10using RSI.RapidCode.dotNET;
17public class UserLimitCommandPositionDirect : StaticMemoryTestBase
21 const int AXIS_COUNT = 1;
22 const int USER_LIMIT_FIRST = 0;
23 const int USER_LIMIT_SECOND = 1;
24 const int USER_LIMIT_COUNT = 2;
29 const int DURATION = 0;
30 const bool ONE_SHOT =
true;
33 const int COMMAND_POSITION_INDEX = 0;
34 const int ACTUAL_POSITION_INDEX = 1;
35 const int TC_COMMAND_POSITION_INDEX = 2;
36 const int TC_ACTUAL_POSITION_INDEX = 3;
38 public void UserLimitCommandPositionDirectSet()
43 axis = CreateAndReadyAxis(Constants.AXIS_NUMBER);
73 axis.
MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
76 ConfigureUserLimitInterrupts(USER_LIMIT_FIRST);
77 ConfigureUserLimitInterrupts(USER_LIMIT_SECOND);
84 public void ConfigureUserLimitInterrupts(
int userLimitIndex)
90 public void WaitForInterrupts()
93 int timeout_millseconds = 10;
Configure a User Limit.
double InterruptUserDataDoubleGet(uint32_t userDataIndex)
int32_t InterruptSampleTimeGet()
int32_t NumberGet()
Get the axis number.
RSIEventType
Event Types or Status Bits.
RSIUserLimitLogic
Trigger types for UserLimits.
