#include "SampleAppsHelper.h"
#include "rsi.h"
int main()
const std::string SAMPLE_APP_NAME = "Math Blocks: Calculate Acceleration from Velocity";
const double VELOCITY = 1.0;
const double ACCELERATION = 0.123;
int exitCode = -1;
const int PREVIOUS_VELOCITY_MATHBLOCK_INDEX = SUBTRACTION_MATHBLOCK_INDEX + 1;
RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = RSIAxisAddressType::RSIAxisAddressTypeCOMMAND_VELOCITY;
controller->
AddressGet(RSIControllerAddressType::RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, PREVIOUS_VELOCITY_MATHBLOCK_INDEX);
subtractionConfig.
Operation = RSIMathBlockOperation::RSIMathBlockOperationSUBTRACT;
uint64_t userBufferAddr0 = controller->
AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, 0);
previousVelocityConfig.
InputDataType0 = RSIDataType::RSIDataTypeDOUBLE;
InputDataType1 = RSIDataType::RSIDataTypeDOUBLE;
Operation = RSIMathBlockOperation::RSIMathBlockOperationMULTIPLY;
controller->
MathBlockConfigSet(PREVIOUS_VELOCITY_MATHBLOCK_INDEX, previousVelocityConfig);
std::cout << "Calculated acceleration from MathBlock: " << calculatedAcceleration << std::endl;
if (std::abs(calculatedAcceleration - ACCELERATION) <= 0.000001)
std::cout << "The MathBlock is calculating the Axis' acceleration by subtracting previous velocity from current velocity." << std::endl;
exitCode = 0;
std::cerr << "Error: The calculated acceleration does not match the expected value" << std::endl;
exitCode = -1;
exitCode = -1;
double UserUnitsGet()
int32_t MotionDoneWait()
static void SetupController(MotionController *controller)
RSIDataType ProcessDataType
Data type for processing.
uint64_t InputAddress0
RSIDataType InputDataType0
uint64_t InputAddress1
RSIDataType InputDataType1
static constexpr int AXIS_X_INDEX
Index of the first axis to use in the sample apps.
static constexpr int MATH_BLOCK_COUNT
Number of math block objects to configure on the controller.
double Double
