IO: Math Blocks
Learn how to create and use Math Blocks in C#.
In this page:
📜 Math Block: Calculate Acceleration from Velocity
Learn how to configure Math Blocks 📖 to calculate the acceleration based on the change in velocity over time.
/* This sample app demonstrates configuring MathBlocks to calculate acceleration from velocity.
It uses one MathBlock to subtract the previous velocity from the current velocity to get the velocity delta,
and a second MathBlock to store the current velocity as the previous velocity for the next calculation.
The calculated acceleration is then derived from the velocity delta and sample rate.
Console.WriteLine("📜 MathBlock: Calculate Acceleration from Velocity");
const int MB_COUNT = 2;
const int MB1 = 0; // mathblock 1 index: subtract current velocity - previous velocity
const int MB2 = 1; // mathblock 2 index: store current velocity as previous velocity
const double VELOCITY = 1.0;
const double ACCELERATION = 0.0123;
const RSIDataType DOUBLE = RSIDataType.RSIDataTypeDOUBLE;
const RSIMathBlockOperation SUBTRACT = RSIMathBlockOperation.RSIMathBlockOperationSUBTRACT;
const RSIMathBlockOperation MULTIPLY = RSIMathBlockOperation.RSIMathBlockOperationMULTIPLY;
// get RMP controller
// set mathblock count before any RapidCodeObject get/create other than the controller
controller.MathBlockCountSet(MB_COUNT);
// get & configure axis
axis.PositionSet(0);
// set sample addresses
ulong userBuffer0Addr = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0);
ulong previousVelocityAddr = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, MB2);
ulong currentVelocityAddr = axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_VELOCITY);
// write 1 to user buffer index 0 for MB2 multiplication
controller.MemoryDoubleSet(userBuffer0Addr, 1);
// MathBlock 1 config: subtract current velocity - previous velocity
var mbConfig1 = controller.MathBlockConfigGet(MB1);
mbConfig1.Operation = SUBTRACT;
mbConfig1.InputAddress0 = currentVelocityAddr; // input0: current command velocity
mbConfig1.InputAddress1 = previousVelocityAddr; // input1: previous velocity (from 2nd MathBlock)
mbConfig1.InputDataType0 = DOUBLE;
mbConfig1.InputDataType1 = DOUBLE;
mbConfig1.ProcessDataType = DOUBLE;
// MathBlock 2 config: multiply current velocity by 1 to store previous velocity
var mbConfig2 = controller.MathBlockConfigGet(MB2);
mbConfig2.Operation = MULTIPLY;
mbConfig2.InputAddress0 = currentVelocityAddr; // input0: current command velocity
mbConfig2.InputAddress1 = userBuffer0Addr; // input1: constant "1" from user buffer
mbConfig2.InputDataType0 = DOUBLE;
mbConfig2.InputDataType1 = DOUBLE;
mbConfig2.ProcessDataType = DOUBLE;
// set MathBlock configurations
controller.MathBlockConfigSet(MB1, mbConfig1);
controller.MathBlockConfigSet(MB2, mbConfig2);
// wait 1 sample for MathBlock config to take effect
controller.SampleWait(1);
// move axis with small acceleration to verify MathBlock calculation
axis.MoveVelocity(VELOCITY, ACCELERATION);
controller.SampleWait(10);
// get latest sample velocity delta from MathBlock 1
double latestVelocityDelta = controller.MathBlockProcessValueGet(MB1).Double;
// reduce velocity back to 0
axis.MoveVelocity(0, ACCELERATION);
// get results
double sampleRate = controller.SampleRateGet();
double userUnits = axis.UserUnitsGet();
double calculatedAcceleration = latestVelocityDelta * Math.Pow(sampleRate, 2) / userUnits;
// rounding to 8 decimals matches encoder resolution for most systems.
// this is more precise than typical hardware needs.
double calculatedAccelerationRounded = Math.Round(calculatedAcceleration, 8);
// print results
Console.WriteLine($"Acceleration: {calculatedAccelerationRounded} (expected: {ACCELERATION})");
// verify accuracy
if (ACCELERATION != calculatedAccelerationRounded)
throw new Exception("❌ MathBlock result is outside accepted tolerance.");
double UserUnitsGet()
MathBlock operations.
Definition rsienums.h:1614
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
📜 Math Block: Difference of Position User Limit
Learn how to configure Math Blocks 📖 to set a value in memory and configure a User Limits 📖 to monitor and trigger an action based on it.
/* This sample app demonstrates configuring a MathBlock to calculate the difference of position between two axes
and using that MathBlock process value in a UserLimit to trigger an abort action when the difference exceeds a threshold.
This sample app requires at least 2 Axis so that positions can be read.
Console.WriteLine("📜 MathBlock: Difference of Position UserLimit");
const int INDEX_ZERO = 0;
// get rmp controller
// set mathblock & userlimit counts before any RapidCodeObject get/create other than the controller
controller.MathBlockCountSet(1);
controller.UserLimitCountSet(1);
// get & configure both axes
Helpers.CheckErrors(axis0);
Helpers.CheckErrors(axis1);
ulong axis0PositionAddr = axis0.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION);
ulong axis1PositionAddr = axis1.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION);
ulong mbProcessValueAddr = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, INDEX_ZERO);
// MathBlock config & set (mb.value = axis0.position - axis1.position)
var mbConfig = controller.MathBlockConfigGet(INDEX_ZERO);
mbConfig.Operation = SUBTRACT;
mbConfig.InputAddress0 = axis0PositionAddr; // input0: axis0 command position
mbConfig.InputAddress1 = axis1PositionAddr; // input1: axis1 command position
mbConfig.InputDataType0 = DOUBLE;
mbConfig.InputDataType1 = DOUBLE;
mbConfig.ProcessDataType = DOUBLE;
controller.MathBlockConfigSet(INDEX_ZERO, mbConfig);
// set UserLimit condition to trigger when absolute position difference exceeds threshold
number: INDEX_ZERO,
conditionNumber: 0,
logic: RSIUserLimitLogic.RSIUserLimitLogicABS_GT,
addressOfDouble: mbProcessValueAddr,
limitValueDouble: 5 * axis0.UserUnitsGet()); // 5 revolutions (values in firmware are not scaled by user units)
// set UserLimit to abort when condition above is met
number: INDEX_ZERO,
action: RSIAction.RSIActionABORT,
actionAxis: Constants.AXIS_0_INDEX,
duration: 0);
// move axis0 to trigger the UserLimit
axis0.MoveRelative(
relativePosition: 10, // revolutions
vel: 1,
accel: 1,
decel: 1,
jerkPct: 0);
axis0.MotionDoneWait();
// get results
var axis0State = axis0.StateGet();
// print results
Console.WriteLine($"Axis 0 state: {axis0State} (expected: {RSIState.RSIStateERROR})");
// verify userlimit triggered abort action
if (axis0State != RSIState.RSIStateERROR)
throw new Exception("❌ UserLimit did not trigger correctly - both axes should be in error state.");
Helpers.AbortMotionObject(axis0);
Helpers.AbortMotionObject(axis1);
controller.UserLimitDisable(INDEX_ZERO); // disable user limit
const int AXIS_1_INDEX
Definition _constants.cs:21
RSIState StateGet()
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
📜 Math Block: PDO Copy
Learn how to configure Math Blocks 📖 to copy a PDO value from one axis to another with a bias offset.
/* This sample app demonstrates configuring a MathBlock to copy a PDO value from one axis to another with a bias offset.
This sample app requires at least 2 real Axis so that PDOs can be read and written.
Console.WriteLine("📜 MathBlock: PDO Copy");
const int MB_INDEX = 0;
const int BIAS = 8000;
const RSIDataType INT32 = RSIDataType.RSIDataTypeINT32;
const RSIMathBlockOperation ADD = RSIMathBlockOperation.RSIMathBlockOperationADD;
// get & configure axis 0
// get & configure axis 1
// check axis are real and not phantom
if (!axis0.NetworkNode.Exists() || !axis1.NetworkNode.Exists())
Console.WriteLine("One or both axes are phantom (not real). Please use real axes for this sample app.");
// write BIAS value to user buffer index 0
// if you want a dynamic bias, you can write to this address at any time or use the process value of another MathBlock instead
ulong userBufferAddr0 = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0);
controller.MemorySet(userBufferAddr0, BIAS);
// configure the MathBlock to copy a PDO value from axis 0 to a PDO override value on axis 1 with a BIAS offset
// here we are using the actual torque of axis 0 and the target torque of axis 1, but these can be replaced with whatever PDOs you want
// by changing the index values to the desired PDOs
uint torqueActualIndex = axis0.NetworkIndexGet(RSINetworkIndexType.NetworkIndexTypeTORQUE_ACTUAL_INDEX);
ulong torqueActualAddress = controller.NetworkInputAddressGet((int)torqueActualIndex);
uint targetTorqueIndex = axis1.NetworkIndexGet(RSINetworkIndexType.NetworkIndexTypeTARGET_TORQUE_INDEX);
ulong targetTorqueAddress = controller.NetworkOutputAddressGet((int)targetTorqueIndex, RSINetworkOutputAddressType.RSINetworkOutputAddressTypeOVERRIDE_VALUE);
// enable the network override to copy the MathBlock output to the PDO
// only needs to be set once, probably in initialization
controller.NetworkOutputOverrideSet((int)targetTorqueIndex, true);
// MathBlock config & set (mb.value = axis0.torqueActual + BIAS)
var mbConfig = controller.MathBlockConfigGet(MB_INDEX);
mbConfig.InputAddress0 = torqueActualAddress; // input0: axis 0 actual torque
mbConfig.InputAddress1 = userBufferAddr0; // input1: BIAS from user buffer
mbConfig.InputDataType0 = INT32;
mbConfig.InputDataType1 = INT32;
mbConfig.Operation = ADD; // switch to MULTIPLY for proportional bias
mbConfig.ProcessDataType = INT32;
mbConfig.OutputAddress = targetTorqueAddress; // output: axis 1 target torque override
mbConfig.OutputDataType = INT32;
// set MathBlock and wait 1 sample for config to take effect
controller.MathBlockConfigSet(MB_INDEX, mbConfig);
// print results
Console.WriteLine($"MathBlock configured to copy axis {Constants.AXIS_0_INDEX} torque actual to axis {Constants.AXIS_1_INDEX} target torque with bias {BIAS}");
Console.WriteLine($"Operation: {mbConfig.Operation}");
Console.WriteLine("✅ MathBlock PDO copy with bias configured successfully");
NetworkNode * NetworkNode
Definition rsi.h:7077
bool Exists()
Returns true if this NetworkNode exists on a physical network.
Definition rsienums.h:621
Network output address types.
Definition rsienums.h:1595
RSINetworkIndexType
Definition rsienums.h:1573
