hello-rttasks.cpp
See Real-Time Tasks 📜 for a detailed explanation of this sample code.
This sample demonstrates how to create and submit a simple Real-Time Task
that increments a global counter variable.
#include "rttasks-helpers.h" // import our helper functions for RTTasks
#include "rttask.h" // import the RTTask library
#include <iostream>
#include <memory>
#include <optional>
#include <thread>
#include <chrono>
using namespace RSI::RapidCode::RealTimeTasks; // Import the RealTimeTasks namespace
int main()
const std::string SAMPLE_APP_NAME = "📜 Real-Time Tasks: Hello RTTasks";
// create the controller
std::optional<RTTaskManager> manager;
RTTaskManagerCreationParameters parameters = RTTaskHelper::GetTaskManagerCreationParameters();
std::cout << "Creating task manager..." << std::endl;
manager = RTTaskManager::Create(parameters);
Helpers::CheckErrors(&manager.value());
// tell the task manager the name of the function to run as a task, the name
// of the library that contains the function, and the directory where the
// library is located. The Increment function is defined in the RTTaskFunctions library.
// it increments a global counter variable.
std::cout << "Submitting task..." << std::endl;
RTTaskCreationParameters params("Increment");
RTTask task = manager->TaskSubmit(params);
// wait for the task to run for a bit
// get the counter global tag to see if the task ran correctly
std::cout << "Getting counter global tag..." << std::endl;
RSI::RapidCode::FirmwareValue counter = manager->GlobalValueGet("counter");
if (counter.Int64 <= 0)
// the task did not run correctly
exitCode = -1;
std::cout << "Counter is not greater than 0. The task did not run correctly." << std::endl;
// the task ran correctly
exitCode = 0;
std::cout << "Counter: " << counter.Int64 << std::endl;
std::cerr << e.what() << std::endl;
// shutdown the task manager firmware process
if (manager.has_value())
manager->Shutdown();
Config::Cleanup(controller);
controller->Delete();
Definition rttask.h:438
static RTTaskManager Create(const RTTaskManagerCreationParameters &parameters)
Create a new RTTaskManager instance.
Definition config.h:147
Definition config.h:81
[SetupController]
Definition config.h:206
Definition helpers.h:87
[NetworkShutdown]
Definition helpers.h:205
[PrintHeader]
Definition helpers.h:221
The RealTimeTasks namespace.
Definition rttask.h:36
Definition rsi.h:872
Definition rttask.h:126
Definition rttask.h:140
int32_t Repeats
Number of times the task should execute (RepeatForever for infinite, 0 for none (one-shot)).
Definition rttask.h:170
Definition rttask.h:320
Definition rsi.h:464
int64_t Int64
64-bit signed integer.
Definition rsi.h:474
