record-performance.cpp
This sample demonstrates how to record and analyze performance metrics
including firmware and network timing statistics.
#include <iomanip>
// helper function to calculate the minimum, maximum, and average of a vector of integers
static std::vector<int> MinMaxAvg(std::vector<int> data)
int min = data[0];
int max = data[0];
int sum = 0;
for (int i = 0; i < data.size(); i++)
if (data[i] < min)
min = data[i];
if (data[i] > max)
max = data[i];
sum += data[i];
int avg = sum / data.size();
return {min, max, avg};
int main()
const std::string SAMPLE_APP_NAME = "📜 Utilities: Record Performance";
/* CONSTANTS */
const int RECORD_PERIOD_SAMPLES = 1; // Number of samples between each record.
const int RECORD_TIME = 1000; // Time in milliseconds to record for.
// create the controller
/* SAMPLE APP BODY */
// check if the network is started
int valuesPerRecord;
bool networkTimingEnabled = false;
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL)
std::cout << "Network is not operational. Only Firmware Timing Deltas will be recorded." << std::endl;
valuesPerRecord = 1;
// enable network timing
controller->NetworkTimingEnableSet(true);
networkTimingEnabled = true;
valuesPerRecord = 3;
// add a recorder
int recorderIndex = controller->RecorderCountGet();
controller->RecorderCountSet(recorderIndex + 1);
// check if the recorder is running already, if it is then stop it
if (controller->RecorderEnabledGet(recorderIndex))
controller->RecorderStop(recorderIndex);
controller->RecorderReset(recorderIndex);
// configure the recorder
controller->RecorderPeriodSet(RECORD_PERIOD_SAMPLES);
controller->RecorderCircularBufferSet(false);
controller->RecorderDataCountSet(valuesPerRecord);
controller->RecorderDataAddressSet(0, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeFIRMWARE_TIMING_DELTA));
if (networkTimingEnabled)
controller->RecorderDataAddressSet(1, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeNETWORK_TIMING_DELTA));
controller->RecorderDataAddressSet(2, controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeNETWORK_TIMING_RECEIVE_DELTA));
// start the recorder
controller->RecorderStart(recorderIndex);
controller->OS->Sleep(RECORD_TIME);
int recordCount = controller->RecorderRecordCountGet(recorderIndex);
std::cout << "There are " << recordCount << " records available." << std::endl;
// read the records
std::vector<int> firmawareTimingDeltas(recordCount);
std::vector<int> networkTimingDeltas(recordCount);
std::vector<int> networkTimingReceiveDeltas(recordCount);
for (int i = 0; i < recordCount; i++)
controller->RecorderRecordDataRetrieve(recorderIndex);
firmawareTimingDeltas[i] = controller->RecorderRecordDataFirmwareValueGet(recorderIndex, 0).Int32;
networkTimingDeltas[i] = controller->RecorderRecordDataFirmwareValueGet(recorderIndex, 1).Int32;
networkTimingReceiveDeltas[i] = controller->RecorderRecordDataFirmwareValueGet(recorderIndex, 2).Int32;
// calculate the statistics
std::vector<int> firmwareTimingStats = MinMaxAvg(firmawareTimingDeltas);
std::cout << "Firmware Timing Deltas (us): ";
std::cout << " Min = " << std::setw(4) << firmwareTimingStats[0];
std::cout << " Max = " << std::setw(4) << firmwareTimingStats[1];
std::cout << " Avg = " << std::setw(4) << firmwareTimingStats[2] << std::endl;
std::vector<int> networkTimingStats = MinMaxAvg(networkTimingDeltas);
std::cout << "Network Timing Deltas (us): ";
std::cout << " Min = " << std::setw(4) << networkTimingStats[0];
std::cout << " Max = " << std::setw(4) << networkTimingStats[1];
std::cout << " Avg = " << std::setw(4) << networkTimingStats[2] << std::endl;
std::vector<int> networkTimingReceiveStats = MinMaxAvg(networkTimingReceiveDeltas);
std::cout << "Network Timing Receive Deltas (us):";
std::cout << " Min = " << std::setw(4) << networkTimingReceiveStats[0];
std::cout << " Max = " << std::setw(4) << networkTimingReceiveStats[1];
std::cout << " Avg = " << std::setw(4) << networkTimingReceiveStats[2] << std::endl;
// delete the recorder
controller->RecorderCountSet(recorderIndex);
exitCode = 0; // set the exit code to success.
exitCode = -1;
controller->Delete();
@ RSINetworkStateOPERATIONAL
Definition rsienums.h:626
@ RSIControllerAddressTypeNETWORK_TIMING_DELTA
the latest time delta between the current network packet send time and the previous (microseconds)....
Definition rsienums.h:416
@ RSIControllerAddressTypeNETWORK_TIMING_RECEIVE_DELTA
the latest time delta between the current network packet receive time and the previous (microseconds)...
Definition rsienums.h:417
@ RSIControllerAddressTypeFIRMWARE_TIMING_DELTA
the latest time delta between the current RMP sample and the previous (microseconds)
Definition rsienums.h:415
Definition config.h:81
Definition helpers.h:87
[NetworkShutdown]
Definition helpers.h:205
[PrintHeader]
Definition helpers.h:221
Definition rsi.h:872
