InputOutput.cs
54using RSI.RapidCode.dotNET; // Import our RapidCode Library.
55using NUnit.Framework;
56using System;
57
58#if DOXYGEN // RSI internal documentation use only
59using RSI.RapidCode;
60#endif
61
63[TestFixture]
64[Category("Software")]
65class InputOutput : SampleAppTestBase
66 {
67 [Test, Timeout(Constants.MAX_TEST_TIME)]
68 public void DedicatedIO()
69 {
71 // Retrieve dedicated inputs with generic and specific function.
72 Console.WriteLine("RSIMotorDedicatedInLIMIT_HW_NEG: {0} and {1}",
73 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_NEG),
74 axis.NegativeLimitGet());
75
76 Console.WriteLine("RSIMotorDedicatedInLIMIT_HW_POS: {0} and {1}",
77 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInLIMIT_HW_POS),
78 axis.PositiveLimitGet());
79
80 Console.WriteLine("RSIMotorDedicatedInHOME: {0} and {1}",
81 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInHOME),
82 axis.HomeSwitchGet());
83
84 Console.WriteLine("RSIMotorDedicatedInAMP_FAULT: {0} and {1}",
85 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_FAULT),
86 axis.AmpFaultGet());
87
88 Console.WriteLine("RSIMotorDedicatedInAMP_ACTIVE: {0} and {1}",
89 axis.DedicatedInGet(RSIMotorDedicatedIn.RSIMotorDedicatedInAMP_ACTIVE),
90 axis.AmpEnableGet());
92 }
93
94 [Test, Timeout(Constants.MAX_TEST_TIME)]
95 public void NetworkInputsAndOutputs()
96 {
98 // Get Input Values
99 int inputCount = controller.NetworkInputCountGet(); // Get number of Network Inputs (PDOs)
100
101 for (int i = 0; i < inputCount; i++)
102 {
103 int size = controller.NetworkInputBitSizeGet(i); // Read Input BitSize
104 int offset = controller.NetworkInputBitOffsetGet(i); // Read Input BitOffset
105 string name = controller.NetworkInputNameGet(i); // Read Input Name
106 UInt64 value = controller.NetworkInputValueGet(i); // Read Input Value
107 }
108
109 // Get Output Values
110 int outputCount = controller.NetworkOutputCountGet(); // Get number of Network Outputs (SDOs)
111
112 for (int i = 0; i < outputCount; i++)
113 {
114 int size = controller.NetworkOutputBitSizeGet(i); // Read Output BitSize
115 int offset = controller.NetworkOutputBitOffsetGet(i); // Read Output BitOffset
116 string name = controller.NetworkOutputNameGet(i); // Read Output Name
117 UInt64 value = controller.NetworkOutputSentValueGet(i); // Read Output Value
118 controller.NetworkOutputOverrideValueSet(i, value);
119 }
121 }
122
123
124 //TODO expand examples once iopoint is expanded.
125 [Test]
126 public void IOPoints()
127 {
130 const int NODE_INDEX = 0; // The EtherCAT Node we will be communicating with
131 //const int INPUT_INDEX = 0; // The PDO Index in that Node
132 const int OUTPUT_INDEX = 0; // The PDO Index in that Node
133
134 IOPoint output0 = IOPoint.CreateDigitalOutput(controller.NetworkNodeGet(NODE_INDEX), OUTPUT_INDEX); // Automatically gets the memory index of a specified node and input index
135
137 output0.Set(false);
138
140 controller.SampleWait(1);
141 Assert.That(output0.Get(), Is.False, "The getter function should return a value equal to false");
143 }
144
145 //TODO expand examples once iopoint is expanded.
146 [Test]
147 public void IOPointUserBuffer()
148 {
151 const int INPUT_INDEX = 0;
152 const int OUTPUT_INDEX = 1; // The PDO Index in that Node
153
154 UInt64 userBufferAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0); // Grabing an memory address to store a simulated IO point.
155
156 IOPoint input0 = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX); // Automatically gets the memory index of a specified node and input index
157 IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX); // Automatically gets the memory index of a specified node and input index
158
159 //---ACT/ASSERT---
160 output0.Set(false);
161 Assert.That(output0.Get(), Is.False, "The getter function should return a value equal to false");
162 output0.Set(true);
163 Assert.That(output0.Get(), Is.True, "The getter function should return a value equal to true");
164 controller.MemorySet(input0.AddressGet(), 0);
165 Assert.That(input0.Get(), Is.False, "The getter function should return a value equal to false");
166 controller.MemorySet(input0.AddressGet(), 1);
167 Assert.That(input0.Get(), Is.True, "The getter function should return a value equal to true");
169 }
170
171 [Test]
172 public void SingleAxisSyncOutputs()
173 {
175 const int TOTAL_POINTS = 4; // total number of points
176 const int EMPTY_CT = -1; // Number of points that remains in the buffer before an e-stop
177 const int OUTPUT_INDEX = 0; // This is the index of the digital output that will go active when the user limit triggers.
178 const int NODE_INDEX = 0; // The EtherCAT Node we will be communicating with
179
180 double[] positions = { 1.0, 2.0, 3.0, 4.0 }; // These will be the streaming motion 5 positions.
181 double[] times = { 0.5, 0.1, 0.2, 0.4 }; // These will be the streaming motion 5 positions' time.
182 int outputEnableID = 2; // The motion element ID at which to set the output
183 int outputDisableID = 3; // The motion element ID at which to set the output
184
185 // Set up the inputs
186 // IOPoint output0 = IOPoint.CreateDigitalOutput(axis, RSIMotorGeneralIo.RSIMotorGeneralIo16); // Retrieve DOUT 1, Method 1: requires you know the io adress in memory, slightly faster
187 IOPoint output0 = IOPoint.CreateDigitalOutput(controller.NetworkNodeGet(NODE_INDEX), OUTPUT_INDEX); // Retrieve DOUT 1 Method 2: only need to know node index
188 output0.Set(false); // Set the output low
189
190 // Set up Sync Outputs
191 axis.StreamingOutputsEnableSet(true); // Enable streaming output.
192
193 // ENABLE the Sync Output(s)
194 axis.StreamingOutputAdd(output0, true, outputEnableID); // This will turn DOUT1 High when the streaming motion reaches its 3rd motion point.
195 axis.StreamingOutputAdd(output0, false, outputDisableID); // This will turn DOUT1 Low when the streaming motion reaches its 4th motion point.
196
197 // DISABLE the Sync Output(s)
198 // axis.StreamingOutputAdd(output0, false, outPutEnableID);
199
200 axis.MovePT(RSIMotionType.RSIMotionTypePT, positions, times, TOTAL_POINTS, EMPTY_CT, false, true); // Start Streaming Motion
201
202 while (!axis.MotionDoneGet())
203 {
204 if (axis.MotionIdExecutingGet() > outputEnableID && axis.CommandPositionGet() < outputEnableID)
205 {
206 Assert.That(output0.Get(), Is.EqualTo(true), "The output should be triggered");
207 }
208 else
209 {
210 Assert.That(output0.Get(), Is.EqualTo(false), "The output should NOT be triggered");
211 }
212 }
213
214 axis.StreamingOutputsEnableSet(false); // Disable Sync Outputs.
215 axis.AmpEnableSet(false); // Disable the motor.
217 }
218 }
double CommandPositionGet()
bool AmpEnableGet()
bool HomeSwitchGet()
bool PositiveLimitGet()
uint16_t MotionIdExecutingGet()
bool NegativeLimitGet()
bool AmpFaultGet()
bool DedicatedInGet(RSIMotorDedicatedIn motorDedicatedInNumber)
Read a digital input.
void Set(bool state)
bool Get()
Definition rsi.h:10971
NetworkNode * NetworkNodeGet(int32_t nodeNumber)
NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializ...
Sets a PDO output directly.
int32_t NetworkInputBitOffsetGet(int32_t index)
uint64_t NetworkOutputSentValueGet(int32_t index)
Gets the value sent out over EtherCAT.
Get the name of a PDO output.
int32_t NetworkOutputBitOffsetGet(int32_t index)
Get the raw PDO offset for an output.
bool MotionDoneGet()
Definition rsienums.h:404
RSIMotionType
Definition rsienums.h:992
RSIMotorDedicatedIn
Definition rsienums.h:843
