Real-Time Tasks
Learn how to implement and work with real-time tasks.
In this page:
⚙️ Real-Time Tasks: Shared Global Data
This is the global data structure shared between Real-Time Tasks 📖 and the main application that is used in all the RTTasks samples.
Defined in the RTTaskFunctions library:
struct GlobalData
GlobalData() { std::memset(this, 0, sizeof(*this)); }
GlobalData(GlobalData&& other) { std::memcpy(this, &other, sizeof(*this)); }
// A shared integer counter
RSI_GLOBAL(int64_t, counter);
// Shared values for FollowSensor
RSI_GLOBAL(int32_t, startingSample);
RSI_GLOBAL(double, sensorValue);
inline constexpr GlobalMetadataMap<RSI::RapidCode::RealTimeTasks::GlobalMaxSize> GlobalMetadata(
REGISTER_GLOBAL(counter),
REGISTER_GLOBAL(startingSample),
REGISTER_GLOBAL(sensorValue),
Source: rttaskglobals.h
📜 Real-Time Tasks: Hello RTTasks
Learn the basics of creating and running Real-Time Tasks 📖 with proper initialization and execution patterns.
// tell the task manager the name of the function to run as a task, the name
// of the library that contains the function, and the directory where the
// library is located. The Increment function is defined in the RTTaskFunctions library.
// it increments a global counter variable.
std::cout << "Submitting task..." << std::endl;
RTTaskCreationParameters params("Increment");
RTTask task = manager->TaskSubmit(params);
// wait for the task to run for a bit
// get the counter global tag to see if the task ran correctly
std::cout << "Getting counter global tag..." << std::endl;
RSI::RapidCode::FirmwareValue counter = manager->GlobalValueGet("counter");
if (counter.Int64 <= 0)
// the task did not run correctly
exitCode = -1;
std::cout << "Counter is not greater than 0. The task did not run correctly." << std::endl;
// the task ran correctly
exitCode = 0;
std::cout << "Counter: " << counter.Int64 << std::endl;
Source: hello-rttasks.cpp
// increment the counter in the global data
RSI_TASK(Increment)
data->counter += 1;
Source: rttaskfunctions.cpp
📜 Real-Time Tasks: Follow Sensor
Learn how to implement sensor-following motion patterns using Real-Time Tasks 📖 for continuous motion generation.
// configure the axis
Axis *axis = controller->AxisGet(0);
axis->PositionSet(0);
axis->AmpEnableSet(true);
// create the task manager
RTTaskManagerCreationParameters parameters = RTTaskHelper::GetTaskManagerCreationParameters();
std::cout << "Creating task manager..." << std::endl;
manager = RTTaskManager::Create(parameters);
Helpers::CheckErrors(&manager.value());
// List all globals defined in RTTaskFunctions library
PrintGlobals(manager.value());
// call the initialization task to initialize the global variables and get pointers to RapidCode objects
// in the RTTaskFunctions library. This needs to be called before any task that uses RapidCode objects.
RTTaskHelper::SubmitInitializationTask(manager.value());
// library is located. The FollowSensor function is defined in the RTTaskFunctions library.
// It moves the axis back and forth based on a simulated sensor value.
RTTaskCreationParameters params("FollowSensor");
params.Period = 10;
// Print the submitted tasks
PrintTasks(manager.value());
// Let the task run while we log information
PrintStatusWhileRunning(manager.value(), axis);
// Wait until either the task has run at least 300 times (in total) or 500ms passes
// Stop the task
task.Stop();
axis->MotionDoneWait(TIMEOUT_MS); // The axis might still be moving from the task, so wait for it to finish
axis->AmpEnableSet(false);
// Use the RTTaskStatus struct to check the execution count and state
RTTaskStatus taskStatus = task.StatusGet();
int64_t executionCount = taskStatus.ExecutionCount;
RTTaskState taskState = taskStatus.State;
if (executionCount <= 0)
exitCode = -1;
std::cout << "Execution count is not greater than 0. The task did not run correctly." << std::endl;
exitCode = 0;
std::cout << "Execution count: " << executionCount << " (>= 300 expected)" << std::endl;
// Print the final axis position
std::cout << "Axis position: " << axis->CommandPositionGet() << std::endl;
// Print the task state
std::cout << "State: " << RTTaskHelper::StateToString(taskState) << " (DISABLED expected)" << std::endl;
Source: follow-sensor.cpp
// move the axis to follow a simulated sensor value
RSI_TASK(FollowSensor)
MotionController *controller = RTMotionControllerGet();
if (data->startingSample == 0) {
data->startingSample = controller->SampleCounterGet();
data->sensorValue = getSensorValue(controller, data->startingSample);
RTAxisGet(0)->MoveTrapezoidal(data->sensorValue, 5, 10, 10);
⚙️ Real-Time Tasks: Task Manager Creation Parameters
Learn how to configure RTTaskManager's for different platforms and builds.
// get the creation parameters for the task manager
#if defined(WIN32) && defined(NDEBUG)
// if we are on windows and not debug, then we need to create an intime task manager
RTTaskManagerCreationParameters GetTaskManagerCreationParameters()
RTTaskManagerCreationParameters parameters;
std::snprintf(
parameters.RTTaskDirectory,
RTTaskManagerCreationParameters::DirectoryLengthMaximum,
RMP_INSTALL_PATH // the rmp install directory
parameters.Platform = PlatformType::INtime;
std::snprintf(
parameters.NodeName,
RTTaskManagerCreationParameters::NameLengthMaximum,
"NodeA"
return parameters;
#else
// otherwise, we are on linux or debug, so we can create a native task manager
std::snprintf(
// for linux real-time set this to an isolated core
// parameters.CpuCore = -1;
return parameters;
#endif // defined(WIN32) && defined(NDEBUG)
Source: rttasks-helpers.h
⚙️ Real-Time Tasks: Initialize RapidCode Objects
Learn how to submit an initialization task that primes RapidCode objects before real-time execution.
// this calls a task to initialize the global variables and get pointers to rapidcode objects
// in the rttaskfunctions library. it needs to be called before any task
// that uses rapidcode objects.
void SubmitInitializationTask(RTTaskManager &manager)
std::cout << "Running initialization task..." << std::endl;
RTTaskCreationParameters initParams("Initialize");
initParams.Repeats = RTTaskCreationParameters::RepeatNone;
RTTask task = manager.TaskSubmit(initParams);
constexpr int timeoutMs = 5000;
task.ExecutionCountAbsoluteWait(1, timeoutMs); // wait for the task to execute once.
// initialize the global data and random number generator
RSI_TASK(Initialize)
data->counter = 0;
data->sensorValue = 0;
data->startingSample = 0;
std::srand(std::time(nullptr));
