MultiAxisMotion.cs
37using RSI.RapidCode.dotNET; // Import our RapidCode Library.
38using NUnit.Framework;
39using System;
40
41#if DOXYGEN // RSI internal documentation use only
42using RSI.RapidCode;
43#endif
44
46[TestFixture]
47[Category("Software")]
48class MultiAxisMotion : StaticMemoryTestBase
49 {
50 [Test]
51 public void MultiAxisVelocityMotion()
52 {
54 // RapidCode Objects
55 MultiAxis multi; // Declare what multi is.
56
57 // Constants
58 const int cycles = 2; // Specify how many times you want to update the velocity.
59 const int NUM_OF_AXES = 6;
60
61 controller.AxisCountSet(NUM_OF_AXES);
62 controller.MotionCountSet(NUM_OF_AXES + 1); // We will need a motion supervisor for every Axis object and MultiAxis object
63
64 int i;
65 double[] accelerations = new double[6] { 1000, 1000, 1000, 1000, 1000, 1000 }; // Specify the acceleration for all 6 axes.
66 double[] velocities = new double[6]; // Initialize the array that will contain the velocities of all 6 axes.
67 Random rnd = new Random(); // Initialize the Random object that we will use to generate random velocities.
68
69 Axis x_axis = controller.AxisGet(Constants.X_AXIS_NUMBER); // Initialize axis. (You can use RapidSetup to see what axes you are using.)
70 Axis y_axis = controller.AxisGet(Constants.Y_AXIS_NUMBER); // Initialize axis.
71 Axis z_axis = controller.AxisGet(Constants.Z_AXIS_NUMBER); // Initialize axis.
72 Axis a_axis = controller.AxisGet(Constants.A_AXIS_NUMBER); // Initialize axis.
73 Axis b_axis = controller.AxisGet(Constants.B_AXIS_NUMBER); // Initialize axis.
74 Axis c_axis = controller.AxisGet(Constants.C_AXIS_NUMBER); // Initialize axis.
75
76 HelperFunctions.CheckErrors(x_axis); // Check that the axis has been initialize correctly.
77 HelperFunctions.CheckErrors(y_axis); // Check that the axis has been initialize correctly.
78 HelperFunctions.CheckErrors(z_axis); // Check that the axis has been initialize correctly.
79 HelperFunctions.CheckErrors(a_axis); // Check that the axis has been initialize correctly.
80 HelperFunctions.CheckErrors(b_axis); // Check that the axis has been initialize correctly.
81 HelperFunctions.CheckErrors(c_axis); // Check that the axis has been initialize correctly.
82
83 multi = controller.MultiAxisGet(NUM_OF_AXES); // Configure your MultiAxis on RapidSetup (Make sure MotionCount is 1 higher than AxisCount)
84 HelperFunctions.CheckErrors(multi); // Check that multi has been initialized correctly.
85
86 multi.AxisRemoveAll(); // If there are any current axes on multi, remove them.
87
88 multi.AxisAdd(x_axis); // Add axis to your Multi-Axis controller.
89 multi.AxisAdd(y_axis); // Add axis to your Multi-Axis controller.
90 multi.AxisAdd(z_axis); // Add axis to your Multi-Axis controller.
91 multi.AxisAdd(a_axis); // Add axis to your Multi-Axis controller.
92 multi.AxisAdd(b_axis); // Add axis to your Multi-Axis controller.
93 multi.AxisAdd(c_axis); // Add axis to your Multi-Axis controller.
94
95 multi.Abort(); // If there is any motion happening, abort it.
96 multi.ClearFaults(); // Clear faults and enable all axes.
97 multi.AmpEnableSet(true); // Enable the motor.
98
99 for (i = 0; i < cycles; i++) // This loop will iterate 5 times based on the value of "cycles"
100 {
101 int random_vel1 = rnd.Next(1, 100); // random_vel1 is a number [ >= 1 and < 100 ]
102 int random_vel2 = rnd.Next(1, 100);
103 int random_vel3 = rnd.Next(1, 100);
104 int random_vel4 = rnd.Next(1, 100);
105 int random_vel5 = rnd.Next(1, 100);
106 int random_vel6 = rnd.Next(1, 100);
107
108 velocities = new double[6] {random_vel1, // Update axis's velocity.
109 random_vel2, // Update axis's velocity.
110 random_vel3, // Update axis's velocity.
111 random_vel4, // Update axis's velocity.
112 random_vel5, // Update axis's velocity.
113 random_vel6 }; // Update axis's velocity.
114
115 multi.MoveVelocity(velocities, accelerations); // Move your Multi-Axis. (this will also update the move on the fly)
116
117 System.Threading.Thread.Sleep(100); // Sleep for 100ms before iterating again.
118 }
119
120 multi.Abort(); // Stop motion on all axes.
122 }
123
124 [Test]
125 public void PointToPointMultiAxisMotion()
126 {
128 // Constants
129 const int NUM_OF_AXES = 2; // Specify the number of axes (Make sure your axis count in RapidSetup is 2!)
130
131 // Parameters
132 double[] positions1 = new double[NUM_OF_AXES] { 5, 10 }; // The first set of positions to be moved to
133 double[] positions2 = new double[NUM_OF_AXES] { 15, 15 }; // The second set of positions to be moved to
134 double[] velocities1 = new double[NUM_OF_AXES] { 1000, 1000 }; // The velocity for the two axes for the first move- Units: units/sec (driver will execute 10 rotations per second)
135 double[] velocities2 = new double[NUM_OF_AXES] { 1000, 1000 }; // The velocity for the two axes for the second move
136 double[] accelerations = new double[NUM_OF_AXES] { 500, 500 }; // The acceleration for the two axes
137 double[] decelerations = new double[NUM_OF_AXES] { 500, 500 }; // The deceleration for the two axes
138 double[] jerkPercent = new double[NUM_OF_AXES] { 50, 50 }; // The jerk percent for the two axes
139
140 controller.AxisCountSet(NUM_OF_AXES);
141 controller.MotionCountSet(NUM_OF_AXES + 1);
142
143 Axis axis0 = controller.AxisGet(Constants.X_AXIS_NUMBER); // Initialize axis0
144 Axis axis1 = controller.AxisGet(Constants.Y_AXIS_NUMBER); // Initialize axis1
145
146 HelperFunctions.CheckErrors(axis0); // [Helper Function] Check that 'axis0' has been initialized correctly
147 HelperFunctions.CheckErrors(axis1); // [Helper Function] Check that 'axis1' has been initialized correctly
148
149 // In this application, we have two Axis objects and one MultiAxis object, so three motion supervisors are required
150 MultiAxis multi = controller.MultiAxisGet(NUM_OF_AXES); // Initialize a new MultiAxis object. MultiAxisGet takes a motion supervisor number as its argument.
151 // This number is equal to the number of axes since motion supervisors are zero indexed (i.e., motion supervisors
152 // 0 and 1 are used for axis0 and axis1, so motion supervisor 2 is available for our MultiAxis object).
153
154 HelperFunctions.CheckErrors(multi); // [Helper Function] Check that 'multi' has been initialized correctly
155 controller.AxisCountSet(NUM_OF_AXES); // Set the number of axis being used. A phantom axis will be created if for any axis not on the network. You may need to refresh rapid setup to see the phantom axis.
156
157 multi.AxisRemoveAll(); // Remove all current axis if any. So we can add new ones
158
159 multi.AxisAdd(axis0); // Add axis0 to the MultiAxis object
160 multi.AxisAdd(axis1); // Add axis1 to the MultiAxis object
161
162 multi.Abort(); // If there is any motion happening, abort it
163 multi.ClearFaults(); // Clear any faults
164 multi.AmpEnableSet(true); // Enable the motor
165
166 axis0.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Disable poistion error for Phantom Axes.
167 axis1.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Disable poistion error for Phantom Axes.
168
169 multi.MoveSCurve(positions1, velocities1, accelerations, decelerations, jerkPercent); // Move to the positions specified in positions1 using a trapezoidal motion profile
170 multi.MotionDoneWait(); // Wait for motion to finish
171
173 Assert.That(axis0.CommandPositionGet(), Is.EqualTo(positions1[0]), "The first axis in the multi axis object should be commanded to move to the firt element of the array");
174 Assert.That(axis1.CommandPositionGet(), Is.EqualTo(positions1[1]), "The second axis in the multi axis object should be commanded to move to the second element of the array");
175
176 multi.MoveTrapezoidal(positions2, velocities2, accelerations, decelerations); // Move to the positions specified in positions2 using a SCurve motion profile
177 multi.MotionDoneWait(); // Wait for the motion to finish
178
180 Assert.That(axis0.CommandPositionGet(), Is.EqualTo(positions2[0]), "The first axis in the multi axis object should be commanded to move to the firt element of the array");
181 Assert.That(axis1.CommandPositionGet(), Is.EqualTo(positions2[1]), "The second axis in the multi axis object should be commanded to move to the second element of the array");
182
183 multi.AmpEnableSet(false); // Disable the axes
184
185 // /@[PointToPointMultiAxisMotion]
186 }
187 }
double CommandPositionGet()
Definition rsi.h:5870
void AxisRemoveAll()
Point-to-point S-Curve Move.
Velocity move.
void AxisAdd(Axis *axis)
Definition rsi.h:10804
int32_t MotionDoneWait()
Definition rsienums.h:1115
