using RSI.RapidCode.dotNET;
using NUnit.Framework;
using System;
using System.Linq;
using System.Threading;
using System.IO;
using System.Runtime.InteropServices;
#if DOXYGEN
#endif
[TestFixture]
[Category("Software")]
public class GcodeMotion : SampleAppTestBase
[SetUp]
public void Setup()
[TearDown]
public void Teardown()
robot = null;
jointsMultiAxis?.
Abort();
Thread.Sleep(50);
var actualUnits = model.
UnitsGet();
Assert.That(actualUnits, Is.EqualTo(expectedUnits), $"Expected model units to be '{expectedUnits}' but was '{actualUnits}' instead!");
var actualName = model.
NameGet();
Assert.That(actualName, Is.EqualTo(expectedName), $"Expected model name to be '{expectedName}' but was '{actualName}' instead!");
[Test]
public void GcodeBasic()
string gcodeProgram = "G91; Sets the programming mode to RELATIVE\n" +
"G64; Turns off exact stop mode(Default)\n" +
"G1 X1.0 Y0.0 Z0.0 A1.0 F60.0; Move on USERUNIT in positive x direction at 60in/min. Moves Free axis A to position 1.0.\n" +
"G3 X1 Y1 I0 J1; Counter clockwise arc with a center point of 0,1,0 and end point of 1,1,0 relative to the current position\n" +
"M80; Show how to use an M-code with GcodeCallback!\n";
Axis[] axes =
new Axis[] { x_axis, y_axis, z_axis, a_axis };
jointsMultiAxis.
AxesAdd(axes, axes.Length);
Console.WriteLine("Error loading G-Code: " + e.Message);
throw e;
Console.WriteLine(
"G-code estimated run time: " + robot.
Gcode.
DurationGet() +
" seconds");
Int64 activeLineNumber = 0;
do
Thread.Sleep(200);
Console.WriteLine("G-Code Line Number: " + activeLineNumber);
Assert.That(robot.
Gcode.
LineCountGet(), Is.EqualTo(gcodeProgram.Count(c => c.Equals(
'\n'))));
VerifyModel(robot.
ModelGet(), modelName);
[Test]
public void ChangingUnits()
Axis[] axes =
new Axis[] { x_axis, y_axis, z_axis, a_axis, b_axis, c_axis };
jointsMultiAxis.
const string modelName = "RSI_XYZABC_Centimeters";
VerifyModel(robot.
ModelGet(), modelName, units);
void FreeAxisLetterSet(const char gcodeLetter, const int32_t freeAxisIndex)=0
Map a letter in a Gcode file to a free axis. It will be used to specify the free axis' motion.
void CallbackRegister(Cartesian::GcodeCallback *callback, bool containsMotion=false)=0
Register a catch-all M-code callback.
int32_t LineCountGet()=0
Get the number of lines in the last loaded G-Code program.
int32_t ExecutingLineNumberGet()=0
Get the currently executing line number.
LinearUnits UnitsGet()=0
Get the currently active unit as set by G20/G21.
void AccelerationRateSet(double programmingUnitsPerMinuteSquared)=0
REQUIRED before Load() or LoadFile(). Sets the target acceleration for the machine (units/minute^2)....
void UnitsSet(LinearUnits units)=0
Set the currently active unit (same as calling G20/G21)
double DurationGet()=0
Get the time duration required to run the loaded G-Code program in seconds.
void FeedRateSet(double programmingUnitsPerMinute)=0
REQUIRED before Load() or LoadFile() if your g-code does not have 'F' in its contents....
void Load(const char *const text)=0
Load a G-code program from a string.
void Run()=0
Run the loaded G-Code file (or string). The behavior is non-blocking. Use DoneWait() to block.
Handles callbacks for M-codes within a G-code file.
bool IsRunning()=0
Returns true if a Gcode program is executing, false otherwise.
void FreeAxisAdd(const ModelAxisMapping &freeAxis)
Map a free axis in the kinematic model. The Axis' DefaultVelocity/Acceleration will be used for free ...
uint64_t MotionDoneWait()=0
void EStop()=0
void ClearFaults()=0
Delete a Robot.
RSI::RapidCode::Cartesian::Gcode * Gcode
An object to load and run Gcode files.
void AxisRemoveAll()
int32_t ErrorLogCountGet()
make a Callback class and register it with the Gcode object
CartesianAxis
LinearUnits
const char * LineText
The actual line content from the G-code file.
int32_t LineNumber
The line number in the G-code file where the M-code is encountered.
Holds data for the G-code M-code callback mechanism.
Data for adding joint or free-axis mappings when building a kinematic model.
