Motion: Point-to-Point
Learn how to perform various types of motion.
In this page:
📜 Motion: Point-to-Point
Learn how to perform point-to-point motion including absolute moves, relative moves, S-curve motion, and velocity motion with Final Velocity Motion 📖 .
const int NUM_AXES = 1; // the number of axes to configure
// motion Parameters
const double POSITION_0 = 0; // specify the start position
const double POSITION_1 = 0.5; // specify the position to move to
const double VELOCITY = 1; // specify your velocity - units: UserUnits/Sec
const double ACCELERATION = 10; // specify your acceleration - units: UserUnits/Sec^2
const double DECELERATION = 10; // specify your deceleration - units: UserUnits/Sec^2
const double JERK_PERCENT = 50; // specify your jerk percent (0.0 to 100.0)
const double FINAL_VELOCITY = 0.5; // specify your final velocity - units: UserUnits/Sec
Source: point-to-point.cpp
📜 Absolute Motion
Demonstrates how to perform absolute trapezoidal motion moves.
std::cout << "Absolute (Trapezoidal) Motion:" << std::endl;
axis->MoveTrapezoidal(POSITION_1, VELOCITY, ACCELERATION, DECELERATION);
axis->MotionDoneWait(TIMEOUT);
axis->MoveTrapezoidal(POSITION_0, VELOCITY, ACCELERATION, DECELERATION);
📜 Relative Motion
Demonstrates how to perform relative motion moves with S-curve profiles.
std::cout << "Relative Motion:" << std::endl;
axis->MoveRelative(POSITION_1 - POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
axis->MoveRelative(POSITION_0 - POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
📜 S-Curve Motion
Demonstrates how to perform S-curve motion using default motion parameters.
std::cout << "SCurve Motion:" << std::endl;
axis->MoveSCurve(POSITION_1);
axis->MoveSCurve(POSITION_0);
📜 S-Curve Motion with Final Velocity
Demonstrates how to perform S-curve motion with a specified final velocity.
std::cout << "SCurve Motion with Final Velocity:" << std::endl;
std::cout << "Final Velocity: " << FINAL_VELOCITY << std::endl;
axis->MoveSCurve(POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY);
HelperAtVelocityWait(controller, axis, TIMEOUT);
std::cout << "Final Velocity: " << 0 << std::endl;
axis->MoveSCurve(POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, 0);
📜 Velocity Move
Demonstrates how to perform velocity moves to accelerate and decelerate to target velocities.
std::cout << "Velocity Move:" << std::endl;
std::cout << "Accelerating to velocity: " << VELOCITY << std::endl;
axis->MoveVelocity(VELOCITY, ACCELERATION);
std::cout << "Decelerating to velocity: " << 0 << std::endl;
axis->MoveVelocity(0, DECELERATION);
