#include <cmath>
#include "SampleAppsHelper.h"
#include "rsi.h"
const int WAIT_SAMPLES = 100;
int samplesWaited = 0;
while (axis->
StatusBitGet(RSIEventType::RSIEventTypeMOTION_AT_VELOCITY) == 0)
samplesWaited += WAIT_SAMPLES;
if (samplesWaited > timeout)
throw std::runtime_error("Timeout waiting for motion to reach velocity");
int main()
const std::string SAMPLE_APP_NAME = "Motion: Point-to-Point";
const double POSITION_0 = 0;
const double POSITION_1 = 0.5;
const double VELOCITY = 1;
const double ACCELERATION = 10;
const double DECELERATION = 10;
const double FINAL_VELOCITY = 0.5;
int exitCode = -1;
const int32_t TIMEOUT = 10000;
std::cout << "Absolute (Trapezoidal) Motion:" << std::endl;
std::cout << "Relative Motion:" << std::endl;
axis->
MoveRelative(POSITION_1 - POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
axis->
MoveRelative(POSITION_0 - POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
std::cout << "SCurve Motion:" << std::endl;
std::cout << "SCurve Motion with Final Velocity:" << std::endl;
std::cout << "Final Velocity: " << FINAL_VELOCITY << std::endl;
axis->
MoveSCurve(POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY);
HelperAtVelocityWait(controller, axis, TIMEOUT);
std::cout << "Final Velocity: " << 0 << std::endl;
axis->
MoveSCurve(POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, 0);
std::cout << "Velocity Move:" << std::endl;
std::cout << "Accelerating to velocity: " << VELOCITY << std::endl;
std::cout << "Decelerating to velocity: " << 0 << std::endl;
exitCode = 0;
exitCode = -1;
Command a point-to-point S-Curve motion.
int32_t MotionDoneWait()
static void SetupController(MotionController *controller)
static constexpr int AXIS_COUNT
Number of axes to configure on the controller.
static constexpr int AXIS_X_INDEX
Index of the first axis to use in the sample apps.
