◆ RecorderCountSet()
void RecorderCountSet ( int32_t recorderCount)
RecorderCountSet will configure the number of Recorders processed by the controller firmware .
recorderCountThe Recorder count.
Monitoring: Recorder
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:12773
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
fGet
