Motion: Update Buffer Points
Update Buffer Points sample application.
This application is designed to assist in managing the buffer in streaming motion. The behavior of continuing streaming motion (with the parameter final=false) will increment the MotionID (retrieved by calling MotionIdExecutingGet()). It will also reset the motion element ID to 0 (retrieved with MotionElementIdExecutingGet()).
The number sent points needs to be managed, somehow. This sample does so by using a fixed buffer size and keeping at least one buffer associated with a Motion ID queued. This should be changed as appropiate.
Precondition
#include <cassert>
#include <cmath>
#include "SampleApps.h"
int UpdateBufferPoints::Run()
/* CONSTANTS */
const int AXIS_COUNT = 1; // number of axes
const int AXIS_NUMBER = 0; // axis number
const double USER_UNITS = 1048576; // counts per unit / user units (set as appropiate)
// Motion parameters
const double TIME_SLICE = 0.001; // 0.001s = 1ms
const int REVS = 2; // number of revolutions
const int RPS = 1; // revs / sec
const int TOTAL_POINTS = (int)(REVS / TIME_SLICE / RPS); // total number of points
const int BUFFER_SZ = 100; // Number of points to send in a buffer
const int EMPTY_CT = 10; // Number of points that remains in the beffer before an e-stop
USE_HARDWARE = false;
/* SAMPLE APP BODY */
// Initizalize the controller from software w/ multiple axes
if (USE_HARDWARE)
MultiAxis* multiAxis;
// add an additional axis for the multiaxis supervisor
controller->MotionCountSet(AXIS_COUNT + 1);
// create the multiaxis using the ID of the first free axis (0 indexed)
multiAxis = controller->MultiAxisGet(AXIS_COUNT);
// Get the axis and configure it
axis->PositionSet(0); // Make sure motor starts at position 0 everytime.
axis->UserUnitsSet(USER_UNITS); // Change your user units.
multiAxis->AxisAdd(axis); // Add the axis to the multiaxis supervisor
// populate the positions and times
std::vector<double> positions, times;
for (int i = 0; i < TOTAL_POINTS; i += AXIS_COUNT)
positions.push_back(i * TIME_SLICE * RPS);
times.push_back(TIME_SLICE);
// prepare the controller (and drive)
multiAxis->Abort();
multiAxis->ClearFaults();
assert(multiAxis->StateGet() == RSIState::RSIStateIDLE);
multiAxis->AmpEnableSet(true);
// reset the motion ID to 0
multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0], &times[0], 1, -1, false, true);
multiAxis->MotionIdSet(0);
// Establish how to keep track of what blocks have been sent
int curMotionElementID = 0, curMotionID = 0, finalMotionID = 0;
int numPointsToSend = BUFFER_SZ;
int endOfLastSent = 0;
bool exitCondition = false;
// Set up a motion hold gate so we can start buffering blocks
const int motionHoldGate = 3;
controller->MotionHoldGateSet(motionHoldGate, true);
multiAxis->MotionHoldGateSet(motionHoldGate);
for (int i = 0; i < 2; ++i)
multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0] + endOfLastSent * AXIS_COUNT, &times[0] + endOfLastSent, numPointsToSend, EMPTY_CT, false, exitCondition);
endOfLastSent += numPointsToSend;
++finalMotionID;
// Set up the interrupt frequency period
controller->SyncInterruptPeriodSet(10); // this generates an interrupt every x cycles of a 1KHz sample rate
// With our timeslices of 1ms, this is 10*1ms=10ms
controller->MotionHoldGateSet(motionHoldGate, false); // release the hold gate to start moving
while (!exitCondition)
int32_t sampleRecieved = controller->SyncInterruptWait(); // see above for timing
curMotionID = multiAxis->MotionIdExecutingGet(); // this takes an unspecified amount of time (non-rtos) so this is going to be called sometime after the interrupt gets handled.
// There's an additional delay to retrieve the data as well.
curMotionElementID = multiAxis->MotionElementIdExecutingGet();
Each MovePT assigns a new MotionID for each call to a move update (with the bufferred points)
Working under the assumption that each Buffer gets a new ID, send two (or several) smaller ones
and when the change in IDs is greater than some number, send a new one
// change this logic to manage the number of buffered moves (and points) as appropiate
// generate points as appropiate
if (std::abs(finalMotionID - curMotionID) < 2)
// check end condition
if (TOTAL_POINTS <= (endOfLastSent + BUFFER_SZ))
numPointsToSend = TOTAL_POINTS - endOfLastSent; // send the remaining points
exitCondition = true;
printf("MotionID %d\nEnd of Last Sent %d\nElement ID %d\nNum to Send %d\nIs Done %s\n===========================================\n\n",
curMotionID, endOfLastSent, curMotionElementID, numPointsToSend, exitCondition ? "yes" : "no");
++finalMotionID;
printf("Updates Done. Waiting to finish motion.\n");
multiAxis->MotionDoneWait();
printf("Motion Complete. Final Motion ID: %d\tFinal Element ID %d\n", multiAxis->MotionIdExecutingGet(), multiAxis->MotionElementIdExecutingGet());
multiAxis->EStopAbort();
catch (RsiError const& err) {
printf("\n%s\n", err.text);
return -1;
controller->Delete();
return 0;
uint16_t MotionElementIdExecutingGet()
void AxisAdd(Axis *axis)
Definition rsi.h:12226
void MotionIdSet(uint16_t id)
Set the Motion identifier.
RSIState StateGet()
void MotionHoldGateSet(bool hold)
Set the Motion Hold Gate.
void EStopAbort()
E-Stop, then abort an axis.
Definition rsi.h:111
@ RSIMotionTypePT
Definition rsienums.h:1180
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIStateIDLE
Idle, ready for anything.
Definition rsienums.h:1016
