CalculateAccelerationFromVelocity.cpp
10#include "SampleAppsHelper.h" // Import our helper functions.
11#include "rsi.h" // Import our RapidCode Library.
12
13using namespace RSI::RapidCode; // Import our RapidCode namespace
14
15int main()
16{
17 // Print a start message to indicate that the sample app has started
18 const std::string SAMPLE_APP_NAME = "Math Blocks: Calculate Acceleration from Velocity";
19 SampleAppsHelper::PrintHeader(SAMPLE_APP_NAME);
20
22 /* CONSTANTS */
23 /* *NOTICE* The following constants must be configured before attempting to run with hardware. */
24 const int NUM_AXES = 1; // The number of axes to configure
25 const int AXIS_INDEX = 0; // The index of the axis to configure
26 const double VELOCITY = 1.0; // the velocity to move the axis
27 const double ACCELERATION = 0.123; // something small so we can check the MathBlock is working
28
29 /* RAPIDCODE INITIALIZATION */
30 // Create the Controller
32 MotionController *controller = MotionController::Create(&params);
33
34 // Variables to store initial object counts to restore later (starts at -1 to indicate it has not been set)
35 int initialMathBlockCount = -1;
36
37 // Set the exit code to an error value.
38 int exitCode = -1;
39 try // Ensure that the controller is deleted if an error occurs.
40 {
41 // Prepare the controller as defined in SampleAppsHelper.h depending on the configuration
43 SampleAppsHelper::SetupController(controller, NUM_AXES);
44
45 // Save initial object counts to restore later
46 initialMathBlockCount = controller->MathBlockCountGet();
47
48 /* SAMPLE APP BODY */
49
50 /* Configure the controller object counts */
51 // Normally you would set the number of axes here, but for samples that is handled in the SampleAppsHelper::SetupController function
52 // controller->AxisCountSet(NUM_AXES);
53
54 // Add the two MathBlocks needed for this sample
55 const int subtractionMathBlockIndex = initialMathBlockCount;
56 const int previousVelocityMathBlockIndex = initialMathBlockCount + 1;
57 controller->MathBlockCountSet(initialMathBlockCount + 2);
58
59 // Get the axis and make sure the axis is not moving and clear any faults
60 Axis *axis = controller->AxisGet(AXIS_INDEX);
62 axis->Abort();
63 axis->ClearFaults();
64
65 // Read the configuration of both MathBlocks
66 MotionController::MathBlockConfig subtractionConfig = controller->MathBlockConfigGet(subtractionMathBlockIndex);
67
68 // This index must be greater than the subtraction math block index, so the subtraction data is
69 // one sample old
70 MotionController::MathBlockConfig previousVelocityConfig = controller->MathBlockConfigGet(previousVelocityMathBlockIndex);
71
72 // Set the axis to use the command velocity as the input for the MathBlock
73 RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = RSIAxisAddressType::RSIAxisAddressTypeCOMMAND_VELOCITY;
74
75 // Configure the first MathBlock to subtract the previous velocity from the current velocity
76 // Current velocity:
77 subtractionConfig.InputAddress0 = axis->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
78 subtractionConfig.InputDataType0 = RSIDataType::RSIDataTypeDOUBLE;
79
80 // Previous velocity: (as was calculated by the second MathBlock, so we use its ProcessValue)
81 subtractionConfig.InputAddress1 =
82 controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, previousVelocityMathBlockIndex);
83 subtractionConfig.InputDataType1 = RSIDataType::RSIDataTypeDOUBLE;
84
85 subtractionConfig.ProcessDataType = RSIDataType::RSIDataTypeDOUBLE;
86 subtractionConfig.Operation = RSIMathBlockOperation::RSIMathBlockOperationSUBTRACT;
87
88 // Write 1.0 to the first UserBuffer entry so the second MathBlock can use it for multiplication
89 uint64_t userBufferAddr0 = controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, 0);
90 controller->MemoryDoubleSet(userBufferAddr0, 1.0);
91
92 // Configure the second MathBlock to multiply the current velocity by 1.0 (which we'll use for
93 // the previous sample's velocity)
94 previousVelocityConfig.InputAddress0 = axis->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
95 previousVelocityConfig.InputDataType0 = RSIDataType::RSIDataTypeDOUBLE;
96 previousVelocityConfig.InputAddress1 = userBufferAddr0;
97 previousVelocityConfig.InputDataType1 = RSIDataType::RSIDataTypeDOUBLE;
98 previousVelocityConfig.ProcessDataType = RSIDataType::RSIDataTypeDOUBLE;
99 previousVelocityConfig.Operation = RSIMathBlockOperation::RSIMathBlockOperationMULTIPLY;
100
101 // Set the MathBlock configurations
102 controller->MathBlockConfigSet(subtractionMathBlockIndex, subtractionConfig);
103 controller->MathBlockConfigSet(previousVelocityMathBlockIndex, previousVelocityConfig);
104
105 // Wait a sample so we know the RMP is now processing the newly configured MathBlocks
106 controller->SampleWait(1);
107
108 // Set the axis to move with a very small acceleration so we can check the MathBlock is working
109 axis->AmpEnableSet(true); // Enable the motor.
110 axis->MoveVelocity(VELOCITY, ACCELERATION);
111
112 // Wait several samples so we know the RMP is now processing the move command and accelerating
113 controller->SampleWait(10);
114
115 // Keep in mind firmware velocity is in counts per sample, so we need to convert to UserUnits
116 // per second squared
117 double calculatedVelocityDelta = controller->MathBlockProcessValueGet(subtractionMathBlockIndex).Double;
118
119 // Reduce the velocity back to 0
120 axis->MoveVelocity(0, ACCELERATION);
121
122 axis->MotionDoneWait(); // Wait for the axis to finish moving.
123 axis->AmpEnableSet(false); // Disable the motor.
124
125 // Convert to UserUnits per second squared
126 double calculatedAcceleration = calculatedVelocityDelta * controller->SampleRateGet() * controller->SampleRateGet() / axis->UserUnitsGet();
127 std::cout << "Calculated acceleration from MathBlock: " << calculatedAcceleration << std::endl;
128
129 // Check that the newly calculated acceleration is as expected
130 if (std::abs(calculatedAcceleration - ACCELERATION) <= 0.000001)
131 {
132 std::cout << "The MathBlock is calculating the Axis' acceleration by subtracting previous velocity from current velocity." << std::endl;
133 exitCode = 0;
134 }
135 else
136 {
137 std::cerr << "Error: The calculated acceleration does not match the expected value" << std::endl;
138 exitCode = -1;
139 }
140 }
141 catch (const std::exception &ex)
142 {
143 std::cerr << ex.what() << std::endl;
144 exitCode = -1;
145 }
146 // Restore the object counts to the original values
147 if (initialMathBlockCount != -1) { controller->MathBlockCountSet(initialMathBlockCount); }
148 // Note: The axis count is handled by the SampleAppsHelper::Cleanup function
149
150 // Clean up the controller and any other objects as needed
151 SampleAppsHelper::Cleanup(controller);
152
153 // Delete the controller as the program exits to ensure memory is deallocated in the correct order
154 controller->Delete();
156
157 // Print a message to indicate the sample app has finished and if it was successful or not
158 SampleAppsHelper::PrintFooter(SAMPLE_APP_NAME, exitCode);
159
160 return exitCode;
161}
double UserUnitsGet()
Definition rsi.h:5870
int32_t MathBlockCountGet()
Definition rsi.h:800
int32_t MotionDoneWait()
Definition rsienums.h:434
Definition rsi.h:866
RSIDataType ProcessDataType
Data type for processing.
Definition rsi.h:3824
Definition rsi.h:3817
uint64_t InputAddress0
Definition rsi.h:3818
RSIDataType InputDataType0
Definition rsi.h:3819
uint64_t InputAddress1
Definition rsi.h:3820
RSIDataType InputDataType1
Definition rsi.h:3821
Definition rsi.h:3825
double Double
Definition rsi.h:477
