SyncOutputWithMotion.cpp
21
22#include <cassert>
23#include "rsi.h" // Import our RapidCode Library.
24#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
25#include <cmath>
26#include "SampleApps.h"
27
28using namespace RSI::RapidCode; // Import the RapidCode namespace
29
31int SyncOutputWithMotion::Run()
32{
34 /* CONSTANTS */
35 // *NOTICE* The following constants must be configured before attempting to run with hardware.
36
37 // Axis configuration parameters
38 const int AXIS_COUNT = 1; // number of axes
39 const int AXIS_NUMBER = 0; // axis number
40
41 const double USER_UNITS = 1048576; // encoder counts per rev (set as appropiate)
42
43 // Motion parameters
44 const double TIME_SLICE = 0.01; // 0.01s = 10ms
45 const int REVS = 2; // number of revolutions
46 const int RPS = 1; // revs / sec
47 const int TOTAL_POINTS = (int)(REVS / TIME_SLICE / RPS); // total number of points
48 const int EMPTY_CT = -1; // Number of points that remains in the buffer before an e-stop
49
50 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
51 USE_HARDWARE = false;
52
53 /* SAMPLE APP BODY */
54
55 // Initizalize the controller from software w/ multiple axes
56 MotionController* controller = MotionController::CreateFromSoftware();
58
59 // Setup the controller for the appropriate hardware configuration.
60 if (USE_HARDWARE)
61 {
63 }
64 else
65 {
66 SampleAppsHelper::SetupControllerForPhantoms(controller, AXIS_COUNT, { AXIS_NUMBER });
67 }
68
69 MultiAxis* multiAxis;
70
71 try {
72 // add an additional axis for the multiaxis supervisor
73 controller->MotionCountSet(controller->AxisCountGet() + 1);
74
75 // create the multiaxis using the ID of the first free axis (0 indexed)
76 multiAxis = controller->MultiAxisGet(controller->MotionCountGet() - 1);
78
79 // populate the multiaxis
80 Axis* axis = controller->AxisGet(AXIS_NUMBER);
82 axis->UserUnitsSet(USER_UNITS);
84 axis->EStopAbort();
85 axis->ClearFaults();
86 axis->PositionSet(0);
87
88 multiAxis->AxisAdd(axis);
89
90 // populate the positions and times
91 std::vector<double> positions, times;
92 for (int i = 0; i < TOTAL_POINTS; i += AXIS_COUNT)
93 {
94 positions.push_back(i * TIME_SLICE * RPS);
95 times.push_back(TIME_SLICE);
96 }
97
98
99 // prepare the controller (and drive)
100 multiAxis->Abort();
101 multiAxis->ClearFaults();
102 assert(multiAxis->StateGet() == RSIState::RSIStateIDLE);
103 multiAxis->AmpEnableSet(true);
104
105
106 // set up the inputs
107 IOPoint* output0 = IOPoint::CreateDigitalOutput(multiAxis->AxisGet(AXIS_NUMBER), RSIMotorGeneralIo::RSIMotorGeneralIo16);
108 // ensure the digital out is set low
109 output0->Set(0);
110
111 // The motion element ID at which to set the output
112 int outPutEnableID = TOTAL_POINTS / 2;
113
114
115 // enable streaming output
116 multiAxis->StreamingOutputsEnableSet(true);
117
118
119 // Enable the streaming output (The following are functionally equivalent)
120 //multiAxis->StreamingOutputAdd(output0->MaskGet(), 0, output0->AddressGet(), outPutEnableID);
121 multiAxis->StreamingOutputAdd(output0, true, outPutEnableID);
122
123 // Disable the output (The following are functionally equivalent)
124 //multiAxis->StreamingOutputAdd(0, output0->MaskGet(), output0->AddressGet(), outPutEnableID);
125 //multiAxis->StreamingOutputAdd(output0, false, outPutEnableID);
126
127
128 multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0], &times[0], TOTAL_POINTS, EMPTY_CT, false, true);
129
130 printf("Motion started. Waiting to complete.\n");
131 multiAxis->MotionDoneWait();
132 printf("Motion Complete. The outputs should have been set\n");
133
134 multiAxis->StreamingOutputsClear(); // cleanup for next run
135
136 multiAxis->EStopAbort();
137 }
138 catch (RsiError const& err) {
139 printf("\n%s\n", err.text);
140 return -1;
141 }
142 controller->Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
143 return 0;
145}
void Set(bool state)
int32_t AxisCountGet()
int32_t MotionCountGet()
Axis * AxisGet(int32_t index)
Get the Axis class used in this MultiAxis class.
void AxisAdd(Axis *axis)
RSIState StateGet()
void StreamingOutputsClear()
void EStopAbort()
E-Stop, then abort an axis.
@ RSIMotionTypePT
Definition rsienums.h:1180
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIStateIDLE
Idle, ready for anything.
Definition rsienums.h:1016
