37using RSI.RapidCode.dotNET;
48class MultiAxisMotion : StaticMemoryTestBase
51 public void MultiAxisVelocityMotion()
59 const int NUM_OF_AXES = 6;
65 double[] accelerations =
new double[6] { 1000, 1000, 1000, 1000, 1000, 1000 };
66 double[] velocities =
new double[6];
67 Random rnd =
new Random();
99 for (i = 0; i < cycles; i++)
101 int random_vel1 = rnd.Next(1, 100);
102 int random_vel2 = rnd.Next(1, 100);
103 int random_vel3 = rnd.Next(1, 100);
104 int random_vel4 = rnd.Next(1, 100);
105 int random_vel5 = rnd.Next(1, 100);
106 int random_vel6 = rnd.Next(1, 100);
108 velocities =
new double[6] {random_vel1,
117 System.Threading.Thread.Sleep(100);
125 public void PointToPointMultiAxisMotion()
129 const int NUM_OF_AXES = 2;
132 double[] positions1 =
new double[NUM_OF_AXES] { 5, 10 };
133 double[] positions2 =
new double[NUM_OF_AXES] { 15, 15 };
134 double[] velocities1 =
new double[NUM_OF_AXES] { 1000, 1000 };
135 double[] velocities2 =
136 double[] accelerations =
new double[NUM_OF_AXES] { 500, 500 };
137 double[] decelerations =
138 double[] jerkPercent =
new double[NUM_OF_AXES] { 50, 50 };
169 multi.
MoveSCurve(positions1, velocities1, accelerations, decelerations, jerkPercent);
173 Assert.That(axis0.
CommandPositionGet(), Is.EqualTo(positions1[0]),
"The first axis in the multi axis object should be commanded to move to the firt element of the array");
174 Assert.That(axis1.
CommandPositionGet(), Is.EqualTo(positions1[1]),
"The second axis in the multi axis object should be commanded to move to the second element of the array");
176 multi.
MoveTrapezoidal(positions2, velocities2, accelerations, decelerations);
180 Assert.That(axis0.
CommandPositionGet(), Is.EqualTo(positions2[0]),
181 Assert.That(axis1.
CommandPositionGet(), Is.EqualTo(positions2[1]),
double CommandPositionGet()
void AxisRemoveAll()
Point-to-point S-Curve Move.
Velocity move.
void AxisAdd(Axis *axis)
int32_t MotionDoneWait()
