributeMaskOnSet(RSIMotionAttrMask::RSIMotionAttrMaskSYNC_END);
// Commanding motion using SyncEnd to end motion for both the axis at the same time.
multiAxisXY->MoveSCurve(START_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENTAGE);
printf("\nTrapezoidal Motion Done\n");
// Disable the all the axes
catch (RsiError const& err)
printf("\n%s\n", err.text);
return -1;
controller->Delete();
return 0;
double CommandPositionGet()
double ActualPositionGet()
Definition rsi.h:5556
int32_t AxisCountGet()
int32_t MotionCountGet()
Definition rsi.h:795
Point-to-point S-Curve Move.
void AxisAdd(Axis *axis)
Definition rsi.h:10251
int32_t MotionDoneWait()
Definition rsi.h:106
