UserLimitCommandPositionDirect.cs
10using RSI.RapidCode.dotNET; // Import our RapidCode Library.
11using NUnit.Framework;
12using System;
13
15[TestFixture]
16[Category("Software")]
17public class UserLimitCommandPositionDirect : StaticMemoryTestBase
18 {
20 // Constants
21 const int AXIS_COUNT = 1;
22 const int USER_LIMIT_FIRST = 0; // Specify which user limit to use.
23 const int USER_LIMIT_SECOND = 1;
24 const int USER_LIMIT_COUNT = 2;
25 const RSIUserLimitLogic LOGIC = RSIUserLimitLogic.RSIUserLimitLogicEQ; // Logic for input value comparison.
26 const RSIUserLimitTriggerType TRIGGER_TYPE = RSIUserLimitTriggerType.RSIUserLimitTriggerTypeSINGLE_CONDITION; // Choose the how the condition (s) should be evaluated.
27 const RSIAction ACTION = RSIAction.RSIActionTRIGGERED_MODIFY; // Choose the action you want to cause when the User Limit triggers.
28
29 const int DURATION = 0; // Enter the time delay before the action is executed after the User Limit has triggered.
30 const bool ONE_SHOT = true; // if true, User Limit will only trigger ONCE
31
32 // User Limit Interrupt constants
33 const int COMMAND_POSITION_INDEX = 0;
34 const int ACTUAL_POSITION_INDEX = 1;
35 const int TC_COMMAND_POSITION_INDEX = 2;
36 const int TC_ACTUAL_POSITION_INDEX = 3;
37
38 public void UserLimitCommandPositionDirectSet()
39 {
40 // Some Necessary Pre User Limit Configuration
41 controller.AxisCountSet(AXIS_COUNT);
42 controller.UserLimitCountSet(USER_LIMIT_COUNT); // Set the amount of UserLimits that you want to use.
43 axis = CreateAndReadyAxis(Constants.AXIS_NUMBER); // Initialize your axis object.
44
45 // set the triggered modify values to stop very quickly
46 axis.TriggeredModifyDecelerationSet(Constants.DECELERATION);
47 axis.TriggeredModifyJerkPercentSet(Constants.JERK_PERCENT);
48
50 // USER LIMIT CONDITION 0 (trigger on digital input)
51 controller.UserLimitConditionSet(USER_LIMIT_FIRST, 0, LOGIC, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeDIGITAL_INPUTS), 0x400000, 0x400000); // Set your User Limit Condition (1st step to setting up your user limit)
52
54 // controller.UserLimitOutputSet(USER_LIMIT_FIRST, RSIDataType.RSIDataTypeDOUBLE, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTC_ACTUAL_POSITION), controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER), true);
55
57 controller.UserLimitConfigSet(USER_LIMIT_FIRST, TRIGGER_TYPE, ACTION, axis.NumberGet(), DURATION, ONE_SHOT); // Set your User Limit Configuration. (2nd step to setting up your user limit)
58
60 // CONDITION 0 (wait for first user limit to trigger)
61 controller.UserLimitConditionSet(USER_LIMIT_SECOND, 0, RSIUserLimitLogic.RSIUserLimitLogicEQ, controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSERLIMIT_STATUS, USER_LIMIT_FIRST), 1, 1);
62
63 // CONDITION 1 (AND wait for Axis command velcity = 0.0)
64 controller.UserLimitConditionSet(USER_LIMIT_SECOND, 1, RSIUserLimitLogic.RSIUserLimitLogicEQ, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_VELOCITY), 0.0);
65
66 // OUTPUT (copy value from UserBuffer to TC.CommandPosition when trigered)
67 //controller.UserLimitOutputSet(USER_LIMIT_SECOND, RSIDataType.RSIDataTypeDOUBLE, controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER), axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTC_COMMAND_POSITION), true);
68 controller.UserLimitConfigSet(USER_LIMIT_SECOND, RSIUserLimitTriggerType.RSIUserLimitTriggerTypeCONDITION_AND, RSIAction.RSIActionNONE, 0, 0, ONE_SHOT);
69
70 // get the Axis moving
71 axis.ClearFaults();
72 axis.AmpEnableSet(true);
73 axis.MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
74
75 // configure and enable interrupts
76 ConfigureUserLimitInterrupts(USER_LIMIT_FIRST);
77 ConfigureUserLimitInterrupts(USER_LIMIT_SECOND);
78 controller.InterruptEnableSet(true);
79
80 // wait for (and print) interrupts
81 WaitForInterrupts();
82 }
83
84 public void ConfigureUserLimitInterrupts(int userLimitIndex)
85 {
86 controller.UserLimitInterruptUserDataAddressSet(userLimitIndex, COMMAND_POSITION_INDEX, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION));
87 controller.UserLimitInterruptUserDataAddressSet(userLimitIndex, ACTUAL_POSITION_INDEX, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeACTUAL_POSITION));
88 }
89
90 public void WaitForInterrupts()
91 {
92 bool done = false;
93 int timeout_millseconds = 10;
94
95 while (!done)
96 {
97 RSIEventType eventType = controller.InterruptWait(timeout_millseconds);
98
99 Console.WriteLine("IRQ: " + eventType.ToString() + " at sample " + controller.InterruptSampleTimeGet());
100
101 switch (eventType)
102 {
103 case RSIEventType.RSIEventTypeUSER_LIMIT:
104 Console.WriteLine("UserLimit " + controller.InterruptSourceNumberGet());
105 Console.WriteLine("CmdPos: " + controller.InterruptUserDataDoubleGet(COMMAND_POSITION_INDEX));
106 Console.WriteLine("ActPos: " + controller.InterruptUserDataDoubleGet(ACTUAL_POSITION_INDEX));
107 Console.WriteLine("TC.CmdPos: " + controller.InterruptUserDataDoubleGet(TC_COMMAND_POSITION_INDEX));
108 Console.WriteLine("TC.ActPos: " + controller.InterruptUserDataDoubleGet(TC_ACTUAL_POSITION_INDEX));
109 break;
110 case RSIEventType.RSIEventTypeTIMEOUT:
111 done = true;
112 break;
113 default:
114 break;
115 }
116 }
117 }
119 }
Configure a User Limit.
double InterruptUserDataDoubleGet(uint32_t userDataIndex)
int32_t InterruptSampleTimeGet()
int32_t NumberGet()
Get the axis number.
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:966
RSIUserLimitLogic
Definition rsienums.h:646
Definition rsienums.h:1115
Definition rsienums.h:434
Trigger types for UserLimits.
Definition rsienums.h:633
