starter-template.cpp
See 🧩 Template 📜 for a detailed explanation of this sample code.
/* This sample app demonstrates a basic template structure for building
RapidCode C++ applications.
#include "helpers.h" // import our helper functions
#include "config.h" // import our configuration
#include "rsi.h" // import our RapidCode Library
using namespace RSI::RapidCode; // import the RapidCode namespace
int main()
const std::string SAMPLE_APP_NAME = "📜 Template: Basic Structure";
/* CONSTANTS */
const int NUM_AXES = 0; // the number of axes to configure, default is 0 for this template
// create the controller
// set the exit code to an error value
int exitCode = -1;
try // ensure that the controller is deleted if an error occurs
// normally you would set the number of axes here, but for samples that is handled in the Config::SetupController function
/* INSERT YOUR CONFIGURATION CODE HERE */
// axis *axis = controller->AxisGet(0);
/* INSERT YOUR APPLICATION CODE HERE */
std::cout << "Hello World!" << std::endl;
exitCode = 0; // set the exit code to success.
exitCode = -1;
Config::Cleanup(controller);
controller->Delete();
Definition config.h:147
Definition config.h:81
[SetupController]
Definition config.h:206
Definition helpers.h:87
[NetworkShutdown]
Definition helpers.h:205
[PrintHeader]
Definition helpers.h:221
Definition rsi.h:872
