Motion: Path
Path Motion sample application.
This sample app will command a path motion for two axis with different points and desired velocity, acceleration and deceleration specified by user.
Different positions have to be secified within 'PathListStart' and 'PathListEnd' using function 'PathLineAdd' where the coordinates are declared in line_A, line_B and etc.
Function 'PathRatioSet(ratio)' is used to define different ratios between the two different drive's encoder resolution. As the name 'PathMotionStart' suggests will simply execute motion for axes.
Precondition
#include <iostream>
#include <fstream>
#include "SampleApps.h"
int PathMotion::Run()
/* CONSTANTS */
const int AXIS_COUNT = (2);
const int AXIS_X = 0;
const int AXIS_Y = 1;
// Default file path for recording the path followed by the axes
const char* const PATH_MOTION_FILEPATH = "PathMotion.csv";
USE_HARDWARE = false;
/* SAMPLE APP BODY */
Axis* axisX;
Axis* axisY;
MultiAxis* multiAxisXY;
double running_x = 0;
double running_y = 0;
double line_A[2] = { running_x, running_y };
running_x += -0.5;
double line_B[2] = { running_x, running_y };
running_y += -0.5;
double line_C[2] = { running_x, running_y };
//curve down
running_y += (-0.25);
double arc_center_A[2] = { running_x,running_y };
running_x += (0.25);
//curve left
running_x += -0.25;
double arc_center_B[2] = { running_x,running_y };
running_y += -0.25;
//curve up
running_y += 0.25;
double arc_center_C[2] = { running_x,running_y };
running_x += -0.25;
//curve right
running_x += 0.25;
double arc_center_D[2] = { running_x,running_y };
running_y += 0.25;
running_x += -0.5;
running_y += 0.5;
double line_D[2] = { running_x, running_y };
// Create and initialize RsiController class
if (USE_HARDWARE)
axisX->PositionSet(0);
axisX->Abort();
axisY->PositionSet(0);
axisY->Abort();
multiAxisXY->AxisAdd(axisX);
multiAxisXY->AxisAdd(axisY);
// make sure all axes are enabled and ready
multiAxisXY->Abort();
multiAxisXY->ClearFaults();
axisX->Home();
axisY->Home();
// set the trajectory info
multiAxisXY->VectorVelocitySet(1.0 * USER_UNITS);
multiAxisXY->VectorAccelerationSet(10.0 * USER_UNITS);
multiAxisXY->VectorDecelerationSet(10.0 * USER_UNITS);
// start path list
double start_positions[2] = { axisX->CommandPositionGet(),axisY->CommandPositionGet() };
multiAxisXY->PathListStart(start_positions);
// turn on blending (smooth corners)
multiAxisXY->PathBlendSet(true);
// Lines and arcs
multiAxisXY->PathLineAdd(line_A);
multiAxisXY->PathLineAdd(line_B);
multiAxisXY->PathLineAdd(line_C);
multiAxisXY->PathArcAdd(arc_center_A, -90.0);
multiAxisXY->PathArcAdd(arc_center_B, -90.0);
multiAxisXY->PathArcAdd(arc_center_C, -90.0);
multiAxisXY->PathArcAdd(arc_center_D, -90.0);
multiAxisXY->PathLineAdd(line_D);
// end path list
multiAxisXY->PathListEnd();
// execute the motion
multiAxisXY->PathMotionStart();
// log positions
std::ofstream myfile;
myfile.open(PATH_MOTION_FILEPATH);
myfile << "samples,x,y,\n";
while (!multiAxisXY->MotionDoneGet()) {
myfile << controller->SampleCounterGet() << "," << axisX->CommandPositionGet() << "," << axisY->CommandPositionGet() << "\n";
controller->SampleWait(10);
myfile.close();
printf("\n%s\n", PATH_MOTION_FILEPATH);
catch (RsiError const& err)
printf("\n%s\n", err.text);
return -1;
return 0;
double CommandPositionGet()
void AmpDisableActionSet(RSIMotorDisableAction action)
Set the Amp Disable action.
Execute the homing routine.
void PathListStart(const double *const startPosition)
Start a line and arc point list for path motion.
void PathMotionStart()
Start the path motion.
void PathArcAdd(const double *const center, double angle)
Add an arc segment to the path.
void VectorDecelerationSet(double deceleration)
Set the vector deceleration.
void PathLineAdd(const double *const position)
Add a line segment to the path.
void PathBlendSet(bool blend)
Set the blending attribute.
void VectorAccelerationSet(double acceleration)
Set the vector acceleration.
void PathListEnd()
End a line and arc point list for path motion.
void AxisAdd(Axis *axis)
void VectorVelocitySet(double velocity)
Set the vector velocity.
Definition rsi.h:12226
bool MotionDoneGet()
Definition rsi.h:111
@ RSIMotorDisableActionNONE
No action taken when disabled.
Definition rsienums.h:1461
@ RSIActionNONE
Definition rsienums.h:1257
