Final Velocity Motion
Perform an absolute or relative move with a specified final velocity.
🔹 What is Velocity Motion?
An absolute or relative move with a specified, non-zero final velocity.
🔹 Why use Velocity Motion?
A move with final velocity will make an absolute or relative move, and upon reaching the specified position, continue moving at the specified final velocity (as if you had made a position move and then, immediately after, a velocity move). This motion will continue indefinitely until it is stopped, either manually or through the program. To command a move with final velocity, enter your desired final velocity as the last argument in your regular move command.
📜 Sample Code
  • C#
    axis.MoveSCurve(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY); // axis continues at final velocity after reaching position
    // wait until axis transitions to final velocity
    while (axis.StatusBitGet(RSIEventType.RSIEventTypeMOTION_AT_VELOCITY) == false)
    Thread.Sleep(100);
  • C++
    const int NUM_AXES = 1; // the number of axes to configure
    // motion Parameters
    const double POSITION_0 = 0; // specify the start position
    const double POSITION_1 = 0.5; // specify the position to move to
    const double VELOCITY = 1; // specify your velocity - units: UserUnits/Sec
    const double ACCELERATION = 10; // specify your acceleration - units: UserUnits/Sec^2
    const double DECELERATION = 10; // specify your deceleration - units: UserUnits/Sec^2
    const double JERK_PERCENT = 50; // specify your jerk percent (0.0 to 100.0)
    const double FINAL_VELOCITY = 0.5; // specify your final velocity - units: UserUnits/Sec
    std::cout << "SCurve Motion with Final Velocity:" << std::endl;
    std::cout << "Final Velocity: " << FINAL_VELOCITY << std::endl;
    axis->MoveSCurve(POSITION_1, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, FINAL_VELOCITY);
    HelperAtVelocityWait(controller, axis, TIMEOUT);
    std::cout << "Final Velocity: " << 0 << std::endl;
    axis->MoveSCurve(POSITION_0, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT, 0);
    axis->MotionDoneWait(TIMEOUT);
