RTTaskCreationParameters specifies all the information required to create and configure a real-time task, including the function to execute, priority, and whether to enable execution timing. Use with RTTaskManager::TaskSubmit() and see Real-Time Tasks for more information.
More...
| | RTTaskCreationParameters (const char *const argFunctionName, const char *const argLibraryName=nullptr, const char *const argLibraryDirectory=nullptr) |
| | Constructor with function name and library details.
bool | EnableTiming = EnableTimingDefault |
| | Whether to enable timing measurements for the task. Keep in mind, enabling timing does add a small amount of overhead to the task execution.
char | FunctionName [NameLengthMaximum] = {0} |
| | Name of the task function to execute.
char | LibraryDirectory [DirectoryLengthMaximum] = {0} |
| | Path to the directory containing the library with the task function.
char | LibraryName [NameLengthMaximum] = "RTTaskFunctions" |
| | Name of the library containing the task function.
int32_t | Period = PeriodDefault |
| | Execution period of the task in RMP sample periods.
int32_t | Phase = PhaseDefault |
| | Phase offset for task execution. For example, if you have 4 tasks with a period of 4, you can set the phase of each task to 0, 1, 2, and 3 so that they don't all execute on the same sample period.
TaskPriority | Priority = PriorityDefault |
| | Priority of the task.
int32_t | Repeats = RepeatNone |
| | Number of times the task should execute (RepeatForever for infinite, 0 for none (one-shot)).
char | UserLabel [NameLengthMaximum] = {0} |
| | User-defined label for the task. Empty UserLabels will default to the FunctionName. UserLabels must be unique.
static constexpr int32_t | DirectoryLengthMaximum = 256 |
| | Maximum length of the library directory path.
static constexpr bool | EnableTimingDefault = false |
| | Default setting for timing measurements.
static constexpr const char *const | LibraryNameDefault = "RTTaskFunctions" |
| | Default library name for the task function.
static constexpr int32_t | NameLengthMaximum = 64 |
| | Maximum length of name fields (library, function, user label).
static constexpr int32_t | PeriodDefault = 1 |
| | Default execution period in RMP sample periods.
static constexpr int32_t | PhaseDefault = 0 |
| | Default phase offset for task execution.
static constexpr TaskPriority | PriorityDefault = TaskPriority::Medium |
| | Default priority for real-time tasks.
static constexpr int32_t | RepeatForever = -1 |
| | Special value to indicate the task should repeat forever.
static constexpr int32_t | RepeatNone = 0 |
| | Special value to indicate the task should not repeat.
