random-walk.cpp
See Real-Time Tasks 📜 for a detailed explanation of this sample code.
This sample demonstrates how to create a Real-Time Task that performs a random walk
motion on an axis using Real-Time Tasks.
#include "rttasks-helpers.h" // import our helper functions for RTTasks
#include "rttask.h" // import the RTTask library
#include <iostream>
#include <memory>
#include <optional>
#include <thread>
#include <chrono>
using namespace RSI::RapidCode::RealTimeTasks; // Import the RealTimeTasks namespace
int main()
const std::string SAMPLE_APP_NAME = "📜 Real-Time Tasks: Random Walk";
/* CONSTANTS */
const int NUM_AXES = 1; // The number of axes to configure, default is 0 for this template
const int TIMEOUT_MS = 5000; // Timeout for waiting for the task to execute once
// create the controller
std::optional<RTTaskManager> manager;
// normally you would set the number of axes here, but for samples that is handled in the Config::SetupController function
// configure the axis
Axis *axis = controller->AxisGet(0);
axis->PositionSet(0);
axis->AmpEnableSet(true);
// create the task manager
RTTaskManagerCreationParameters parameters = RTTaskHelper::GetTaskManagerCreationParameters();
std::cout << "Creating task manager..." << std::endl;
manager = RTTaskManager::Create(parameters);
Helpers::CheckErrors(&manager.value());
// call the initialization task to initialize the global variables and get pointers to RapidCode objects
// in the RTTaskFunctions library. This needs to be called before any task that uses RapidCode objects.
RTTaskHelper::SubmitInitializationTask(manager.value());
// tell the task manager the name of the function to run as a task, the name
// of the library that contains the function, and the directory where the
// library is located. The RandomWalk function is defined in the RTTaskFunctions library.
// it moves the axis back and forth based on std::rand().
std::cout << "Submitting task..." << std::endl;
RTTaskCreationParameters params("RandomWalk");
params.Period = 5;
RTTask task = manager->TaskSubmit(params);
// wait for the task to run for a bit
// get the counter global tag to see if the task ran correctly
std::cout << "Getting counter global tag..." << std::endl;
FirmwareValue counter = manager->GlobalValueGet("counter");
if (counter.Int64 <= 0)
// the task did not run correctly
exitCode = -1;
std::cout << "Counter is not greater than 0. The task did not run correctly." << std::endl;
// the task ran correctly
exitCode = 0;
std::cout << "Counter: " << counter.Int64 << std::endl;
// the average global tag is the position the axis should be at if the RandomWalk task is working correctly
FirmwareValue average = manager->GlobalValueGet("average");
std::cout << "Average: " << average.Double << std::endl;
// Print the final axis position
std::cout << "Axis position: " << axis->CommandPositionGet() << std::endl;
task.Stop();
axis->MotionDoneWait(TIMEOUT_MS); // The axis might still be moving from the task, so wait for it to finish
axis->AmpEnableSet(false);
std::cerr << e.what() << std::endl;
// shutdown the task manager firmware process
if (manager.has_value())
manager->Shutdown();
Config::Cleanup(controller);
controller->Delete();
double CommandPositionGet()
Definition rsi.h:5863
Definition rsi.h:800
int32_t MotionDoneWait()
void Stop()
Stop the task from executing.
Definition rttask.h:435
static RTTaskManager Create(const RTTaskManagerCreationParameters &parameters)
Create a new RTTaskManager instance.
Definition config.h:147
Definition config.h:81
[SetupController]
Definition config.h:206
Definition helpers.h:32
[NetworkShutdown]
Definition helpers.h:146
[PrintHeader]
Definition helpers.h:162
The RealTimeTasks namespace.
Definition rttask.h:36
Definition rsi.h:866
Definition rttask.h:126
Definition rttask.h:140
int32_t Repeats
Number of times the task should execute (RepeatForever for infinite, 0 for none (one-shot)).
Definition rttask.h:170
int32_t Period
Execution period of the task in RMP sample periods.
Definition rttask.h:173
Definition rttask.h:320
Definition rsi.h:468
int64_t Int64
64-bit signed integer.
Definition rsi.h:478
double Double
Definition rsi.h:477
